3 hours ago, Guitarmaster said:
C3 or C2. Much more powerful!
Of course if you went to a 2 ship formation and one flew the first and the other flew the fifth then you would have a power chord formation!
Sent from my XT1585 using Tapatalk
Dominant and tonic
Hi Marauder,
Your cooler will hit the engine mount if you install the STC doubler as it comes in the kit. I installed my doubler on Matt’s airplane last night and we have about 3/4 inch clearance now. I’m thinking of doing my own STC for the cooler relocation now as it should be fairly simple and to correct the problem with the currently available STC.
Hi David,
What’s the best way to proceed with the oil cooler relocation kit? Should I order it and have you install it? Or should I order it and have you provide me the modified doubler? Terry is willing to install the modified doubler but would speed things up if we had the correct doubler.
5 minutes ago, Marauder said:
Hi David,
Hi Marauder,
I’d suggest ordering the kit and I’ll provide you with a new 2 piece doubler. It would be better for me if the relocation was done before I do the cowling mod.
Thank you,
David
Hi Marauder,
Thank you,
David
Sounds good.
Hmmmm...  an C, E, and G all flying in close formation...
If there was no E available, you could find an F, but it be much tighter with the G and the C would be in loose formation. Or, if you like, a "sus4" formation....
I think I need to go to bed....
Went up this afternoon or some testing in the C.
There is no discernible difference in TAS with the cowl flaps trailing open by 1"  Granted, weather conditions were different from the last time; the temp and hence, DA being the biggest factor.
What is noticeable is the CHT.  Power is about 23.5/2400.
Old Cowl flap setting
New Cowl flap setting:
It definitely looks like Dave's cowl mod helps with cooling.  Granted, it appears that the MP is about 1.5" higher in the first pic, but I have a hard time believing that alone is producing 30 degree hotter temps.
I'm excited to see what happens to my "F"!
Edited by Guitarmaster
390ish Cylinders down to 360ish?  Is this the temps that C’s commonly see?  I do not ever see those temps in cruise in my E model.  Is this the cowl or is this what “C’s” do for cylinder temps?
I wish Scott! I routinely get over 400 in the climb and in cruise I'm lucky to get under 380-390....
Hi Scott,
I’m not sure what part of the mod has helped my temps the most, new baffling, cowling, or cowl flap modification. I still have some more work that we’re experimenting with on the cowl flap exit air. We’ll see how we do on Matt’s. I expect some issue to cause me to scratch my head and then struggle to fix.
Thanks,
David
It’s raining 337’s here today! I received Matt’s and Marauders 337’s today. The FAA actually beat me to getting the paperwork done before the job. Time to get Matt’s flying for data reports!
David
  • Like 7
David
That is great news David. Let me know when you think you can get the doubler to me and I will order the oil cooler relocation kit.
Really curious to see Matt’s numbers.
Will do. I think I can work on the doubler next week. Need to check my stock of aluminum.
Thanks
1 minute ago, bradp said:
You guys still running 50 ROP >75%?
Negative. My Owners Manual says that greater than 75% power requires Full Rich. I'm only there for takeoff and climb.
My engine also performs better if I back off from WOT until the MP needle wiggles, which can be a lot at >8000 msl,  something to do with air flow through the carburetor as well as the WOT fuel enrichment circuit. You injected guys don't seem to have this issue . . . .
