N177MC Posted April 12, 2020 Report Posted April 12, 2020 The mains on a late model M20J that I maintain lean rather significantly inwards, making it look bow-legged. I have checked the rigging but found nothing amiss . What am I missing ? Thanks! Quote
RLCarter Posted April 12, 2020 Report Posted April 12, 2020 Nothing, unless there is a lot of wear on the gear allowing it to go over center too far... Take a look at an A36 Bonanza, they are really bow legged Quote
Guest Posted April 12, 2020 Report Posted April 12, 2020 It’s not unusual, many Mooney gears don’t sit square to the ground. There is also no means to adjust/ correct this. Clarence Quote
cbarry Posted April 12, 2020 Report Posted April 12, 2020 I’m curious if you still notice the same amount of “bow-leggedness” when it’s up on jacks and if you have any obvious slack In the gear or gear actuator tubing? Quote
skykrawler Posted April 12, 2020 Report Posted April 12, 2020 I wonder if that airplane is planning to taxi with the nose wheel chocked? Quote
takair Posted April 12, 2020 Report Posted April 12, 2020 When the gear is up, do they go all the way into the well? As RL said, the over-center links could be worn. Mine had gotten so bad it was hard to set the tension and the gear were not going up all the way. Replacing the links corrected things. I think it can contribute to the look in the picture, even if not 100%. Quote
N177MC Posted April 12, 2020 Author Report Posted April 12, 2020 Everything else is fine, wheels retract properly, doors are tight, etc. Haven't noticed this particularly when on the stands, will check next time. The plane is chocked because it's performing a full throttle power check following engine overhaul. Thanks for the input ! 1 Quote
Yooper Rocketman Posted April 12, 2020 Report Posted April 12, 2020 19 minutes ago, N177MC said: The plane is chocked because it's performing a full throttle power check following engine overhaul. Oh boy. Obviously everything turned out okay but I would never chalk the nose wheel for a run up. Chalk the mains. I've seen too many pictures of collapsed nose wheels from run ups with gear that was slightly worn or out of adjustment (other makes, not necessarily Mooney). Tom 2 2 Quote
N201MKTurbo Posted April 12, 2020 Report Posted April 12, 2020 They were originally straight. There was an AD back in the 70s that replaced the overcenter links and made them lean in. https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/AOCADSearch/022EF974FDE32DBA86256A3B006FA1EA?OpenDocument Quote
wcb Posted April 12, 2020 Report Posted April 12, 2020 I do not know about anyone else or if it is a problem since I am PPL only and there are so many other good qualified people on here. But, it certainly appears in the picture that the outside tubular structure on the port side is bent. Look at the distance at the bottom of the both parts of the tubular structure the width is significantly different. 1 Quote
carusoam Posted April 12, 2020 Report Posted April 12, 2020 +1 on nose wheel safety issue... it is designed to fold back... the mains are more secure in that direction... they fold sideways... Mooney main legs are hard to make judgements about as they don’t sit vertically.... There is at least one thread around here where many people have taken pics of the angle of the gear... but that is hard to make judgements from as well... lots of lens angle and distance get in the way... It may help to see another Mooney in the wild... Best regards, -a- Quote
N177MC Posted April 12, 2020 Author Report Posted April 12, 2020 2 hours ago, wcb said: I do not know about anyone else or if it is a problem since I am PPL only and there are so many other good qualified people on here. But, it certainly appears in the picture that the outside tubular structure on the port side is bent. Look at the distance at the bottom of the both parts of the tubular structure the width is significantly different. Nope nothing bent. BTW, I am an experienced A&P/IA . Quote
N177MC Posted April 12, 2020 Author Report Posted April 12, 2020 (edited) 32 minutes ago, carusoam said: Mooney main legs are hard to make judgements about as they don’t sit vertically.... There is at least one thread around here where many people have taken pics of the angle of the gear... but that is hard to make judgements from as well... lots of lens angle and distance get in the way... Indeed, it's not easy to get the angles and POV just right. That said, believe me there is a positive 3° to 5° camber from vertical, on both gear legs. Edited April 12, 2020 by N177MC Quote
MooneyMitch Posted April 12, 2020 Report Posted April 12, 2020 8 hours ago, N177MC said: The mains on a late model M20J that I maintain lean rather significantly inwards, making it look bow-legged. I have checked the rigging but found nothing amiss . What am I missing ? Thanks! The photo appears to have some irregularity issues. Things aren't always as they appear...... Quote
Awful_Charlie Posted April 13, 2020 Report Posted April 13, 2020 I'm pretty sure if you take a couple of steps to the right and look straight down the aircraft, it will look as though both legs are canted inwards, and if you move further to the right then the starboard leg will look 'wrong' and the port leg 'correct'. It will also change if you make the wings horizontal in the picture! 1 Quote
Guest Posted April 16, 2020 Report Posted April 16, 2020 You could just park the plane on a level piece of asphalt, then use a large carpenter’s square to check the 2 wheels to see how out of square they are. Clarence Quote
MooneyMitch Posted April 17, 2020 Report Posted April 17, 2020 The photo of the left main gear area is horribly inaccurate and highly distorted. Look at the inside edge of the gear area. It’s wildly mishapened, making the gear structure look bowed. False photo. Quote
PT20J Posted April 17, 2020 Report Posted April 17, 2020 Are the tires wearing evenly across the tread? Quote
