Hank Posted January 21, 2017 Report Posted January 21, 2017 My gear horn decided it doesn't need to wait until 12" to come on anymore. It varies, but is usually 14-15", although a couple of times it started buzzing around 16", which is totally unacceptable. Where is the stinking microswitch located??? I've taken apart the throttle quadrant but didn't see it. Today I looked all along the carb and no dice behind it, either. Where is it hiding? For what it's worth, my C is all electric, 1970. Thanks, ya'll. Quote
Mooneymite Posted January 21, 2017 Report Posted January 21, 2017 (edited) Hank, I have never actually seen it, but when you move the throttle in the quadrant, you can hear it clicking.....it must be somewhere close. Mine is also sometimes less than precise. When you find it, post pictures! I thought you ran at full throttle all the time. I'm surprised you ever hear the horn. Edited January 21, 2017 by Mooneymite 1 Quote
KSMooniac Posted January 21, 2017 Report Posted January 21, 2017 Look behind the quadrant from the pilot side of the console. There should be a small plate holding the switch with two clamps that grab on the throttle cable. They might've slipped, allowing the switch to activate too soon.Sent from my VS985 4G using Tapatalk Quote
Hank Posted January 21, 2017 Author Report Posted January 21, 2017 Thanks, I'll check there again and look for the plate. It starting acting up not long after replacing the carb heat cable. Must have gotten bumped. Quote
carusoam Posted January 21, 2017 Report Posted January 21, 2017 (edited) On the push/pull version, it is an adjustable position switch on the throttle control behind the instrument panel. I believe, I recall somebody posting photos of the switch and how it was adjusted, And the notch in the rod that had the knob on the end. Now, how much different would the quadrant be compared to the push / pull version? Hope that can help. Best regards, -a- I found the photos here... Edited January 21, 2017 by carusoam Quote
Bob_Belville Posted January 21, 2017 Report Posted January 21, 2017 I replaced all 3 engine control cables in 2015. On my E the limit switch is mounted on the throttle cable right behind the panel. It might be different on your C but with the engine not running you should hear the LS make as you pull the throttle. The top cable in the photo below is my old throttle cable. The slot in the sheath is where the LS rides. (I took the pic to send to McFarlane - the bottom new cable came minus the slot. They immediately made a new, correct cable. Fine folks.) 1 Quote
carusoam Posted January 21, 2017 Report Posted January 21, 2017 Good morning, Bob! 3am on the east coast. It will be a couple of hours before even Mr Hyett shows up... Best regards, -a- 1 Quote
Bob_Belville Posted January 21, 2017 Report Posted January 21, 2017 On 1/21/2017 at 8:34 AM, carusoam said: Good morning, Bob! 3am on the east coast. It will be a couple of hours before even Mr Hyett shows up... Best regards, -a- Expand Another insomniac. I probably should be reading one of the books I received for Xmas. NT Wright or John Goldingay ought to do it. 1 Quote
Marauder Posted January 21, 2017 Report Posted January 21, 2017 On 1/21/2017 at 8:34 AM, carusoam said: Good morning, Bob! 3am on the east coast. It will be a couple of hours before even Mr Hyett shows up... Best regards, -a- On 1/21/2017 at 8:43 AM, Bob_Belville said: Another insomniac. I probably should be reading one of the books I received for Xmas. NT Wright or John Goldingay ought to do it. I'm glad to see I'm not the only one. Sent from my iPad using Tapatalk 1 Quote
Marauder Posted January 21, 2017 Report Posted January 21, 2017 Sent from my iPad using Tapatalk Quote
Bob_Belville Posted January 21, 2017 Report Posted January 21, 2017 On 1/21/2017 at 8:49 AM, Marauder said: I'm glad to see I'm not the only one. Sent from my iPad using Tapatalk Expand Just getting home from an Inaugural Ball? Quote
Marauder Posted January 21, 2017 Report Posted January 21, 2017 I blame my insomnia on the day job. You two retirees should be sleeping like babies. Sent from my iPad using Tapatalk Quote
Marauder Posted January 21, 2017 Report Posted January 21, 2017 On 1/21/2017 at 8:50 AM, Bob_Belville said: Just getting home from an Inaugural Ball? Washington is having two events. The Ball and the Riot. Pick your venue. Sent from my iPad using Tapatalk 1 Quote
