Dream to fly Posted May 30, 2018 Report Posted May 30, 2018 Mine has seen better times and I can't seem to find an electronic OHM value. What should the impedance be?
carusoam Posted May 31, 2018 Report Posted May 31, 2018 Looks like there may be room for a lighter, better sounding, replacement... ? How much does the old one weigh? Best regards, -a-
dan nephin Posted May 31, 2018 Report Posted May 31, 2018 The one in the pic is1.4 lbs according to the bathroom scale. 1
Dream to fly Posted May 31, 2018 Author Report Posted May 31, 2018 Just took this out of my 80 k Ok. So 8 ohms. I was thinking it was lower but that will work thanksSent from my E6810 using Tapatalk
bradp Posted May 31, 2018 Report Posted May 31, 2018 Make sure it’s now wired backwards. Aka me how I know. :-) 1
HRM Posted May 31, 2018 Report Posted May 31, 2018 I thought they were supposed to be 4 ohm. Depends on what's driving it, of course.
Dream to fly Posted May 31, 2018 Author Report Posted May 31, 2018 Called PS engineering and the cabin speaker should be 4 ohms at 3 watts. Apparently some speakers were 8 or 16 ohms and that will cause clipping so if you are installing a PS engineering audio panel it is 4 ohms. After some cleaner and a magnifying glass I found a number on the speaker that was a number 2. Mine might have been a 2 ohm speaker in my plane. Just guessing but my speaker was so badly damaged its hard to tell.
EricJ Posted May 31, 2018 Report Posted May 31, 2018 4 hours ago, Dream to fly said: Called PS engineering and the cabin speaker should be 4 ohms at 3 watts. Apparently some speakers were 8 or 16 ohms and that will cause clipping so if you are installing a PS engineering audio panel it is 4 ohms. After some cleaner and a magnifying glass I found a number on the speaker that was a number 2. Mine might have been a 2 ohm speaker in my plane. Just guessing but my speaker was so badly damaged its hard to tell. Probably not 2 Ohms, as speakers are generally either 8 or 4 Ohms.
Bartman Posted May 31, 2018 Report Posted May 31, 2018 Maybe the 2 was really an 8 that was worn just right and looks like a 2 1
FlyingDude Posted June 25, 2021 Report Posted June 25, 2021 Hi guys, Responding after 3 years Anyone found a lighter alternative in these years? I'm also wondering if installing a smaller speaker could open up more room in the air scoop channel, increasing the overhead air flow... Thanks
EricJ Posted June 25, 2021 Report Posted June 25, 2021 26 minutes ago, FlyingDude said: Hi guys, Responding after 3 years Anyone found a lighter alternative in these years? I'm also wondering if installing a smaller speaker could open up more room in the air scoop channel, increasing the overhead air flow... Thanks The speakers spec'ed for my J are no longer made, and this met or exceeded all of the relevant specs. It is the same size, and the mounting tabs fit the same as the old one, etc. I believe it was lighter as well, although I didn't measure how much. Those old speakers had heavier magnets than modern ones.https://www.amazon.com/gp/product/B01N4NY1KE 1
FlyingDude Posted June 25, 2021 Report Posted June 25, 2021 Thanks @EricJbut the specs on that Amazon link say it's 1.8lbs. I was wondering if one can install a much lighter speaker...
mike20papa Posted June 25, 2021 Report Posted June 25, 2021 If you are looking to replace the cabin roof mounted speaker .. beware. If I remember correctly (?!) it has mounting holes in the magnet. If you have an early model, look for the 2-AN3/10-32 screws in the cabin roof that hold the speaker in place. Wish I had better info, but I don't think a simple speaker swap will work.
EricJ Posted June 25, 2021 Report Posted June 25, 2021 42 minutes ago, FlyingDude said: Thanks @EricJbut the specs on that Amazon link say it's 1.8lbs. I was wondering if one can install a much lighter speaker... I think that's for both; there are two in a package. The old, heavy one that came out weighs slightly less than 1.3 lbs (I have it here and just weighed it). 1
carusoam Posted June 25, 2021 Report Posted June 25, 2021 We don’t have a requirement to have a speaker do we? Headsets seem to have replaced the need for one… The back-up to the headset… is another headset. PP wondering only… -a-
N201MKTurbo Posted June 25, 2021 Report Posted June 25, 2021 I have 12 brand new ones. The OEM part number is one letter off. The only difference is they were made for tanks. They have waterproof cones and they don’t have the screws holding the magnet together. Otherwise exactly the same electrically and mechanically. They are still sealed in the mil spec paper bags. Let me know if you want one. It is probably as close as you will ever get to the original speaker.
