So my AP found a crack where the flap arm mounts in the belly of the plane. I’m super worried this means the airframe is done for. Anyone with experience take a look at the pics and give any suggestions? Is this fixable or is the plane destined for the scrap heap?
OMG you have no idea how much of a relief that is to hear.
I was sick to my stomach thinking about the alternative.
This happens by forgetting to raise the flaps after takeoff . . . A situation usually found while wondering why cruise speed is so low.
Also can be caused by dialing in flaps prior to correct flap speed.
I love MooneySpace! :D
No problem, mine was repaired also before I bought it from Sabremech.
good pictures here and info about the ‘access panel’
-Don
Yeah I had that sb done as well.  In addition to adherence to proper flap speeds, make sure passengers are well briefed many times not to step on the flaps as they climb up!  Or just put them full down during preflight so they are hard to step on.  Make sure you have desired flap setting before takeoff.
Installing the doubler is relatively extensive surgery.  It would be best if your A&P had done one before but not required.  They have to pull up the baggage floor to get in there.  Good luck!
Edited by Ragsf15e
Sometimes, the crack can be invisible.  Try putting the flaps all the way down, then inspecting.
 The sTub spar that has the flaps attached to it....
Lets invite @M20Doc to have a look...
To see if the doubler can be used in this case...  crack vs. missing piece...
The good news stands, it can be fixed... :)
9 minutes ago, carusoam said:
LThere is a name for that spar that has the flaps attached to it....
What, the sub spar? At some point un the 60s the flap attachment was changed. I don't know if my 1970 C has a flap sub spar or not . . . . But Clarence probably knows.
It's actually a stub spar and it is a component of all Mooney metal wings. The main spar, located forward of the wheel wells, runs the full span of the wing and carries most of the load. There is also a lighter spar at the aft edge of the wing that does not run the full span (hence the term "stub"). This is the attachment point for the flaps and the original design wasn't beefy enough to prevent flap loads from causing cracks.
Skip
The repair is straight forward for any maintainer with basic sheet metal skills and some basic tools.  The baggage compartment floor doesn’t need to be removed completely.  Remove enough rivets roll the skin forward to access the top skin for riveting the doubler.
The service bulletin is for all Mooneys only into 1968.  The flap attachment must have been changed during that time.
For C models with electric flaps, the actuator is mounted on a bulkhead and attaches differently.  I have never seen anyone with electric flaps on a short body have this issue.
Edited by Mooneymite
One more reason to like electric flaps!
Clarence if you ever get bored you should write a book, "maintaining your mooney".  I would buy the first copy.  I have been working on mooneys for a long time and you still bring up new stuff I have not seen before.
Mark
  • Like 6
That really is not a bad idea. Sell online subscription with pic/videos and maybe tip of the month - just have someone take  videos with a good camera — monthly subscription fee or yearly...
-Don
Mark
It’s time for such.
Mitch did a great job producing(?) the Boots / Mooney video...
Could be time to start planning the next project... :)
1,000 details every Mooney owner wants to know...  *
at some time during their ownership...
Our fleet certainly deserves this.  This would be a great asset to aircraft mechanics.
You’re very kind Anthony. I must give credit where credit is due. Boots concept, filming and production was a labor of love from myself and Jolie Lucas.
I recently did one , I removed the bottom skin below the actuator , for access , you have to remove the trim and rudder , elevator control rods , for access to buck the rivets , Took me about 12 hours work , Fairly straight forward.... Kit was about 200 dollars from Mooney...
I just called my closest MSC (air-mods) to have this SB (M20-217) done on my plane as well.  They are looking into the availability of the doubler kit from Mooney.  I hope its in stock.  I'm hoping that the one pc belly as well as having the interior out will help the repair go a bit faster for them.  We'll see...
I'll be relieved to have one more item off my squawk list.
