WAFI Posted April 6, 2023 Report Posted April 6, 2023 I'm not as concerned as my other issue that is going on but I wanted to get some feed back on this situation. After any length of flight I get a small puddle of Fuel/Oil mixture dripping from the 90 degree fitting underneath my motor. Thoughts??
N201MKTurbo Posted April 6, 2023 Report Posted April 6, 2023 I lay a blue paper towel there. If you are outside, don't worry about it it isn't your pavement. That is the sump drain, it is there to drain fuel that accumulates in the intake plenum. When you shut down your engine, the fuel injection lines are full of fuel. The heat of the engine causes this fuel to vaporize and it forces the fuel out of the injector nozzles. It runs down the intake risers into the plenum and out the sniffle valve, which is the 90 degree fitting you are pointing to. It is all working as designed. 5
N201MKTurbo Posted April 6, 2023 Report Posted April 6, 2023 As far as oil dripping off the outside of the sniffle valve, it is the lowest point on the engine. Lycomings leak oil. It all runs down the engine and eventually makes it to the sniffle valve and drips. I've seen a few pictures of absolutely dry Lycomings. They are the outliers... 3
WAFI Posted April 6, 2023 Author Report Posted April 6, 2023 10 minutes ago, N201MKTurbo said: I lay a blue paper towel there. If you are outside, don't worry about it it isn't your pavement. That is the sump drain, it is there to drain fuel that accumulates in the intake plenum. When you shut down your engine, the fuel injection lines are full of fuel. The heat of the engine causes this fuel to vaporize and it forces the fuel out of the injector nozzles. It runs down the intake risers into the plenum and out the sniffle valve, which is the 90 degree fitting you are pointing to. It is all working as designed. Thanks for the feedback!! Now onto my bigger issue!
A64Pilot Posted April 7, 2023 Report Posted April 7, 2023 21 hours ago, N201MKTurbo said: I've seen a few pictures of absolutely dry Lycomings. They are the outliers... The few that I have overhauled were absolutely dry. ‘For a few years, then they would begin to seep in a couple places, I believe at least seepage is going to occur and seeps later turn into leaks.
Yetti Posted April 8, 2023 Report Posted April 8, 2023 You probably need to lean more when you land. I don't change the mixture from cruise to land. On rollout I will half the mixture. 1
Hank Posted April 8, 2023 Report Posted April 8, 2023 23 minutes ago, Yetti said: You probably need to lean more when you land. I don't change the mixture from cruise to land. On rollout I will half the mixture. On rollout, I pull the mixture back to where I taxi, about 2/3 towards Idle / Cutoff. With a quadrant, it's easy to judge the position. 2
Yetti Posted April 8, 2023 Report Posted April 8, 2023 2 minutes ago, Hank said: On rollout, I pull the mixture back to where I taxi, about 2/3 towards Idle / Cutoff. With a quadrant, it's easy to judge the position. I probably should have said half the mixture from where it was at cruise. Yes on the quadrant. It's probably an inch up from off at that point.
carusoam Posted April 8, 2023 Report Posted April 8, 2023 I use the FF indicator… at idle. Lean until rough, then enrich. Mixture full in (IO550) FF = 4gph Mixture set for taxi FF = 2gph The IO360 is probably near 2/3 these values… Best regards, -a- 1
