MBDiagMan Posted May 25, 2020 Report Posted May 25, 2020 I am going to make a tailbob on a flat dolly for my F. What size washtub and how many sackcrete bags? Quote
jetdriven Posted May 25, 2020 Report Posted May 25, 2020 I made a tie down out of sand bags and a piece of plywood, and a steel bar and some chain. Quote
Robert Hicks Posted May 25, 2020 Report Posted May 25, 2020 I I forget the size of tub we used, maybe ~30 gallons? I do know it took a little less than 3 bags of concrete mix. Quote
Hank Posted May 25, 2020 Report Posted May 25, 2020 The ones I've seen have all been standard washtubs. Screw on the casters, bend a piece of rebar to attach to (so it can't pull out), make sure everything is how you want it, then mix Quikrete in your wheelbarrow and fill 'er up! Should last for decades of heavy use. Quote
David Lloyd Posted May 25, 2020 Report Posted May 25, 2020 The shop at my airport has had the bottom third of a 55 gallon drum on casters, filled with wing bolts (someone told me B-25) for 41 years. Airport is closing, mechanic was taking everything with him, tried to lift it with an engine hoist. Just about the time it began to lift off the floor, the metal rod and hook pulled through the bottom of the drum. Good thing it didn't happen during any of my annual inspections! Quote
MBDiagMan Posted May 25, 2020 Author Report Posted May 25, 2020 (edited) Thanks for your responses. I know exactly how to make it. What I need is the wash tub size and how many bags to get. There are many sizes available. I want it to be heavy enough for an F, but not too heavy. My hangar is large and I won’t be swinging the gear of a Citation in the foreseeable future so I don’t want too much weight to move around. Edited May 25, 2020 by MBDiagMan Quote
BrianWilkins Posted May 25, 2020 Report Posted May 25, 2020 On 5/25/2020 at 5:06 PM, MBDiagMan said: Thanks for your responses. I know exactly how to make it. What I need is the wash tub size and how many bags to get. There are many sizes available. I want it to be heavy enough for an F, but not too heavy. My hangar is large and I won’t be swinging the gear of a Citation in the foreseeable future so I don’t want too much weight to move around. Expand I use a different method than what you're going to make, but if it will help you calculate what you need; I found that approximately 200 lbs of weight on the tail held my E model just about right. If you take that number and figure out the volume of quickcrete needed, you should have the info you need. 1 Quote
MBDiagMan Posted May 25, 2020 Author Report Posted May 25, 2020 Yes, the required weight is what I need. I can calculate everything else. I thought there had been so many of these things made that people would off the top of their heads know how many bags and which size washtub. Thanks to all. Quote
jetdriven Posted May 25, 2020 Report Posted May 25, 2020 IIRC I have 5 bags of 60lb sand. 300 lb. I’ll take a look tomorrow at my hangar. Quote
EricJ Posted May 25, 2020 Report Posted May 25, 2020 (edited) My IA uses about 200 lbs of stacked concrete block. They're much easier to move around than a tub full of concrete. I'm going to start using a Harbor Freight 1klb dolly with blocks stacked on it. That way the dolly and blocks can be moved around easily and repurposed when necessary. I've seen people try to dispose of concrete tubs at the airport and it's not pretty. Edited May 25, 2020 by EricJ Updated reason for editing. Quote
N201MKTurbo Posted May 25, 2020 Report Posted May 25, 2020 Any private pilot should know how to calculate this. I would make it twice the up force with two 200 pounders in the front seats. Quote
carusoam Posted May 26, 2020 Report Posted May 26, 2020 Some shops load bags on the wing... Others tie the tail down... The details have been covered here already... But... if you want more.... https://mooneyspace.com/search/?&q=Tail tie down weight&search_and_or=and&sortby=relevancy Best regards, -a- Quote
