A non-scientific poll on engine oil change interval practices
107 members have voted
  1. 1. On what frequency is your engine oil changed?
    • q 20 hours or less,
      0
    • q 20 - 30 hours,
      48
    • q 30 - 40 hours,
      26
    • q 40 - 50 hours,
      10
    • q 50 hours,
      12
    • q 4 months regardless of hours,
      2
    • Once a year regardless of hours.
      3
    • q 4 months or 50 hours, whichever comes first,
      6
    • No set calendar and/or hours schedule but when oil on dipstick looks like it needs changing.
      0
I'm curious about different practices out there as to oil change intervals and to see if any correlations can be made. Non-scientific poll simply out of curiosity!
It has changed for us.  We used to change oil when we had gone through a case of oil (6 qts for the change and 6 quarts added during use).  That was usually about 30-35 hours and the oil was black.  We did a top overhaul and now change every 50 hours or 4 months whichever comes first.  At present we have about 35 hours on the oil and have only used 3 quarts.
Bob
It works out to be about 25-30 hours for me... but really I change every 4 months or so.  Wish I was flying enough to be worried about the hours on the oil, not the time!
Where is the "when the light on the dash tells me to" option?
Prob on a Cirrus
I suspect most of the folks reporting changing oil regularly at <<50 hours are in this boat, the majority of the survey responses. I just changed mine for the first time because of reaching 50 hours at <4 months and felt  some pride in getting to pick that response :P
The oil and particularly the filter change are a pain - no one wants to do it more than necessary.
I use to do mine every 35 hours or 4 months but learning more about turbo aircraft, I now do it at 25 hours.
(TSIO-360-SB)
I am flying enough to change it almost every month (or two) so I stopped using the CamGuard.
I change the oil when it is time to add the second quart, generally 25-30 hours. (I add a quart around 12-15 hours, then when it is time to add another quart, I change the oil instead). I've done with is just about every engine I've owned. Although, I have 17 hours since the last oil change and it isn't time to add even the first quart yet,
It’s the screen that’s a pain. Lycoming says to do it at least once a year.
-Robert
Ken,
which engines do you have?  IO550s?
There is something near magical about the oil use / conservation of some Continental engines...
IO-470s. Stock for a B55 Baron. My previous Baron was a Colemill so it had the IO-520s on the same airframe. I kinda prefer the 470s.
I do the change it and let the case run out deal. Ends up around 25-30 hours. I just switched to the Phillips 20w50/cam guard plan from 100w plus. I just wanna see how consumption, iron analysis etc. go using Phillips.
I have the quick drain so I do the oil alone at 25 hrs and both oil and filter at the next 25 hrs.
Done that for 11 years and not gonna quit.
I try to get it done between 40 and 50 hours. But it winds up being more often than that. I like to have a fresh oil change before a big trip. And I like to do long trips. I think there was less than 20 hours on the oil that I just got changed. But we were leaving for two weeks of flying. I'd I like to start with fresh oil.
I do an oil change at ~50 hrs with filter. I put in 6 quarts and burn another 6 in between then. I fly too much to do it at a smaller interval (I flew 12 hours in a span of 3 days last weekend) and at 2200SMOH I doubt 25hr intervals will extend it much longer versus a 50-hr interval.
I used to do 25 hours in the Acclaim.   Before the top overhaul, I would have to add a couple of quarts during that time.   After the top, I didn’t have to add anything between changes.    Now I’m in the once a year group :)
Brad.
