Don M Posted August 16, 2018 Report Posted August 16, 2018 Hi, I am the proud owner of a Mooney 201J since April of this year. I am struggling switching tanks when flying as the fuel tank lever is on the floor. Has anyone seen some sort of tool that is available for this purpose so I don’t need to bend down go switch tanks? thank you, Don ps: love my plane. I transitioned from a piper Arrow11.
autopatch Posted August 16, 2018 Report Posted August 16, 2018 30 minutes ago, Don M said: Hi, I am the proud owner of a Mooney 201J since April of this year. I am struggling switching tanks when flying as the fuel tank lever is on the floor. Has anyone seen some sort of tool that is available for this purpose so I don’t need to bend down go switch tanks? thank you, Don ps: love my plane. I transitioned from a piper Arrow11. This is the tool that I purchased and I am happy with. (We share the same problem with the Cessna Cardinal series.) https://www.ebay.com/itm/Mooney-Fuel-Selector-Arm-Extender/142560991626
FastTex Posted August 16, 2018 Report Posted August 16, 2018 (edited) 10 minutes ago, autopatch said: This is the tool that I purchased and I am happy with. (We share the same problem with the Cessna Cardinal series.) https://www.ebay.com/itm/Mooney-Fuel-Selector-Arm-Extender/142560991626 Interesting. Does it connect to the lever throughout the flight? If, yes How? Edited August 16, 2018 by FastTex
N201MKTurbo Posted August 16, 2018 Report Posted August 16, 2018 Or you can make one at the Home Depot for about $1 if you already have the glue. The glue will set you back about $5 4
gsxrpilot Posted August 16, 2018 Report Posted August 16, 2018 1 hour ago, FastTex said: Interesting. Does it connect to the lever throughout the flight? If, yes How? No. It is just an extension of your reach. You can make one out of PVC pipe from HomeDepot as @N201MKTurbo said. Just cut a notch in the end to fit over the tank selector. Use it to switch tanks and then stow it in a side pocket or somewhere convenient. 1
steingar Posted August 16, 2018 Report Posted August 16, 2018 I just undo my shoulder belt and enjoy a bit of self-fellatio while I change the tanks. I have to admit, I am very afraid of running a tank dry at low altitude. I have to take off my shoulder belt at a moment when its services may be vitally important, and boy am I worried about how that report is going to be written. 1 3 1
carusoam Posted August 16, 2018 Report Posted August 16, 2018 Welcome aboard, Don! Official Transition Training didn’t cover the Mooney diet and stretching exercises? While you are looking at building the official tool for switching tanks... Also look up the other tool you want... something to verify fuel level in the tanks while on the ground... That Al Mooney guy was very slim. Best regards, -a-
ArtVandelay Posted August 16, 2018 Report Posted August 16, 2018 Is the 78J different, because this has never been a problem, it’s right in the middle, no overt body contortions required?
carusoam Posted August 16, 2018 Report Posted August 16, 2018 Same place, I believe, until it moved to the center of the cockpit... Centered is just easier to access. For the CFI sitting right seat too... Best regards, -a-
N201MKTurbo Posted August 16, 2018 Report Posted August 16, 2018 3 minutes ago, teejayevans said: Is the 78J different, because this has never been a problem, it’s right in the middle, no overt body contortions required? Yes.
carusoam Posted August 16, 2018 Report Posted August 16, 2018 The old location is on the floor in front of the pilot... When you look down for it, the yoke is sort of in the way... Bending to reach it becomes more of a challenge the further you are from ‘standard’ pilot. Trying to dodge yourself and the yoke while operating the valve is a real challenge... centered between the pilots makes a lot more sense... Best regards, -a-
Hank Posted August 17, 2018 Report Posted August 17, 2018 4 hours ago, carusoam said: The old location is on the floor in front of the pilot... When you look down for it, the yoke is sort of in the way... Bending to reach it becomes more of a challenge the further you are from ‘standard’ pilot. Trying to dodge yourself and the yoke while operating the valve is a real challenge... centered between the pilots makes a lot more sense... Best regards, -a- I lean forward, turning my head to the left and dropping my right shoulder to reach the floor between and behind my feet . . . Having gained a few pounds in my decade of ownership, it's more difficult than before. But I'm working on reducing my midsection; so far, I've gained back ~3 gal of fuel. And switching tanks is much easier, after start on the ground and in the air. 1 1
eman1200 Posted August 17, 2018 Report Posted August 17, 2018 10 hours ago, autopatch said: This is the tool that I purchased and I am happy with. (We share the same problem with the Cessna Cardinal series.) https://www.ebay.com/itm/Mooney-Fuel-Selector-Arm-Extender/142560991626 this is the method I learned from @DrBill cost me pennies to make, works great. 1
MyNameIsNobody Posted August 21, 2018 Report Posted August 21, 2018 I want to feel that move from one decent to the other. I am more concerned with turning fuel off and thinking I swapped tanks... Way to go Hank. That is impressive. Health benefits a big benefit too!
Josue Posted June 19, 2021 Report Posted June 19, 2021 On 8/16/2018 at 11:51 AM, N201MKTurbo said: Or you can make one at the Home Depot for about $1 if you already have the glue. The glue will set you back about $5 You have the size of the groove?
McMooney Posted June 19, 2021 Report Posted June 19, 2021 let go of the yoke, grab the metal bar in the windshield, pull yourself forward till you can reach it. think i'll be going to home depot tomorrow
N201MKTurbo Posted June 19, 2021 Report Posted June 19, 2021 42 minutes ago, Josue said: You have the size of the groove? No, I have long arms and legs, I don’t need it. There was one in the plane when I bought it, but I never used it.
201Steve Posted June 19, 2021 Report Posted June 19, 2021 I used one for about the first 10 flights. Found the strategy for me, never use it now.
David Lloyd Posted June 19, 2021 Report Posted June 19, 2021 When I bought this Mooney two years ago, first time I tried the swap tank in flight, what the heck? Can't reach the selector! Don't remember that being a problem 35 years ago. Strained to get it, then found the red plastic tee handle. If you make your own, just remember to have the notch and tee aligned so it is easy to tell the selector is turned all the way right or left. Anyone with a C and worried about running one tank dry ought to purposely try it sometime and see how easily and quickly the engine restarts. Don't try it at 500' off the departure end of the runway.
