Jerry 5TJ Posted August 1, 2016 Report Posted August 1, 2016 On July 29, 2016 at 11:00 AM, teejayevans said: Does anyone use synthetic vision? I have it with Garmin pilot and played with it, once past the gee wiz phase it's not very useful, probably could use it for a 0-0 landing in case of a emergency, but it would not be a smooth one, sometimes use it to look for traffic, what am I missing? I find SV quite useful in approaches in IMC. On the G500 the Flight Path Marker (FPM) appears on the screen and as the SV-generated runway comes into view the FPM hovers at the approach end of the runway and confirms the approach. I find it helps situational awareness. If there is distinctive terrain near the runway it will show on SV and that helps in the transition from "on the gauges" to flight by visual reference--the depiction hints at what you'll see when you look for the runway. I don't have any images I've taken showing this as I'm generally busy at that moment. Here's an image from Internet search that shows the FPM predicting touchdown on the runway. If this were an LPV approach the GPS1 annunciation would show APR rather than TERM there would be a GS displayed to the right the baro minimums would be shown (if loaded) Still you can see the round green FPM on the runway near the TDZ. As you fly the FD or "the needles" the sight of the SV runway orients you. It isn't necessary but it is a helpful part of the glass presentation. The less familiar you are with the field the more it helps. Just yesterday I flew the RNAV GPS 10 LPV into KAOH, a field I'd never seen before. I could see the approach end of 10 at about 900 AGL but couldn't recognize it as a runway. SV showed I was right on path to the runway. At 600 AGL the view out front made sense. As you get close you can read the runway numbers, too, and make sure they match your landing clearance... 1 Quote
NotarPilot Posted August 1, 2016 Report Posted August 1, 2016 19 hours ago, aviatoreb said: Too bad - that is what I would want. Then, what is the G5 or Dynon doing for me that this GRR unit does not - plus the GRR is cheaper, and it has SVT? http://www.grtavionics.com/mini-ga.html If you really really want SVT then consider the ESI-500 but keep in mind everything has a price when you want something. I think I remember L-3 saying it was around $5,000 but it's definitely a beautiful unit. ESI-500 Quote
geoffb Posted August 1, 2016 Report Posted August 1, 2016 As I see it, these things are no more than a solid state alternative to a second, electric AI like a Castleberry or Lifesaver. For a similar price, we're hopefully getting a redundant attitude instrument with a better MTBF than and electric gyro. So, if you're like me and you have a pretty much all vacuum airplane with a Brittain autopilot, you can dump the turn and bank, replace it with the G5 or Quattro per the advisory circulars and add some valuable redundancy with battery backup. Based on the pinout diagram for the Quattro, I suspect there's a whole lot more functionality built in than Sandia is using right now. But until the regulatory guidance changes, I don't think we'll see it turned on. 2 Quote
Danb Posted August 1, 2016 Report Posted August 1, 2016 Jerry you can grab Chris and practice 0/0 landings ( emergency only) using the synvis it's quite amazing how much utility you get from the flight path marker. Quote
StevenL757 Posted August 1, 2016 Report Posted August 1, 2016 On 7/29/2016 at 0:28 AM, gsengle said: Wake me when it will drive my KFC150 Sent from my iPhone using Tapatalk Psst...L-3 ESI500 Genesis. :-) Quote
StevenL757 Posted August 1, 2016 Report Posted August 1, 2016 1 hour ago, NotarPilot said: If you really really want SVT then consider the ESI-500 but keep in mind everything has a price when you want something. I think I remember L-3 saying it was around $5,000 but it's definitely a beautiful unit. ESI-500 Agree. I have one with the dedicated MAG-500 heading input option, SynVis, and the ILS/VOR-LOC/GPS inputs...fully-loaded, really. I believe Don K. has a similar arrangement in his Bravo. All total, my cost (w/o install) was about $8,700. List cost will obviously be higher, but at the ~$5k price point, you should get a really nice unit nonetheless... Quote
aviatoreb Posted August 1, 2016 Report Posted August 1, 2016 Hmmmm! SO the ESI500 Genesis drives the autopilot? Quote
