bradp Posted November 3, 2022 Report Posted November 3, 2022 The Lycoming part is 37A-19773-376. It is 7/16 in thick at the greatest (outer circumference). Its outer circumference is 35 5/8". What's sitting on my plane now is the Lycoming. It is made by Gates but has a part number that does not reference to any other Gates PN. The closest sized Gates 7/16" belts are 7355, which measures 36+7/16" and 7345, which measures 35+3/8" outer circumference. They are different in that the Lycoming has an outer fiberglass backing and an internal fiberglass reinforcement, whereas the Gates auto belts are rubber with an internal fiberglass reinforcement only. YMMV. 2 Quote
carusoam Posted November 4, 2022 Report Posted November 4, 2022 Let’s invite @M20Doc (alternator belt question) -a- Quote
N201MKTurbo Posted November 4, 2022 Report Posted November 4, 2022 What’s wrong with using the lycoming belt except the price? I was helping a guy do a prop change and asked where he got the belt. He said he read online that it was the same as the Lycoming belt. I made him buy a Lycoming belt. Quote
carusoam Posted November 4, 2022 Report Posted November 4, 2022 What part of the world does Gates build their belts in? If it’s China… they are still trying to figure out their Covid plan without buying vaccines from other countries… Best regards, -a- Quote
N201MKTurbo Posted November 4, 2022 Report Posted November 4, 2022 1 hour ago, carusoam said: What part of the world does Gates build their belts in? If it’s China… they are still trying to figure out their Covid plan without buying vaccines from other countries… Best regards, -a- Gates used to make all their belts in Denver. I don’t know if that is still the case or not. 1 Quote
N201MKTurbo Posted November 4, 2022 Report Posted November 4, 2022 I just looked it up Gates has most of its manufacturing facilities in the USA with a few plants in Mexico. Quote
Guest Posted November 4, 2022 Report Posted November 4, 2022 On my homebuilts I use a NAPA belt, on everything else I use the Lycoming or Continental belt and change them every 10 years to coincide with out 10 year propeller overhaul. Never had one fail under this program. Quote
vorlon1 Posted November 4, 2022 Report Posted November 4, 2022 Are both of these belts within the tension adjustment range of the alternator? I would guess so, but it would be great to know for sure. Quote
A64Pilot Posted November 4, 2022 Report Posted November 4, 2022 This is not something that the tiny bit of money saved is worth it. There IS a difference in the Lycoming belt. Gates does make some good belts, green stripe come to mind, but the belt they build to Lycomings spec is worth it. 2 Quote
PT20J Posted November 4, 2022 Report Posted November 4, 2022 According to Lycoming SI 1129, they use 3/8” or 1/2” belts. Quote