Bob_Belville Posted January 21, 2017 Report Posted January 21, 2017 My Mooney is not the only one in the family with a bladder. Quote
Bob_Belville Posted January 21, 2017 Report Posted January 21, 2017 On 1/21/2017 at 8:52 AM, Marauder said: Washington is having two events. The Ball and the Riot. Pick your venue. Sent from my iPad using Tapatalk Expand Remmeber the last time the Tea Party pillaged and burned stuff? Me neither. Quote
Marauder Posted January 21, 2017 Report Posted January 21, 2017 It's been an interesting day in the northeast. My favorite part was the disappearing TFR over Biden's house. Sent from my iPad using Tapatalk 3 Quote
Bob_Belville Posted January 21, 2017 Report Posted January 21, 2017 On 1/21/2017 at 8:20 AM, Bob_Belville said: I replaced all 3 engine control cables in 2015. On my E the limit switch is mounted on the throttle cable right behind the panel. It might be different on your C but with the engine not running you should hear the LS make as you pull the throttle. The top cable in the photo below is my old throttle cable. The slot in the sheath is where the LS rides. (I took the pic to send to McFarlane - the bottom new cable came minus the slot. They immediately made a new, correct cable. Fine folks.) Expand The cable at the bottom of this pic is the throttle. You can see the leads to the LS. I just noticed that the power boost cable is fitted for a LS to activate a panel light that the ram air door is open but the switch is not installed! Quote
bonal Posted January 21, 2017 Report Posted January 21, 2017 Doesn't Hank have a quadrant if so would be different than our push pull throttle Quote
Hank Posted January 22, 2017 Author Report Posted January 22, 2017 On 1/21/2017 at 11:58 PM, bonal said: Doesn't Hank have a quadrant if so would be different than our push pull throttle Expand Yes I do. And my mechanic gave up quickly when he looked at it today . . . Guess I'll try again later . . . Quote
gsxrpilot Posted January 22, 2017 Report Posted January 22, 2017 My former C had the switch at the carb end of the throttle cable. Quote
Hank Posted January 22, 2017 Author Report Posted January 22, 2017 On 1/22/2017 at 2:15 AM, gsxrpilot said: My former C had the switch at the carb end of the throttle cable. Expand Yeah, we looked there first, flashlights and all, from both sides. Was your C a quadrant bird like mine? Quote
gsxrpilot Posted January 22, 2017 Report Posted January 22, 2017 On 1/22/2017 at 2:18 AM, Hank said: Was your C a quadrant bird like mine? Expand No, mine had a vernier throttle which for a 1964, was obviously after market. Quote
sleepingsquirrel Posted January 22, 2017 Report Posted January 22, 2017 (edited) Hi Hank, My B model switch is in the engine compartment. Yours might be throwback to that style. diagram at bottom of this SB shows location of switch on firewall. M20B gear warning throttle.pdfUnavailable Edited January 22, 2017 by sleepingsquirrel Quote
MBDiagMan Posted January 15, 2019 Report Posted January 15, 2019 Famous last words, but adjusting my gear horn switch will be the last little detail that will have everything tip-top. That is, of course, until the next little thing comes up. My switch is like the one at the bottom of the bottom picture in Bob Belvilles post. The challenge is getting to the four nuts on the back side to hold them while loosening and tightening the screws. There are air vents and all sorts of things not only in the way, but serve as an abyss for a wrench or nut to fall into. The nut should only have to be loosened, but there is very minimal room for a wrench. I haven’t even been able to determine the nuts wrench size. I think it will be 11/32. This one might call for the invention of some new curse words, because I don’t think the old ones will be strong enough. Right now, the throttle is right at 3/4” from being pulled out all the way. If I can get it loose to adjust it I am thinking I will set it to 3/8” and try it. Can anyone tell me how far from full rearward their gear horn switch actuated? Quote
Culver LFA Posted January 16, 2019 Report Posted January 16, 2019 On 1/15/2019 at 10:20 PM, MBDiagMan said: I haven’t even been able to determine the nuts wrench size. I think it will be 11/32. Expand The 2 throttle switch nuts are 1/4” on my ‘67 F. Pulling avionics from the rack may help so you can slide a hand in from the top/middle and the other from below the panel. Something will cramp up, guaranteed. Quote
