201er Posted June 27, 2013 Report Posted June 27, 2013 I expect a lot of bloodshed, this is an extremely controversial topic. I hope our renowned physicist can explain the forces acting on a still propeller at different angles and the harm they might bring. How do you leave your propeller when parked outside? Why? Quote
carusoam Posted June 27, 2013 Report Posted June 27, 2013 Which ever way it takes to keep birds from being comfortable on it, while not allowing water to settle into the seals. Now it's indoors, does it matter? -a- 1 Quote
John Pleisse Posted June 27, 2013 Report Posted June 27, 2013 I say, keep it covered in some way, at least the spinner, hub and blade shims. Some say this isn't smart because covers harbor moisture and promote corrosion. Quote
triple8s Posted June 27, 2013 Report Posted June 27, 2013 Outside? Two blade horizontal because if it rains moisture is going to pool up in the clamp/seal area of the hub. Why not turn it horizontal so water doesnt even get in? Another reason is the bottom blade is low, a careless ramp person may be able to get into the low blade with a towbar/tug. Quote
Alan Fox Posted June 27, 2013 Report Posted June 27, 2013 Who cares.... I have a prop pastie... Quote
AmigOne Posted June 27, 2013 Report Posted June 27, 2013 In one year my airplane will be parked outside - when it rains - maybe a day per month (and maybe less). If it rains hard I think that the water will get everywhere no matter what the position. So most of the times I'll leave it wherever it stopped. Quote
kerry Posted June 27, 2013 Report Posted June 27, 2013 When your engine stops it stops on the same compression stroke e.g.(cylinder #1 will be at top center each time you shut down). I randomly pull my propeller through differn't strokes after each shut down to keep wear on the cylinders and rings more even. Then I leave the prop in a horz position because it looks better. If you notice my avatar its in the vertical position. Oh well. Quote
Jeff_S Posted June 27, 2013 Report Posted June 27, 2013 My prop (3-blade) usually stops with the top blade vertical, although sometimes bottom vertical. I always rotate it to top vertical because otherwise the blade gets in the way of the Power Tow I use to push it back into the hangar. Even when I'm parked outside, I usually rotate it top vertical because it seems like this would just shed water better, and maybe be a slightly less- interesting bird perch. Quote
1964-M20E Posted June 27, 2013 Report Posted June 27, 2013 Propellers are for boats. OK so what do we call the big fan on the front of the plane? Quote
aaronk25 Posted June 27, 2013 Report Posted June 27, 2013 I leave it where ever it stops after ignition key is turned off and have a beer from the hanger fridge. Aaron Quote
N201MKTurbo Posted June 27, 2013 Report Posted June 27, 2013 If I need to move the airplane the prop goes horizontal so I can use the tow bar. If it is snowing outside I make the prop vertical so the snow melt can run out and not freeze in the spinner. Other then that I don't care. The engine always stops with the prop at 2:00. Quote
bumper Posted June 27, 2013 Report Posted June 27, 2013 I always remove the prop and put it in the plane for safe storage. This keeps the birds from making a mess but is quite bothersome when stopping for a burger. Sometimes I'll get lazy and not do it if I'm only stopping for a couple of hours. My expense for safety wire is horrendous. 2 Quote
Joe Zuffoletto Posted June 27, 2013 Report Posted June 27, 2013 Top vertical (see my avatar) to keep it out of the way of towing devices. Quote
gsengle Posted June 27, 2013 Report Posted June 27, 2013 Well when I used to have a 2 bladed prop, I'd leave it vertical, so rain/snow would drain out the bottom of the spinner... Â Now, I have to leave the top blade vertical or I cant use the tow bar... Â g Quote
dcrogers11 Posted June 27, 2013 Report Posted June 27, 2013 When I'm at home, in the hangar, it stays where it stopped. Usually 10:00/4:00. I commute to work in my plane and store it in a community hangar with a bunch of "high-wingers" so I rotate it to a horizontal position so that there's no chance of them hitting my prop with a wing. Hopefully, they're not that close to me, but you never know.  Don Quote
RJBrown Posted June 27, 2013 Report Posted June 27, 2013 2 blade horizontal. Out of the way of the tow bar. No long white stripes from a sitting bird. Now to find a way to keep the birds off the blade antennae on the vertical stab. With the Rocket I would feather it occasionally to exercise that feature. Sometimes just to see if I got an odd look. That something is different but I can't say what look can be amusing. Quote
fantom Posted June 27, 2013 Report Posted June 27, 2013 Horizontal for my two blader, so I can hit my hard head on it every now and then. 1 Quote
jlunseth Posted June 27, 2013 Report Posted June 27, 2013 I voted horizontal, not because I do anything with the prop, I just leave it where it stops. The FBO that stores it moves it to horizontal so they can tow, and that is where it stays. Quote
NotarPilot Posted June 28, 2013 Report Posted June 28, 2013 I think horizontal just looks nicer. Quote
sreid Posted June 28, 2013 Report Posted June 28, 2013 If I need to move the airplane the prop goes horizontal so I can use the tow bar. If it is snowing outside I make the prop vertical so the snow melt can run out and not freeze in the spinner. Other then that I don't care. The engine always stops with the prop at 2:00. You must have to vary your takeoff time to account for varying winds. Quote
