gsxrpilot Posted October 28, 2019 Report Posted October 28, 2019 2 hours ago, xavierde said: For that you need the JPI "box", right? Yes/maybe... Is your 700 enabled for data memory? Some are some aren't. If it is enabled, it will likely have that port that @jaylw314 describes. Look for that port somewhere on the panel. It might be behind the panel. You'll need the JPI cable to connect to that port. To use the cable, you'll either need a laptop with a 9-pin serial port or the JPI box. If using a laptop, download the data from the JPI to the laptop, then upload the file to SavvyAnalysis. If using the JPI box, down load the data from the JPI to a USB stick, then transfer the file to your computer, then upload to Savvy Analysis. 1 Quote
Vno Posted October 28, 2019 Report Posted October 28, 2019 I had a similar problem with my JPI 700 on Not being able to download data. Get the serial number of it and give JPI tech support a call. One they can tell if it has ever been in for service or what the latest update was done to it. Second, they can walk you through a menu process to turn on the data monitoring, which might work. If not they can give you a RMA and price to send in and upgrade. Mine was around $350 which gave the latest software and a USB cable installed. Well worth it. I did have to send it in since it was an older unit and had never been upgraded. Brian 1 Quote
tmo Posted October 29, 2019 Report Posted October 29, 2019 In lieu of a DB9 serial port, which could be hard to find on a modern laptop, one can use a USB dongle with a DB9 connector; the standard is called RS232. Quote
jkarch Posted October 31, 2019 Report Posted October 31, 2019 If the cylinder in the back is hot then it could be a baffling issue if the EGTs are uniform Quote
xavierde Posted November 3, 2019 Author Report Posted November 3, 2019 So I managed to do some investigating today and believe that I found the EDM700 port: 1 Quote
xavierde Posted November 3, 2019 Author Report Posted November 3, 2019 (edited) And removed both upper and lower cowlings to have a look at the probes. Here are cylinders #2, 4 and 6. #2 seems to be set up at a different place and I believe the other cable is the OEM probe still showing on the old CHT gauge. Edited November 3, 2019 by xavierde Quote
Guest Posted November 3, 2019 Report Posted November 3, 2019 38 minutes ago, xavierde said: And removed both upper and lower cowlings to have a look at the probes. Here are cylinders #2, 4 and 6. #2 seems to be set up at a different place and I believe the other cable is the OEM probe still showing on the old CHT gauge. Cylinder #2 is using a spark plug gasket thermocouple, they tend to over read, cylinders 4&6 are using standard JPI bayonet thermocouples. Clarence Quote
xavierde Posted November 4, 2019 Author Report Posted November 4, 2019 I guess the only way to get rid of that would be to get a JPI that's primary, allowing me to remove that probe and get consistency across all 6 probes. Quote
carusoam Posted November 4, 2019 Report Posted November 4, 2019 59 minutes ago, xavierde said: I guess the only way to get rid of that would be to get a JPI that's primary, allowing me to remove that probe and get consistency across all 6 probes. There is an improvement for the ship’s /JPI CHT challenge... JPI makes a different probe that is worth considering... Instead of putting the gasket probe under the spark plug... they have a smaller one that fits under the TC well hardware. Placing it closer, but still a different T then the actual well... more accurate, but still imperfect... Or go primary engine monitor for a bunch more AMUs... Also, their used to be a plug for the hand held mike there? Next to the JPI data socket... The regular nuts on the instrument panel can be fancied up by using some acorn nuts... PP thoughts only, not a mechanic... Best regards, -a- Quote
jaylw314 Posted November 4, 2019 Report Posted November 4, 2019 1 hour ago, xavierde said: So I managed to do some investigating today and believe that I found the EDM700 port: Holy heck, I could have gone years without noticing that! Quote
Guest Posted November 4, 2019 Report Posted November 4, 2019 2 hours ago, xavierde said: I guess the only way to get rid of that would be to get a JPI that's primary, allowing me to remove that probe and get consistency across all 6 probes. This is the thermocouple Anthony is referring to. It goes under the factory thermocouple. Clarence Quote
carusoam Posted November 4, 2019 Report Posted November 4, 2019 Clarence, you are the best! Best regards, -a- Quote
Bob_Belville Posted November 4, 2019 Report Posted November 4, 2019 I wonder if all those CHTs aren't considered pretty high... but I'm comparing to my NA Lycoming IO360... Apples and oranges? Quote
xavierde Posted November 4, 2019 Author Report Posted November 4, 2019 18 minutes ago, Bob_Belville said: I wonder if all those CHTs aren't considered pretty high... but I'm comparing to my NA Lycoming IO360... Apples and oranges? I've heard the same thing from a few J owners. My source for engine parameters is this article: http://www.mooneypilots.com/mapalog/M20K252_evaluation_report.htm I'm still learning to run this engine properly though so I might be wrong to trust these recommendations. 1 Quote
gsxrpilot Posted November 4, 2019 Report Posted November 4, 2019 3 hours ago, xavierde said: I've heard the same thing from a few J owners. My source for engine parameters is this article: http://www.mooneypilots.com/mapalog/M20K252_evaluation_report.htm I'm still learning to run this engine properly though so I might be wrong to trust these recommendations. This is exactly the document I used and had printed out and on the seat next to me when I picked up my 252 and flew it home for the first time. Then I installed a good engine monitor, an EDM900. I also attended the APS class. That and talking to M20K pilots here on MooneySpace who have a lot of turbo Mooney experience, changed my technique. I don't believe that document is a great way to manage the engine in a 252. 1 Quote
