Hi guys, on the right side of the pilots yoke is a toggle switch as you can see in the picture. Anybody have any guess what it might be for?  I thought it might be for the ejection seat but I tried it and it didn’t work so I ruled that option out.
Switches and buttons on the yoke are anyone's guess if they don't don't match the POH.  A lot of them are added or changed without documentation.
I have seen similar setups wired to the ident on the transponder. Try pressing it airborne while watching the transponder for an ident light.
Try it on the ground first...
Just in case it opens the bomb bay door, or something surprising...
Is there a way to contact your prior owner to ask?
"Press to Test Release to Detonate" switch :unsure:    Maybe  stab trim or like other have said AP disconnect if it is momentary switch .
Edited by jamesm
My right hand side of the yoke has 2 switches, one for clearing weather on stormscope and the other an instant replay of last audio.  Dont use either one of them much.
activates the guns .30 caliber in the Mooney since we are a little smaller than the mustang which  had the .50 caliber.
Correct! In the later years Mooneys, like my 75, they moved the switch to the throttle.
My guess it is the map light. That is where mine is located.
this!!
