charlesual Posted March 11, 2019 Report Posted March 11, 2019 I recently noticed erratic fuel pressure at cruise and needed richer then normal setting to keep the engine running smoothly. (11.5 gph vs the usual 8.5 gph). It ran smooth leaned out when I turned the electric boost pump on. The fuel screens on the fuel selector and fuel servo were clean and vent tube unobstructed so I’m pretty sure my mechanical fuel pump is degraded or getting ready to fail. Looks kind of hard to get to it without removing the mags or fuel filter. (My IA says mags need to be removed to access and estimates an 8 hour job but hasn’t actually done one before) Any recommendations on removal and installation of new fuel pump? Thanks mooneyspace. Sent from my iPhone using Tapatalk Quote
RLCarter Posted March 11, 2019 Report Posted March 11, 2019 I replaced the one on my E, top &a bottom cowl was removed but left and right mags stayed in place. Don't remember it being all that hard to get to. I removed the old one, my IA rotated the engine slowly to get the plunger fully retracted to allow installation of the new pump, torqued and saftey wired the 2 bolts and reassembled. Not sure about the time frame start to finish but was less than 8 hrs Quote
N201MKTurbo Posted March 11, 2019 Report Posted March 11, 2019 A long ball end Allen Socket makes it easier. Quote
Shadrach Posted March 11, 2019 Report Posted March 11, 2019 There is no need to disturb the mags when removing the fuel pump. Moreover, 8hrs seems a bit ridiculous. I’m pretty sure it took under 8 hours for me to completely remove my engine. It may be beneficial to remove the top bolts that fasten the engine mount to the firewall so that the engine can be tilted forward a bit. The fuel pump is secured by two allen bolts IIRC. It may also have a cover which presents its own challenges. this is what your accessory case looks like with FP still attached. 1 Quote
charlesual Posted March 11, 2019 Author Report Posted March 11, 2019 That is very helpful!! Thanks for responding. Gotta love mooneyspace. Sent from my iPhone using Tapatalk Quote
orionflt Posted March 11, 2019 Report Posted March 11, 2019 removing the top engine mount bolts and tilting the motor gives plenty of room to access the fuel pump. it is still a bear to work on but you do not have to remove anything else. make sure an engine hoist is hooked to the engine before removing the engine mount bolts from the firewall. Brian 1 Quote
Shadrach Posted March 11, 2019 Report Posted March 11, 2019 Yes, I should have mentioned the hoist. Definitely need a hoist to tilt the engine. Quote
gsxrpilot Posted March 11, 2019 Report Posted March 11, 2019 It looks to me like you're about 45 Mooney minutes away from N87 where there is a very reputable and experienced Mooney shop. I'll bet it would be worth the fuel to take it to someone who knows what they're doing and have done it not just once, but many times. Call ahead, and get on the schedule. Have them order the parts ahead of time. Then fly in, get it done, and fly home. Quote
Yetti Posted March 12, 2019 Report Posted March 12, 2019 I was laughed at when I asked if the grumpy IA wanted to do it or maybe that was the starter. One AP said you have to remove the left mag. I sacrificed a 5/15 allen wrench to about 2" and then used a socket and ratchet to turn it. Making sure the plunger is in the right spot. I was slow doing it the first time ever and probably took 5 hours. Much like changing a Chevy V8 pump. Except it is on the back of the engine and under a mag. Quote
Yetti Posted March 12, 2019 Report Posted March 12, 2019 Wait you said GPH what is the PSI doing? Leak down test? Quote
67 m20F chump Posted March 12, 2019 Report Posted March 12, 2019 I’m glad you posted about this. We are getting ready to change my pump too. I have the mags off for inspection and I don’t want to go back after the pump. May as well swap it out since I’m there. Spruce has overhauled tempest pumps but for $20 more you can get new lycoming pump and no core charge. Quote
takair Posted March 12, 2019 Report Posted March 12, 2019 Heads up. There is a thread (or two) about the mechanical pumps. There is an ongoing issue with the new pumps putting out pressure above Mooney redline. Lycoming says it’s fine, but your IA may not. I ended up reverting to the old Lycoming pump, others go with the tempest. This is really frustrating for those caught off guard. Quote
RLCarter Posted March 12, 2019 Report Posted March 12, 2019 4 hours ago, takair said: Heads up. There is a thread (or two) about the mechanical pumps. There is an ongoing issue with the new pumps putting out pressure above Mooney redline. Lycoming says it’s fine, but your IA may not. I ended up reverting to the old Lycoming pump, others go with the tempest. This is really frustrating for those caught off guard. I went with the Lycoming pump, while not at redline it's pretty close Quote
Marcopolo Posted March 12, 2019 Report Posted March 12, 2019 In my experience, pulling the left mag serves a dual purpose when replacing the mechanical fuel pump. 1) allows better access for removing and installing the hoses and the pump. 2) allows a visual verification through the magneto mount hole that the fuel pump actuator rod is riding in the right place prior to buttoning everything up. If the 2 fuel mount bolts aren't tightened progressively and evenly, there's a possibility that the actuator rod will ride off of the plunger and if the engine is started like this other damage may occur. Ron 2 Quote
charlesual Posted March 12, 2019 Author Report Posted March 12, 2019 Great feedback from all. Thanks!!Sent from my iPhone using Tapatalk Quote
Woodpile Posted October 4, 2023 Report Posted October 4, 2023 I just replaced mine in in the 20F. I have the cooling shroud and needed to slightly raise the mag cover to get the shroud out. Surefly mag cover was quick to tilt up (just another set of safety wire). I removed the oil filter for better access from the top. - tape the gasket when re-installing - the hoses are a bear to align - never thought I could get my arm under the exhaust and come up the middle. Dropping lower cowl might be useful, but not worth the extra work - just the ram air duct would take me an hour. - less than 8 hours and I've never done one - no need to remove mag or tilt engine - exercise caution on Aircraft Spruce, as 3 different pressure versions of the same pump are on the same page. The compatibility sheet is spot on though. 2 Quote
A64Pilot Posted October 11, 2023 Report Posted October 11, 2023 On 3/12/2019 at 8:23 AM, Marcopolo said: In my experience, pulling the left mag serves a dual purpose when replacing the mechanical fuel pump. 1) allows better access for removing and installing the hoses and the pump. 2) allows a visual verification through the magneto mount hole that the fuel pump actuator rod is riding in the right place prior to buttoning everything up. If the 2 fuel mount bolts aren't tightened progressively and evenly, there's a possibility that the actuator rod will ride off of the plunger and if the engine is started like this other damage may occur. Ron Almost 50 years ago I did that on a small block Chevy, didn’t damage anything luckily, put a nasty burr on the actuating plunger though that I filed out. Funny how many similarities there are to some automotive engines Quote
75_M20F Posted October 14, 2023 Report Posted October 14, 2023 You should consider checking the pressure output of the mechanical fuel pump with another pressure gauge before you go through the removal and replacement. Just to make sure its the true issue. 1 Quote
