N231SM Posted May 7, 2018 Report Posted May 7, 2018 Hello all. This is located far right firewall under the glare shield behind the fuse column. I am wondering what this coil like part is. There are 2 rubber boots. Attached to one is a wire putting out .25v all the tiime from one of those boots, unaffected by master/avionics. There is a large connector as well. I have the diagram if someone could tell me what this might be. Also, does anyone have a list of all the likely in line fuses under pass and pilot dash? I am labeling them as fast as I can isolate them. There are 5 under the pass g-shield. Tks
N201MKTurbo Posted May 7, 2018 Report Posted May 7, 2018 The thing with the two red boots is the ammeter shunt. 2
carusoam Posted May 7, 2018 Report Posted May 7, 2018 Would you recognize a shunt if you saw one? I’m not able to see it very clearly, and I’m not exactly sure of its location... But the shunt is a low resistance, calibrated resistor, That is used to measure current being used by the plane... Rich, beat me to the post! Best rgerads, -a-
Yetti Posted May 7, 2018 Report Posted May 7, 2018 The second pic is a military connector with multiple conductors/wires in it. I forget the common name of them. https://www.alliedelec.com/amphenol-industrial-ms3102e14s-5p/70143498/?mkwid=sPpjQ7qdz&pcrid=30980760979&gclid=CjwKCAjw8r_XBRBkEiwAjWGLlC0tfR4vb3zwLdM1LcK7yfpe6hW95gsSwaHbBXNlQiN_DDniXAd10RoC8mgQAvD_BwE
Yetti Posted May 7, 2018 Report Posted May 7, 2018 Generally in that position on the other side of the firewall in an F there is a noise filter to keep spikes out of the electrical system.
Yetti Posted May 7, 2018 Report Posted May 7, 2018 Here are the J schematics by serial number http://mooney.free.fr/Manuels M20J/M20J/Mooney Service Manuel M20J Vol. 2 of 2.pdf 1
N231SM Posted May 7, 2018 Author Report Posted May 7, 2018 OK. A shunt. Is that what I am looking for in the wiring diagram? Small one- # 18 probably. I have a wire coming off one of the boots that looks like it should go somewhere. Tks
Mooneymite Posted May 7, 2018 Report Posted May 7, 2018 The thin wires off the shunt go to the ammeter, I believe. 1
Guest Posted May 7, 2018 Report Posted May 7, 2018 I don’t have a K model schematic at home, but that is a shunt. Normally for the ammeter, the small wires normally pass through 2 in line glass fuses, one in each wire. Clarence
tony Posted May 7, 2018 Report Posted May 7, 2018 (edited) I think he is taking about the silver box to the right of the shunt. Edited May 7, 2018 by tony
kris_adams Posted May 8, 2018 Report Posted May 8, 2018 I’m continually amazed at the knowledge of this group. Wish I could add more! 1
Guest Posted May 8, 2018 Report Posted May 8, 2018 Without knowing what equipment is installed, I can only guess. The black box with the cannon connector might be a prop device timer? Clarence
N201MKTurbo Posted May 8, 2018 Report Posted May 8, 2018 1 hour ago, M20Doc said: Without knowing what equipment is installed, I can only guess. The black box with the cannon connector might be a prop device timer? Clarence Spell check fail!
Warren Posted May 8, 2018 Report Posted May 8, 2018 Hi N231SM, We are neighbors. I am at Metro airport. I have a 1985 K. The box with the round connector looks like the BF Goodrich prop heat timer module. I have a full set of wiring diagrams if you want to look at or borrow them. PM me if interested. Warren
Guest Posted May 8, 2018 Report Posted May 8, 2018 6 hours ago, N201MKTurbo said: Spell check fail! Actually it’s the Apple way of spelling de-ice. If we get a spelling and grammar check person here on MooneySpace they will surpass Anthony’s post count in no time! Clarence
N231SM Posted May 8, 2018 Author Report Posted May 8, 2018 Hello all, I finally figured out it is a shunt for the prop de-ice ammeter. There should be a fuse on each wire going to the meter. The connector looks like the connector that goes to the prop de-ice timer. So, again.........what a fantastic knowledge base. Jim 3
Stephen Posted May 8, 2018 Report Posted May 8, 2018 22 hours ago, Yetti said: The second pic is a military connector with multiple conductors/wires in it. I forget the common name of them. https://www.alliedelec.com/amphenol-industrial-ms3102e14s-5p/70143498/?mkwid=sPpjQ7qdz&pcrid=30980760979&gclid=CjwKCAjw8r_XBRBkEiwAjWGLlC0tfR4vb3zwLdM1LcK7yfpe6hW95gsSwaHbBXNlQiN_DDniXAd10RoC8mgQAvD_BwE "Cannon plug"?
tony Posted May 9, 2018 Report Posted May 9, 2018 13 hours ago, Stephen said: "Cannon plug"? 38999 or thirty eight triple nine. Comes from the mil-std.
