I saw in some old posts that overnightsupply.com had reasonably priced probes, alas the website is no longer there?
Does anyone have a CB source for K style CHT/EGT probes? I need four of each and they are quite pricey!
I would be suspicious of CB probes. My experience with the JPI probes is that they last a long time and don't cause problems if installed according to the instructions. I have over 1200 hours on the EGT probes. CHTs should last forever,
Best street price is $104.50.    I can do $90/each for new ones, and if you really want to try used ones I could probably put together a set for much less.
Aerodon supercub180@gmail.com
I missed those?! has anyone had success with the universal probes?
not if you want accurate temp indications.
There are J and K type probes and then there are grounded and ungrounded versions of these. Only the correct probe type will work properly on an EDM.
Don’t waste your $ on the wrong type.
