amillet Posted March 7, 2021 Report Posted March 7, 2021 Replaced the electric fuel boost pump today. The original motor installed in 1996 suddenly began sounding sick; slow and irregular pulsing. Electric flap motor died 18 months ago. Is 20 +/- years the expected useful life of these small electric motors? Quote
carusoam Posted March 7, 2021 Report Posted March 7, 2021 That would be tough to put a finger on... Lets invite @M20Doc to the conversation... (small electric motor life, flaps, and fuel pumps) Best regards, -a- Quote
N201MKTurbo Posted March 7, 2021 Report Posted March 7, 2021 The motors should last forever. The bearings can dry up and cause problems. Most of the commutators and brushes are so over built they should last thousands of hours. If the bearings go south the motor has to work harder and could burn out the armature. 1 Quote
carusoam Posted March 7, 2021 Report Posted March 7, 2021 Somewhere along the way... we calculated the total number of hours the flap motors and gear motors actually run... Its minuscule compared to trying to wear one out in a year... Best regards, -a- Quote
Guest Posted March 7, 2021 Report Posted March 7, 2021 There seems to be no easy answer, some motors last amazing long lives, other relatively short ones. Just like airplane engines I suppose. Clarence Quote
A64Pilot Posted March 7, 2021 Report Posted March 7, 2021 (edited) Those Weldon pumps only last about 300 hours in operation before the brushes wear out. They were reportedly working on a brushless motor but by the time of my retirement they hadn’t come out. (three years ago) I suspect they may never go brushless, but if they did that would pretty much eliminate motor wear as the life limit and make it pump wear, which seems to be minimal. So how many years does it take to accumulate 300 hours at maybe 10 min per flight? The pumps used on an S2R-H80 appear to be almost identical. http://www.kathrynsreport.com/2019/09/loss-of-engine-power-total-thrush-s2r.html Oh, and the pump in that accident was a red herring, it had nothing to do with the accident. Edited March 7, 2021 by A64Pilot Quote
Tim Jodice Posted March 7, 2021 Report Posted March 7, 2021 Is 20 years that bad? That seems like a reasonable life for a electric pump. Quote
LANCECASPER Posted March 7, 2021 Report Posted March 7, 2021 16 hours ago, amillet said: Replaced the electric fuel boost pump today. The original motor installed in 1996 suddenly began sounding sick; slow and irregular pulsing. Electric flap motor died 18 months ago. Is 20 +/- years the expected useful life of these small electric motors? Not necessarily. The Mooney still senses that there's some money remaining in your wallet and wants to help relieve you of it. 1 1 Quote
Mooney217RN Posted March 8, 2021 Report Posted March 8, 2021 These Weldon pumps can and do go bad. Usually it's the seals that go, but I had one in my E Model fail outright. That said, they do last a long time. They have weep valves (see picture) that tell you when the seals are going. If there is any sign of fuel coming out of that valve, it's time to replace the pump. 1 Quote
