Jpravi8tor Posted September 23, 2022 Report Posted September 23, 2022 I got all new engine hoses, getting them off took 2 full days! getting them on forget about it! I have removed all cowlings all scat hoses even the exhaust and still don't have enough room for my meathooks. I'm think i should have removed the engine it would have been easier! 1
Shadrach Posted September 23, 2022 Report Posted September 23, 2022 The gauge lines are bit of a PITA to connect to the engine as I recall, but the line running from the governor to he prop control fitting is the most time consuming to route and secure. Still, two days seems like an awful lot. Admittedly, it’s much easier to contend with some of the hoses with the engine on a hoist.
N201MKTurbo Posted September 23, 2022 Report Posted September 23, 2022 If you loosen the lower motor mount bolts so the engine can pivot, grab the engine with a hoist. Remove the top motor mount bolts (the 1/4 inch ones), you can pivot the engine down a bit. Just be mindful of the control cables. 1
Don Gates Posted September 24, 2022 Report Posted September 24, 2022 14 hours ago, Jpravi8tor said: I got all new engine hoses, getting them off took 2 full days! getting them on forget about it! I have removed all cowlings all scat hoses even the exhaust and still don't have enough room for my meathooks. I'm think i should have removed the engine it would have been easier! There is a pair of hoses on my C that go from the accessory case down to the cowl mounted oil cooler. They are secured to the firewall with a pair of “butterflied” adel clamps. Getting those adel clamps loose is difficult. Getting them back on without tilting the engine mount or pulling the engine entirely is well nigh impossible. When I installed mine during the engine change I had bad dreams about those oil lines being too short or too long, and in the end I would have liked them to be .25 inch shorter, but it worked out. Thankfully I used the expensive Teflon hose that has a longer service life than standard Aeroquip hose because I dread ever having to do anything with them again…. 1
Jerry 5TJ Posted September 24, 2022 Report Posted September 24, 2022 1 hour ago, Don Gates said: There is a pair of hoses on my C that go from the accessory case down to the cowl mounted oil cooler. They are secured to the firewall with a pair of “butterflied” adel clamps. Getting those adel clamps loose is difficult. Getting them back on without tilting the engine mount or pulling the engine entirely is well nigh impossible. I still vividly recall changing those oil cooler hoses in my E model, even though it was close to 30 years ago. It was awful. 1
Jpravi8tor Posted September 24, 2022 Author Report Posted September 24, 2022 I’m currently hoping to wake up from this nightmare!
mike_elliott Posted September 24, 2022 Report Posted September 24, 2022 If it were easy, anyone could be a Mooney Mechanic 1
kerry Posted September 24, 2022 Report Posted September 24, 2022 If your battery box is up front, then it needs to be removed to get access to the oil cooler hoses.
Guest Posted September 24, 2022 Report Posted September 24, 2022 23 hours ago, Jpravi8tor said: I got all new engine hoses, getting them off took 2 full days! getting them on forget about it! I have removed all cowlings all scat hoses even the exhaust and still don't have enough room for my meathooks. I'm think i should have removed the engine it would have been easier! Sounds like you’re spending too much time on the first letters in your signature and not enough on the last letters. It’s a Mooney, they have parts that are a challenge to work on, but not impossible.
Jpravi8tor Posted September 24, 2022 Author Report Posted September 24, 2022 2 minutes ago, M20Doc said: Sounds like you’re spending too much time on the first letters in your signature and not enough on the last letters. It’s a Mooney, they have parts that are a challenge to work on, but not impossible. true, true there once was a time when all I did was work on piston aircraft but now at age 60 working on the ramp in the sun in Georgia(it was 92 Degrees the other day) can be challenging add in the part where the plane is a mooney and bam instant can of whoopass! I will overcome and one day get this bird in a hangar but until then I shall remain humbled by my Mooney! 1
A64Pilot Posted September 26, 2022 Report Posted September 26, 2022 Adel clamps are a whole lot easier to deal with if you first clamp them shut with needle nose vise grips with an awl or phillips screwdriver in them to hold alignment, wrap safety wire around the base and tighten, with them on the hose of course, then line them up and put the screw through, for double clamps attached to each other it really makes life easier. 3
Skates97 Posted September 26, 2022 Report Posted September 26, 2022 40 minutes ago, A64Pilot said: Adel clamps are a whole lot easier to deal with if you first clamp them shut with needle nose vise grips with an awl or phillips screwdriver in them to hold alignment, wrap safety wire around the base and tighten, with them on the hose of course, then line them up and put the screw through, for double clamps attached to each other it really makes life easier. When my AP/IA taught me this trick it was life changing.
