One-man lower cowl removal & installation jack
For those of you who work on your own airplane but don't always have someone present to help you remove and reinstall the lower cowl, here is a YouTube video which shows how to do it without chipping paint or scratching the spinner.  This jack makes it safe and efficient and it's easy/cheap to build.
Edited by JimK
  • Like 11
  • Thanks 5
That is a clever design, but I would never pull the cowling without three strips of painters tape on the body directly behind the cowling.
look at 4/5 (long bodies at least), and you will see why.
Very clever.  I've been thinking about a solution on the J model.   I like this, but on the J there is no drain hole.   I was thinking about something like an engine hoist, but not so heavy.
Hmm, do you own a drill and drill bits????  :D :D
I would love plans.
  • 3 weeks later...
Jim,
Well done.  Any chance you’d share the length and height of your cowl stand.  Serious pain to do solo without scratching the paint.  Took mine off today and was wishing I had a stand like yours.
Thanks for sharing,
  • 3 weeks later...
My “no scratch solution” for my J is paracord support across the top of the engine and duct tape covering all offending edges and corners, front and rear of the cowl.
I thread a medium zip tie through the third (I think) camloc hole and attach the paracord to both sides with slip knots and hook it behind the lifting loop to keep it in place. Tape over the aluminum flange and nut plates at the front to protect the spinner and also thoroughly cover the aluminum channel and the first camloc at the rear to protect the fuselage. “Pop” the cowl loose from the fuselage and alternate slacking up the left and right sides to lower it to safety. Reverse the procedure to install. Since I started doing this, I haven’t made any new marks.
It takes some practice, but it’s not hard to get the hang of it.
On 2/8/2025 at 10:20 AM, PprophetBirdman said:
I use a hydraulic lift table from Harbor freight to raise and lower the cowl.
I have read a large number of reviews saying it doesn't go up or down and/or the little rubber plug that's supposed to keep the hydraulic fluid contained blows out never to be seen again.  What was your experience?
My experience with HF hydraulics (jacks) is you need to bleed them.  As shipped they get air into the cylinder and then won't go up.
Thanks for the tip. I have one on order and will see how it does, with some padding and/or moving blankets.
This is the one I ordered:
https://www.harborfreight.com/automotive/lifts-cranes-stands/hydraulic-lifts-carts/500-lb-capacity-hydraulic-table-cart-70726.html
Okay, stupid question, but what is that oval-shaped thing just aft of the cowling on this Ovation?  Mine certainly doesn't have this, and the manufacture date is just a year earlier.  Is that a light that shines out on the wing?  I found this aircraft on Flight Aware and the picture from the right side doesn't show a similar thing.  Just curious...
