Plane was dropped off at Premiere Aircraft (Mooney Dealer) in Ft Lauderdale yesterday for the upgrade.  When I see it again, it'll have a 3 blade hartzell scimitar and 310 HP, up from 244.  Should be a hoot!
  • Like 6
Make sure your seatbelt is very tight before your first departure . . . Anthony can fill you in on what the upgrade is like, but he started with more than 244.
Hope your face survives the really bug grin!!
George, very happy for you.  You won't be disappointed.  Really looking forward to meeting you soon and seeing your ship after conversion.
Steve
My 310 upgrade was worth every penny and was just from 280HP to 310HP.
Looks like you fixed the sagging prop problem.  I know this because your plane looks identical to mine and your plane's in flight pics are my desk top :)
How did you correct it?
Driver
Driver
Yes...New lords mounts last year
George,
Do you prefer metal or plastic with that?
Thin bladed aluminum TopProp or composite?
Interested in your thought process related to...
- WnB.
- rotational inertia / flywheel effect.
- blade life issues.
- four blade prop from that European manufacturer.
- any way to avoid the step change between the smallish spinner and cowl design?
Not that you will need it, but...  Good luck with your install.  :)
Make certain they crank up your max FF. even if it is well within TCM specs now,
Advanced Pilot Seminars (APS) feel it should be 29.5 for very sound ENGINEERING reasons. This will drop your EGTs and CHT on takeoff.
It's rare to see one Eagle, much less two so I parked next to yours yesterday. Going in for annual and 310 HP mod too!
Sounds like a swarming. The stinging part comes when they hand you the bill. ;)
Same prop as on the Acclaim type S by chance, or the 7 kt slower scimitar?
As mentioned above 29.5-29.8 gph sea level takeoff FF. Make sure you get all 2700 rpm. When my mechanic was adjusting my rpm he came up to me afterwards and was still shaking. I guess he never had a plane pull itself along with the wheels locked and chirping down the taxi way:) On days when the temperatures are high I take off and climb with the low boost pump on. I have found on my plane with OAT above 76F that I will have a few run away EGT's from fuel vaporizing. The fuel pump keeps them all in line. Have fun, it's a great setup!
Very Cool!  Just wish they'd keep the cover on the plane.  its hot down there in FL!
I'll be sure to mention that to Ray at Premier,..Thx!
Fantastic!
I upgraded from a M20E to an Eagle more than a year ago. I got my M20S with the 310HP STC already.
I would not want to miss the acceleration and climb performance. T/o performance like the M20E, cockpit space and cruise speed of the Ovation.
The bill hurts until the check is cashed. You will enjoy the performance for many years!
  • 2 weeks later...
When it grows up, it will sprout the other two cylinders.
8 cylinders is so yesterday.  Everyone has 10 cylinders these days.
16 between all of my planes.  I'll have to down size.