Shiny moose Posted June 25, 2021 Report Posted June 25, 2021 8 hours ago, N201MKTurbo said: I have 12 brand new ones. The OEM part number is one letter off. The only difference is they were made for tanks. They have waterproof cones and they don’t have the screws holding the magnet together. Otherwise exactly the same electrically and mechanically. They are still sealed in the mil spec paper bags. Let me know if you want one. It is probably as close as you will ever get to the original speaker. Square or rectangIe? I would like to see a picure of what you have.
N201MKTurbo Posted June 25, 2021 Report Posted June 25, 2021 21 minutes ago, Shiny moose said: Square or rectangIe? I would like to see a picure of what you have. They are square. I’ll snap a picture when I get home.
Raymond J1 Posted June 25, 2021 Report Posted June 25, 2021 (edited) On 5/31/2018 at 4:11 AM, Dream to fly said: Ok. So 8 ohms. I was thinking it was lower but that will work thanksSent from my E6810 using Tapatalk If you look at the electrical diagram of your intercom or audio mixer, the value of the impedance required for the speaker circuit is specified. Very good sound for me with this trade model. Just a little thicker, it is necessary to create a specific spacer, but this does not change the mounting of the trim (for "67 F"). Then it is necessary to take back the plastic housing to modify it in the upper part of the magnet. The photo of the molding model showing the modified upper part. Minor modification approved without problems, form one is edited after testing the installation and for the entire installation. Edited June 25, 2021 by Raymond J
Culver LFA Posted June 25, 2021 Report Posted June 25, 2021 (edited) On 6/24/2021 at 10:44 PM, carusoam said: We don’t have a requirement to have a speaker do we? Headsets seem to have replaced the need for one… The back-up to the headset… is another headset. PP wondering only… -a- Carusoam, I flew my Mooney for years with a bad speaker having no idea what I was missing. Since replacement a few years ago I now find that speaker extremely beneficial. It gets hot down here in Atlanta so when I taxi around my home drome the overhead speaker is monitoring the frequency. At airports with AWOS I’ll dial that in on the speaker before startup. There are times it’s nice to not have a headset on while in the airplane. Edit: I just thought of another "feature" that a pro on this forum shared with me - When on an ILS/LOC approach you select the NAV audio on the overhead speaker, the Morse code identifier can be heard in the background providing confirmation that it is working all the way down the chute. It's not too distracting since it is not in your headset but can still be heard slightly muted since the sound is in the cabin. Just an easy way to confirm the ILS/LOC is operating while your going down to mins. Edited June 26, 2021 by Culver LFA Had another thought 2 2
N201MKTurbo Posted June 28, 2021 Report Posted June 28, 2021 Here are the speakers I have. The parts manual lists a Radio Shack speaker. I think I found these from the part number printed on my speaker. If I recall, this is the closest part number I could find. As you can see, they are in mil spec packaging. These have the exact part number as my original speaker, except for one letter in the suffix. The main difference is the terminals are rotated 45 degrees from the original, they don’t have the screws holding the magnets together and they have green waterproof cones. I put one in my 77 J and it fit and sounded perfect. l have 5 speakers, one opened, and 4 in unopened packages. Let’s say $100 plus shipping.
M20F Posted June 28, 2021 Report Posted June 28, 2021 On 6/24/2021 at 9:44 PM, carusoam said: We don’t have a requirement to have a speaker do we? Headsets seem to have replaced the need for one… The back-up to the headset… is another headset. PP wondering only… -a- When one cruises along in their Executive with a cigar in the left hand and a martini in their right hand, civility demands that the Chairmen of the Board be playing over the speaker. 1
carusoam Posted June 28, 2021 Report Posted June 28, 2021 There is a pic of the chairman standing in front of his Lear around here somewhere… -a-