Marauder Posted August 1, 2016 Report Posted August 1, 2016 Jerry you can grab Chris and practice 0/0 landings ( emergency only) using the synvis it's quite amazing how much utility you get from the flight path marker. We sort of did that. The runway at KAOH had a section that looked like concrete and the runway number painted white blended into the concrete background. I looked over at the G500 on Jerry's plane and confirmed the runway was the correct one. Sent from my iPad using Tapatalk Quote
ryoder Posted August 2, 2016 Report Posted August 2, 2016 On July 30, 2016 at 10:58 PM, rbridges said: You been flying much since selling the plane? I got checked out in a 182 for my BFR and flew helicopters a few times. Flew as a passenger with Greg for a while but 396 has had some maintenance issues and its in annual so not much flying. I miss that feeling of pulling the gear up manually on takeoff. I'm in a graduate program now in Space Studies so that is occupying my time. 1 Quote
smccray Posted August 2, 2016 Report Posted August 2, 2016 On August 1, 2016 at 11:11 AM, geoffb said: As I see it, these things are no more than a solid state alternative to a second, electric AI like a Castleberry or Lifesaver. For a similar price, we're hopefully getting a redundant attitude instrument with a better MTBF than and electric gyro. So, if you're like me and you have a pretty much all vacuum airplane with a Brittain autopilot, you can dump the turn and bank, replace it with the G5 or Quattro per the advisory circulars and add some valuable redundancy with battery backup. Agree- and nothing that I'm aware of would preclude you from putting the G5/ D10 in the top row center position of the 6 pack and moving the KI-256 to the bottom row left position. The G5/ D10 provides the ball, and you have 2 attitude indicators. Do I have that wrong? The added benefit is that there's clearly a trend towards allowing these instruments to grow in their capabilities although the path forward isn't clear. There has to be some future here but we'll see what it is... Biggest difference I see is that the Dynon displays heading from a magnetometer. The Garmin displays GPS ground track- there isn't a magnetometer available. Quote
NotarPilot Posted August 4, 2016 Report Posted August 4, 2016 On August 2, 2016 at 4:14 PM, smccray said: Agree- and nothing that I'm aware of would preclude you from putting the G5/ D10 in the top row center position of the 6 pack and moving the KI-256 to the bottom row left position. The G5/ D10 provides the ball, and you have 2 attitude indicators. Do I have that wrong? The added benefit is that there's clearly a trend towards allowing these instruments to grow in their capabilities although the path forward isn't clear. There has to be some future here but we'll see what it is... Biggest difference I see is that the Dynon displays heading from a magnetometer. The Garmin displays GPS ground track- there isn't a magnetometer available. I'm already contemplating installing one of these in the near future. I really like the size and display presentation of the Garmin G5 but doing more research I'm finding the Dynon D-10A seems to have more features such as magnetic heading (with the installed magnetometer) which gives magnetic heading, wind speed and direction. Now I'm really torn. Maybe I can put a G5 on the pilot side and a D-10A on the co-pilot side. Quote
MB65E Posted August 4, 2016 Report Posted August 4, 2016 Each time I cage my RC Allen I think of the G5!!!! Blue side up and level during IFR taxi checks are actually important with legacy gyros!! -Matt Quote
Hector Posted August 4, 2016 Report Posted August 4, 2016 As I see it, these things are no more than a solid state alternative to a second, electric AI like a Castleberry or Lifesaver. For a similar price, we're hopefully getting a redundant attitude instrument with a better MTBF than and electric gyro. So, if you're like me and you have a pretty much all vacuum airplane with a Brittain autopilot, you can dump the turn and bank, replace it with the G5 or Quattro per the advisory circulars and add some valuable redundancy with battery backup. Based on the pinout diagram for the Quattro, I suspect there's a whole lot more functionality built in than Sandia is using right now. But until the regulatory guidance changes, I don't think we'll see it turned on. That might be a problem given that your Brittain AP works off your TC gyro. Quote