A64Pilot Posted September 26, 2022 Report Posted September 26, 2022 Just now, Skates97 said: When my AP/IA taught me this trick it was life changing. I think I was working on aircraft for a year or two until I saw it done, it’s like the Ajax on a screwdriver trick or using vise grips to remove panel screws or cutting the head on a panel screw making it a slotted screw. Things you pick up after school
Guest Posted September 26, 2022 Report Posted September 26, 2022 1 hour ago, A64Pilot said: Adel clamps are a whole lot easier to deal with if you first clamp them shut with needle nose vise grips with an awl or phillips screwdriver in them to hold alignment, wrap safety wire around the base and tighten, with them on the hose of course, then line them up and put the screw through, for double clamps attached to each other it really makes life easier. I tell my apprentices to develop some finger strength for holding Adel clamps. No need to destroy them while installing them. You could also use the Cirrus style of Adel clamp with the locking feature, they hold themselves together making assembly of multiple clamps simpler.
jaylw314 Posted September 26, 2022 Report Posted September 26, 2022 They're $35 at Aircraft Spruce 1 1
EricJ Posted September 26, 2022 Report Posted September 26, 2022 I have one of these that works pretty well to hold adel clamps in some cases, but in many cases with limited access it can be hard to find something that works. https://aircraft-tool.com/shop/detail.aspx?id=HANDECLAMP-1 2 1
N201MKTurbo Posted September 26, 2022 Report Posted September 26, 2022 36 minutes ago, EricJ said: I have one of these that works pretty well to hold adel clamps in some cases, but in many cases with limited access it can be hard to find something that works. https://aircraft-tool.com/shop/detail.aspx?id=HANDECLAMP-1 Nice find, I'll have to get one of those.
jamesm Posted September 27, 2022 Report Posted September 27, 2022 or a couple of wraps of 0.020 safety wire around the adel clamp works some times works.
Mkruger2021 Posted September 27, 2022 Report Posted September 27, 2022 The tool above is great which I used to do the same PITA job you just described. Also as a jet mechanic, we use a good old pair of reverse safety wire pliers on the Adel clamp. Then put it in reverse to remove the wire. Use the awl to align it all up before hand! hope that helps.... 1
BKlott Posted September 29, 2022 Report Posted September 29, 2022 On 9/24/2022 at 9:45 AM, Jerry 5TJ said: I still vividly recall changing those oil cooler hoses in my E model, even though it was close to 30 years ago. It was awful. 30 years?
carusoam Posted September 29, 2022 Report Posted September 29, 2022 Crummy memories can last through a lot of trauma…. Best regards, -a-
47U Posted September 30, 2022 Report Posted September 30, 2022 The Clamp Keeper is good for tight spaces. It’s works with both #8 and #10 threaded fasteners. Pricey, though… a 10-spot and change per, but sold only in lots of 5 by Monroe Aerospace. I’m passing my extras out to my IA and fellow knuckle-draggers.
MooneyMitch Posted September 30, 2022 Report Posted September 30, 2022 30 minutes ago, 47U said: The Clamp Keeper is good for tight spaces. It’s works with both #8 and #10 threaded fasteners. Pricey, though… a 10-spot and change per, but sold only in lots of 5 by Monroe Aerospace. I’m passing my extras out to my IA and fellow knuckle-draggers. Yep!!
cliffy Posted October 15, 2022 Report Posted October 15, 2022 Next time the engine is off put rivnuts in the firewall.
