I flew a bunch of instrument approaches this weekend for my currency (never a problem in Seattle) and upon landing at KPAE I cleared the active and got taxi clearance in front of waiting Horizon E175 by the terminal.
Engine stumbled and basically stopped while I was thinking I might need assistance and they'll be pissed for me blocking them. I manage to keep it going with electric fuel pump and taxi to the hangar. Engine is IO360-A1A with almost new Tempest LW15473. Pump was replaced less then 2y ago and has 98h! This should really not fail so soon.
What are your experience and should I just ordered the same pump again?
I've read about high fuel pressure on some Lycoming pumps and would like to avoid that, having EI CGR30 engine monitor that will be flashing and turn red.
Also, what is the reasonable time to install these? I seem to remember it took a while last time as my IA had an access problem on my M20F.
Regards,
I had my mags out for 500 hour inspection and went ahead and replaced the pump because I could get to it.  I think it would be a tough job with them in.  Spruce had them in stock but. Now I’m wondering what brand I got.  I think the new pump from lycoming was about the same cost as the tempest rebuilds.
I bought the rebuild but should have just got new as they are $50 more or so.   Replaced with the mags on.   had to sacrifice a 5/16 allen wrench.   About 4 hours to replace.   About 6 hours the first time.
Interesting.  My pump leaks just a little bit of oil, but my mechanic suggested they generally last full 2000 hours + until overhaul.  I haven’t pushed him to mess with it.
Are you guy replacing them preemptively?
Before you condemn the pump, check the fuel lines upstream of the pump. If a fitting came loose or a tube cracked so the pump will suck air, it will quit pumping fuel.
  • 1 month later...
You said you replaced the fuel pump without removing the mag.   Do you have any advice or hints?  Thanks.
I sacrificed a 5/16 allan wrench about 2" long.  Then use a socket and drive to turn it.    The key is to get the plunger in the most up position.  Turn prop and feel plunger with finger.   Be able to work by feel not by sight.
Thank you Yeti.  I will try that tomorrow.  FYI we were both born on Earth Day!
Or Hitler's Birthday :-(
