Maybe the plastic foot wells were originally screwed into the strips?  Mine were fastened to the replacement panels, installed about 25 years ago I guess.
Looks like my 65C had the same aluminum for using sheet metal screws to hold the side paneling on...
I don’t remember any plastic protected adel clamps there though...
  On 4/28/2019 at 6:55 PM, ArtVandelay said:
That hose is older than dirt...I would replace it. I bet it breaks apart when you remove it.
Expand
It is very old but in surprisingly good shape. The one on the pilot side is toast. Both will be replaced soon.
An additional function of a lot of metal pieces placed around under the panel by Mooney engineering is to maximize the number of very sharp edges to maximize the blood shed  from people trying to trace wires and cables and hoses and crap.
I swear there's some really stupid stuff down there that makes you think somebody did it intentionally, or at a minimum couldn't be bothered to consider that anybody would ever have to reach under there for anything.   I've learned to keep a file handy just to improve and lighten and the airframe under there just for my own health and to minimize the blood stains on the carpet.
Expand
LOL.  It is very sharp at the corners and edges. I am amazed that the factory installed such a sturdy piece of metal to mount a flimsy piece of plastic.   Maybe they originally had plans for a heavier footwell.
  On 4/28/2019 at 6:11 PM, Rwsavory said:
 Does this strip of aluminum serve any purpose other than to fasten a side panel?  My side panels were not screwed into it.
It was what rwsavory says it is. It is for attaching the lower plastic. You can see the screw holes in the picture.
Expand
There are obvious signs of wandering screws that scratched the plate around those two holes during past interior installs.   The plate is oversized- it could be made smaller and sharper.  :(
Expand
Currently there are two corners that can easily get ya, cut the center section out so you would have two separate plates doubling you chances of leaving a little DNA :D
There is about an inch of wandering when these are panels are reinstalled. I believe they have made them larger because they were trying to protect wiring that may run behind them.
Here is the wandering zoomed in.
Wiring running behind it.
