Riddle me this, what could cause a low vacuum light at takeoff and cruise power, but not at low rpm or during the run up? I don’t have a gauge, just an idiot light on my 1970 M20E. The wing leveler/autopilot and artificial horizon work fine.
That High/Low vac switch can be twitchy....most seem to be installed to float somewhere on the vacuum line.  Perhaps it is a vibration issue.
See if you can borrow a vacuum gauge to install to check the actual vacuum pressure before you spend a lot of time/effort looking for a vacuum problem.
I had the vacuum switch go bad on me. Fortunately my avionics guy had one lying around from his own Mooney, removed when the vacuum system was removed. I now also have a spare one, which was removed from my K this past summer. I’ll sell it if you need it.
Do you have a single light vs two lights?  Is it possible that it is acting as the low and High vacuum light and it is responding to high vacuum?
Previous owner installed a vac gauge on my O...
The idiot lights just don’t give enough information.  You don’t need to be an engineer to appreciate the added data...
Looks like a mechanic may need to install a temporary gauge or a real gauge to get you to the next step...
Do you have a JPI already?
PP Thinking out loud, not a mechanic...
On 2/14/2018 at 8:32 AM, N9405V said:
I have the two light setup.
Does the low light come on when the engine is not running?
Yes, and at low idle. Above 900 rpms to 1800 rpms light goes out. Then, when I apply take off power, it comes on.
Really strange.  Would be best to insert a gauge to see what’s going on.  Could be a bad switch or electrical.  Maybe it responds to vibration vs pressure.