donkaye Posted August 4, 2016 Report Posted August 4, 2016 On August 1, 2016 at 10:14 AM, aviatoreb said: Hmmmm! SO the ESI500 Genesis drives the autopilot? That would be nice, but no, it doesn't drive an autopilot. The G5 is a glorified Castleberry. I just don't understand what all the fuss is about. It's useless as a certified backup to glass. End of story for now. 2 Quote
gsengle Posted August 4, 2016 Report Posted August 4, 2016 The big deal and the fuss is that I believe the G5 *is* certified as a primary standalone AI. The reason most of us can't treat it that way is our attitude based autopilots... Sent from my iPhone using Tapatalk 1 Quote
jetdriven Posted August 4, 2016 Report Posted August 4, 2016 Just now, gsengle said: The big deal and the fuss is that I believe the G5 *is* certified as a primary standalone AI. The reason most of us can't treat it that way is our attitude based autopilots... Sent from my iPhone using Tapatalk You can move the gyro that drives the autopilot to the lower left spot and use the G5 of D10 in the center 1 Quote
gsengle Posted August 4, 2016 Report Posted August 4, 2016 You could do that I believe with the previous units too... Even though they were just standby. I'm saying the big deal is that these are certified for sole primary use. Matters more for a 172 than for us... For us it's a glorified Castlebery. But then again what do I know... Sent from my iPhone using Tapatalk Quote
jetdriven Posted August 4, 2016 Report Posted August 4, 2016 From someone with a vacuum gyro and a castleberry electric AI, yes I agree. It's a glass castleberry, not much more. Quote
gsengle Posted August 4, 2016 Report Posted August 4, 2016 But from the FAA standpoint it's a certified primary flight instrument for certified airplanes. Sent from my iPhone using Tapatalk Quote
jetdriven Posted August 4, 2016 Report Posted August 4, 2016 So is the 12VDC castleberry attitude gyro. But you must either have a vacuum secondary gyro or an electric with a battery backup. id be inclined to trust this more than the castleberry since it's a solid state but it isn't cheap so we roll on with the castleberry. Quote
gsengle Posted August 4, 2016 Report Posted August 4, 2016 Wasn't aware. But plenty of us are using backups that aren't certified for primary. I use a panel mounted Dynon pocket panel as a backup for instance. Sent from my iPhone using Tapatalk Quote
aviatoreb Posted August 4, 2016 Report Posted August 4, 2016 21 minutes ago, gsengle said: The big deal and the fuss is that I believe the G5 *is* certified as a primary standalone AI. The reason most of us can't treat it that way is our attitude based autopilots... Sent from my iPhone using Tapatalk Right - that is exactly where I am. I have a steam gauge panel and required electric turn coordinator a nice electric attitude indicator as an optional backup. So the G5 could be a replacement for my optional electric attitude indicator but I would be more excited to consider it if it did something more like svt or something. I would be very much more excited by it if it would serve as a primary replacement for my attitude based autopilot but it is not legally allowed even if in engineering terms it could. Quote
gsengle Posted August 4, 2016 Report Posted August 4, 2016 Well in engineering terms I don't think the product has been set up to drive the king autopilots yet unless it shares like G500 software under the covers... Sent from my iPhone using Tapatalk Quote
bradp Posted August 4, 2016 Report Posted August 4, 2016 There is a confusion / inconsistency in the marketing of the G5. The STC has a download code/key that prints the STC letter to make the instal legal. In the BT forum a garmin rep (Trek I think) said that a garmrin dealer needs to use their login to download the code. However, this is an A&P installable unit. Chief and spruce are selling them. So makes me wonder how your local A&P who's not a garmin dealer is supposed to print the STC? Quote
mike_elliott Posted August 4, 2016 Report Posted August 4, 2016 On 8/1/2016 at 0:59 PM, StevenL757 said: Psst...L-3 ESI500 Genesis. :-) From Fletcher at L3 a few months ago: The ESI-500 is also a great product but it does not have analog pitch and roll outputs. It does have a AHARS output on ARINC 429 so you could use a ARNIC 429 to analog converter. Your L3 dealer would need to do a little research on a converter as L3 does not manufacture one. Quote
