DonMuncy Posted December 29, 2021 Report Posted December 29, 2021 Mine are David Clarks with Headsets Inc. ANR conversion. Is anyone here conversant with that set-up to know whether there may be a stereo/mono selection there somewhere. Quote
carusoam Posted December 29, 2021 Report Posted December 29, 2021 29 minutes ago, DonMuncy said: Mine are David Clarks with Headsets Inc. ANR conversion. Is anyone here conversant with that set-up to know whether there may be a stereo/mono selection there somewhere. Fuzzy old memory, but…. check the side of this blob on the headset wire… it may have a tiny sliding switch that is probably marked M & S… Just a guess… Wish Bob was here… he really liked his DCs… and he was an electrical engineer…. Best regards, -a- Quote
DonMuncy Posted December 29, 2021 Report Posted December 29, 2021 Good memory Anthony. And for the LHS, they need to be in mono? I don't ever remember touching that switch. 1 Quote
carusoam Posted December 29, 2021 Report Posted December 29, 2021 My intercom is mono… I remember testing it to see what would happen if I flipped my DC’s stereo switch to stereo… it gave a weirder response other than cutting out the one channel… I was probably hoping I had a stereo intercom when I first got it…. Best regards, -a- Quote
donkaye, MCFI Posted December 30, 2021 Report Posted December 30, 2021 4 hours ago, DonMuncy said: Good memory Anthony. And for the LHS, they need to be in mono? I don't ever remember touching that switch. Only because you have a mono audio panel. With a stereo audio panel it can be in stereo. 1 Quote
tony Posted December 31, 2021 Report Posted December 31, 2021 As a test, , depin com2 and install the LHS in there and let us know what happens. Quote
Oscar Avalle Posted December 31, 2021 Report Posted December 31, 2021 Yes, this is just part of laser element characteristics. When flying straight & level in an IMC layer that is 'near' freezing, it can hit a target such as cooled water droplets ice crystals and report it back. The procedure for those who fly IMC regularly, is to either ignore it or disable the audio using the "Switched" input on the audio panel and add a note to their landing checklist to enable it. Yes, that is el what I thought and did.OscarSent from my iPhone using Tapatalk Pro Quote
GeeBee Posted January 2, 2022 Report Posted January 2, 2022 Where are most of the long body types mounting their sensor? Quote
dfurst Posted January 2, 2022 Report Posted January 2, 2022 12 minutes ago, GeeBee said: Where are most of the long body types mounting their sensor? On my Ovation, tight wing (closer to intercom) trailing edge panel, closest to the body. Short run. Nothing critical in the way. 1 Quote
Igor_U Posted January 4, 2022 Report Posted January 4, 2022 On 12/29/2021 at 2:10 PM, DonMuncy said: Good memory Anthony. And for the LHS, they need to be in mono? I don't ever remember touching that switch. Don, I have a DC headset with Headset Inc ANR and I don't think there's a stereo/mono switch like on other headsets... I used them for years with no issues with sono KMA24 and stereo PMA7000 audio panels. Quote
toto Posted January 4, 2022 Report Posted January 4, 2022 18 minutes ago, Igor_U said: Don, I have a DC headset with Headset Inc ANR and I don't think there's a stereo/mono switch like on other headsets... I used them for years with no issues with sono KMA24 and stereo PMA7000 audio panels. I think it depends on the source headset. I have a Headsets, Inc mod to an H10-13S, and it has a stereo/mono switch in the cable as described. But if you started with the non-S model, then it’s probably a mono headset with no switch. 1 Quote
DonMuncy Posted January 4, 2022 Report Posted January 4, 2022 Thanks everyone for the help. We are still working the problem. Quote
hammdo Posted January 5, 2022 Report Posted January 5, 2022 Don, I have the kit installed and I do have a mono audio panel (PMA7000M) using Bose A20 headset. I'm at KGYI and could fly down if you and your AP want to check mine out. -Don 2 Quote
Mcstealth Posted January 5, 2022 Report Posted January 5, 2022 1 hour ago, hammdo said: Don, I have the kit installed and I do have a mono audio panel (PMA7000M) using Bose A20 headset. I'm at KGYI and could fly down if you and your AP want to check mine out. -Don Just give you an excuse to fly......... 2 Quote
DonMuncy Posted January 5, 2022 Report Posted January 5, 2022 1 hour ago, hammdo said: Don, I have the kit installed and I do have a mono audio panel (PMA7000M) using Bose A20 headset. I'm at KGYI and could fly down if you and your AP want to check mine out. -Don Don, Thanks. Actually, the gurus working on it are a full avionics shop. (Which makes it even more unbelievable that we are having the problem.) I have a hard time envisioning that looking at yours would help troubleshoot mine. But they are going to reinstall the unit tomorrow and look again. I will tell them about your generous offer. I will let you know if they would like to look. Why don't you text me your number (214) 207-6744 and when I go out in the morning, I could call you if it looks helpful. Better yet, why don't you plan a flight to RBD and I will buy you lunch. then if they need to look at your plane, it will be convenient. 1 Quote
hammdo Posted January 5, 2022 Report Posted January 5, 2022 Great reason to meet up with a fellow 'mooniac' ;o) -Don 1 Quote
Danb Posted January 18, 2022 Report Posted January 18, 2022 On 12/25/2021 at 10:03 AM, LANCECASPER said: I was referring to a Mooney with a G1000 and the Garmin GMA 1347 Audio Panel. Hey Lance I’m currently having the LHS installed in my Bravo G1000, I believe there using the ADF button on the G1000, it should have the ability to turn on and off. 1 Quote
rbp Posted March 16, 2022 Report Posted March 16, 2022 On 3/15/2022 at 7:45 PM, tim417 said: Okay I kinda want this. I’m having one installed on my Brave as we speak! Can’t wait to try it out Quote
donkaye, MCFI Posted March 16, 2022 Report Posted March 16, 2022 I've had mine since it first came out. I'd recommend it to everyone. I used the old trim circuit breaker from the KFC 150 for the breaker and an on/off switch. Install time about 7 hours. 1 Quote
Will.iam Posted March 16, 2022 Report Posted March 16, 2022 Wow 7 hours? What took the most time? Quote
donkaye, MCFI Posted March 16, 2022 Report Posted March 16, 2022 4 minutes ago, Will.iam said: Wow 7 hours? What took the most time? A little over 3 hours to remove and cut the inspection plate to attach the device and run the wires to the front panel. The balance of the time to run the wires to the audio panel and wire the circuit breaker and on/off switch. I have a deluxe installation. If you don't want the circuit breaker, the install time would be less. You should have the on/off switch because you will want the unit off when flying in moisture because the lidar will reflect the rain and give a false reading. 1 Quote
DonMuncy Posted March 16, 2022 Report Posted March 16, 2022 I have had mine for a LONG time and still do not have it installed properly. I took it to my avionics shop (who I have used for a long time; have multiple excellent technicians I trust, etc.) They put it in, but the volume on the unit is so low it can barely be heard on roll-out, and not at all in the air. They ultimately sent the unit back to Nidal to be checked out. He said it is within specs. After reinstallation, it is unchanged. They had everyone in the shop scratching their heads, but no answer yet. One of our MS guys has offered to bring his plane (with an installed unit) for me to listen to, and ultimately swap my unit for his to troubleshoot, but we haven't gotten together yet. Any ideas? Quote