Hank Posted May 26, 2020 Report Posted May 26, 2020 I thought "washtub" was a standard size . . . . 1 Quote
RLCarter Posted May 26, 2020 Report Posted May 26, 2020 It’s been discussed before but here is the Service Bulletin Quote
Guest Posted May 26, 2020 Report Posted May 26, 2020 I’ve got one that is a welded steel frame made of 1-1/2” angle iron on 4 heavy casters. It holds 4- 12” solid concrete blocks (80# each) stacked 2 high on each side of a telescoping post. Being blocks makes it somewhat portable. Clarence Quote
ragedracer1977 Posted May 26, 2020 Report Posted May 26, 2020 On 5/26/2020 at 7:41 AM, RLCarter said: It’s been discussed before but here is the Service Bulletin Expand And there's a long thread on it where I think @M20Doc contacted Mooney and they said keep tying the tail down Quote
jetdriven Posted May 26, 2020 Report Posted May 26, 2020 I have 5 bags of 60lb sand. 300 lb. I’ll take a look tomorrow at my hangar. 1 Quote
tmo Posted May 26, 2020 Report Posted May 26, 2020 How are "standard aircraft jacks" called for by the SI different from non-aircraft jacks? Is it a question of compatible support points, or is there something more to it? Quote
RLCarter Posted May 26, 2020 Report Posted May 26, 2020 On 5/26/2020 at 3:25 PM, tmo said: How are "standard aircraft jacks" called for by the SI different from non-aircraft jacks? Is it a question of compatible support points, or is there something more to it? Expand Probably a CYA thing 1 Quote
RLCarter Posted May 26, 2020 Report Posted May 26, 2020 On 5/26/2020 at 2:00 PM, ragedracer1977 said: And there's a long thread on it where I think @M20Doc contacted Mooney and they said keep tying the tail down Expand not sure, its been brought up numerous times, I use the “A” frame method along with a tail stand, gives it 4 points and rock solid..... my pucker factor isn’t as high as it use to be compared to the 1st time Quote
Hank Posted May 26, 2020 Report Posted May 26, 2020 On 5/26/2020 at 7:41 AM, RLCarter said: It’s been discussed before but here is the Service Bulletin Expand Mooney says after 50 years to not hold the tail down, but to lift by the engine. Hartzell and McCauley say to not use a prop jack to lift by. Lycoming says to not lift the nose ofnthe olane using the engine, the lift points are designed to lift only the engine. So apparently we're supposed to jack the wings and magically levitate the nose wheel into the air. I've stacked two cases of oil, a large roll of wrenches and a couple feet of bound approach plates on my tail, then held it stable by hand. You gotta do what you gotta do . . . . Quote
RLCarter Posted May 26, 2020 Report Posted May 26, 2020 @Hank yep, pick what your comfortable with. I had to pull the gear out of the 172 a few years ago, built the cradle per the maintenance manual, seemed like I had to jack it up into the Flight Levels before the cradle would go under it......... Jacking Airplanes up just feels wrong..... Quote
EricJ Posted May 26, 2020 Report Posted May 26, 2020 On 5/26/2020 at 5:19 PM, Hank said: Mooney says after 50 years to not hold the tail down, but to lift by the engine. Expand I've not heard the 50-year caveat before. Where did that come from? Was there associated advice about tying the aircraft down for a storm with or without the tail tie down after 50 years? Quote
Skates97 Posted May 26, 2020 Report Posted May 26, 2020 Cheap furniture dolly from Harbor Freight, a piece of plywood, and three 90# bags of the cheapest quick-crete from Home Depot. When not in use it is wheeled under the big shelf in the corner of the hangar. Quote
Guest Posted May 26, 2020 Report Posted May 26, 2020 On 5/26/2020 at 2:00 PM, ragedracer1977 said: And there's a long thread on it where I think @M20Doc contacted Mooney and they said keep tying the tail down Expand I actually checked with Lycoming, who said the engine lift ring is meant to lift the engine, not the airplane. Clarence Quote
