Bill G Posted April 14, 2018 Report Posted April 14, 2018 I found this under the pilot's seat in my 1962 M20C. I've looked all around the cockpit but can't find anything missing or that looks like it. Any ideas? Quote
Yetti Posted April 14, 2018 Report Posted April 14, 2018 Measuring stick. Usually comes in a quantity of 12 inches. I vote pin for the seat. Look at the rails and see if they have holes that could fit in and then replace. 1 1 Quote
Bill G Posted April 14, 2018 Author Report Posted April 14, 2018 I suspected it might be from the seat but couldn't find where it would go or any missing parts and both seats work OK. Maybe I should remove the seats and take a closer look. Quote
MyNameIsNobody Posted April 14, 2018 Report Posted April 14, 2018 Damn, I thought it was a Broomhandle Mauser firing pin. Quote
N201MKTurbo Posted April 14, 2018 Report Posted April 14, 2018 I think. It fell out of some Cessna drivers pocket. 1 Quote
Skates97 Posted April 15, 2018 Report Posted April 15, 2018 9 hours ago, Bill G said: I suspected it might be from the seat but couldn't find where it would go or any missing parts and both seats work OK. Maybe I should remove the seats and take a closer look. Can you look under along the rails and see the pins when you hold the bar up? If not it is probably worth taking them out and checking to make sure the pins that hold it in the rails are on each side. I don't know if that is what it is, but the seats are very easy to remove so you might as well. 1 Quote
Bill G Posted April 15, 2018 Author Report Posted April 15, 2018 I suspected it might be from the seat but couldn't find where it would go or any missing parts and both seats work OK. Maybe I should remove the seats and take a closer look. Skates97 - I couldn't see the pins, but plan to take the seats out tomorrow for a better look. Quote
carusoam Posted April 15, 2018 Report Posted April 15, 2018 Compare that pin to the the holes in the seat tracks... I think you may have found a seat locator pin. Expect that you have two per seat. If you only have one, the seat kind of cocks around the one pin. If the one pin doesn’t lock properly, you risk sliding back during the T/O run/climb out... See how important that can be? PP thoughts only, not a mechanic. Best regards, -a- Quote
Guest Posted April 15, 2018 Report Posted April 15, 2018 I would guess a seat pin as well, a flashlight and a mirror would confirm it. Or removal of the seat from the rails. Clarence Quote
N201MKTurbo Posted April 15, 2018 Report Posted April 15, 2018 I looked through the IPC drawings for all the years and couldn't find anything like that. They are all longer with a bolt or a pin holding them to the release bar. Quote
Bill G Posted April 15, 2018 Author Report Posted April 15, 2018 I'll take the seats out tomorrow and let you know what I find. Quote
Bill G Posted April 15, 2018 Author Report Posted April 15, 2018 It was 1 of 2 pins that holds the passenger's seat back to the seat. Suprised it didn't completely break apart. Easy to find and repair once I removed the seat. Thanks for the suggestions! 5 1 Quote
Hank Posted April 15, 2018 Report Posted April 15, 2018 Good find! We all learned from your experience. Bet it was pretty obvious where the problem was as you lifted the seat out . . . . Quote
carusoam Posted April 15, 2018 Report Posted April 15, 2018 Great pic, Bill! thanks for sharing the details. Best regards, -a- Quote
1964-M20E Posted April 16, 2018 Report Posted April 16, 2018 Glad you figured it out. That is a good thing to look for and annual inspections. Quote
Stephen Posted April 16, 2018 Report Posted April 16, 2018 I was going to vote Illudium Q-36 Explosive Space Modulator, but if not that, probably seat pin. 2 Quote
carusoam Posted April 23, 2018 Report Posted April 23, 2018 Follow-up to Stephen’s observation.... http://looneytunes.wikia.com/wiki/Illudium_Q-36_Explosive_Space_Modulator Martian humor, -a- Quote
1964-M20E Posted April 23, 2018 Report Posted April 23, 2018 8 hours ago, carusoam said: Follow-up to Stephen’s observation.... http://looneytunes.wikia.com/wiki/Illudium_Q-36_Explosive_Space_Modulator Martian humor, -a- If you need to be told you are already too far gone to be saved. 1 1 Quote
