Tony Armour Posted November 6, 2015 Report Posted November 6, 2015 (edited) I would discribe it but it's impossible :-) Might should belong in the Vintage forum ? http://charlotte.craigslist.org/cto/5270430991.html Edited November 6, 2015 by Tony Armour 1 Quote
mpg Posted November 6, 2015 Report Posted November 6, 2015 .. Kathryn's Report: Mooney M20C, N6762U: Accident ... ..NTSB Identification: ERA14CA104 14 CFR Part 91: General AviationAccident occurred Sunday, January 26, 2014 in Rutherfordton, NCProbable Cause Approval Date: 04/23/2014Aircraft: MOONEY M20C, registration: N6762UInjuries: 1 Uninjured.NTSB investigators used data provided by various entities, including, but not limited to, the Federal Aviation Administration and/or the operator and did not travel in support of this investigation to prepare this aircraft accident report.According to the pilot, he checked the fuel gauges in the airplane before departing on a cross country flight. He stated that the left fuel gauge indicated 1/2 tank and the right fuel gauge indicated 1/4 tank. The pilot did not visually check the fuel quantity in the tanks and did not take on any additional fuel. Approximately 60 nautical miles (NM) from his destination, he switched from the left fuel tank to the right fuel tank. The engine began to "stutter" and he switched back to the left fuel tank and the engine resumed normal operation. He located the nearest airport which was 10 NM from his location and made a turn towards it. Shortly thereafter, the engine began to "stutter" again and the pilot shut the engine down and made an emergency landing in a field. During the emergency landing, the airplane collided with trees, and sustained substantial damage to the wings and fuselage. Examination of the fuel system revealed that the fuel tanks were not breached, and the left and right fuel tanks contained less than 1 gallon of fuel in each. A review of the pilot operating handbook (POH) revealed that each fuel tank held 26 gallons of fuel, for a total of 52 gallons. The POH stated that there is 48 gallons of usable fuel, which left 4 gallons of fuel unusable. The POH also revealed that the fuel tanks should be visually checked before flight. 1 Quote
carusoam Posted November 6, 2015 Report Posted November 6, 2015 (edited) Excellent for both the vintage Mooney/Corvette driver! 60’s Mooney M20C, 80’s C4 Vette... the 70’s C3 wheels bridge the decades? Gives a nice visual feel for how wide the Mooney cabin is. The width is typical of a Corvette minus the center drive shaft tunnel. Best regards, -a- Edited November 6, 2015 by carusoam 1 Quote
1964-M20E Posted November 6, 2015 Report Posted November 6, 2015 On 11/6/2015 at 4:35 AM, Tony Armour said: I would discribe it but it's impossible :-) Might should belong in the Vintage forum ? http://charlotte.craigslist.org/cto/5270430991.html yes but you would need to add a second door. I have an extra fuselage maybe not a bad Idea make an electric car from it. 3 Quote
aviatoreb Posted November 6, 2015 Report Posted November 6, 2015 I think it is now officially an experimental - so you could install a parachute! 1 Quote
Raptor05121 Posted November 6, 2015 Report Posted November 6, 2015 Came out just after mine, I'm 6744U 1 Quote
aviatoreb Posted November 6, 2015 Report Posted November 6, 2015 I think it would look better with a paint job - let's all switch over the paint thread. 1 Quote
