I’ve never had one of these apart to examine the mechanism, but from various documents and published descriptions, it seems clear that the spring performs two functions. First, it acts as a wrap spring brake to keep the wheels in the retracted position. Second, it acts as a wrap spring clutch to engage the motor with the ball screw to extend the gear. This is why the gear won’t extend if the spring breaks; the motor spins, but it is disconnected from the rest of the mechanism.
There are really two preloads on the gear. The first is checked by slowly extending the gear with the emergency system just until the gear down light illuminates and then checking that the preloads are within the specified range. The second test is to cycle the gear electrically and check that a higher maximum preload is not exceeded. This is because momentum will cause the gear to keep moving a bit when the down limit switch cuts off power to the motor, and so the preload will be higher in this case.
Skip
Skip
This is the first time I'm learning about this.   Makes sense.  Good to know.  I'd nominate this piece of information for a MS FAQ.  Is it controversial?   Seems not.
It’s in the service and maintenance manual for the M20J and I presume others as well.
5 hours ago, MikeOH said:
If I'm following this discussion correctly (and I may not be!), I think that once on the ground the weight of the aircraft tries to drive the link open, but since it's over center, it just locks more. The motor is no longer needed once weight is on the wheels.
The part I'm not following is if the no-back spring is causing this, i.e. it has failed, then how come the gear works at all?  I thought a no-back spring failure resulted in the gear refusing to even extend, not just allowing the gear to come off of over center?  What am I missing?
14 hours ago, amillet said:
I too questioned why it made any difference with the gear down. This is Greg’s explanation:
The gear actuator is the biggest issue we seem to have.  The reason the gear horn is sounding intermittently is because the gear actuator is turning backwards releasing the gear tension.  The reason for this is the No Back Spring is slipping.  When the tension drops off, the gear actuator kicks on to gear back up against the stop.  Not the best thing for the motor or the actuator.
Like @MikeOH , I am also having a hard time understanding the supposed failure mode on a no-back spring that would let the gears in the gear motor actuator slip backwards slightly when the gear is down and over-center.  Possibly if the no-back spring tang was cracked and flexing it might happen.  If it was broken you would not have any gear operation.
You would be wise to ask for the old no-back spring (#9 in diagram) to be returned to you for inspection. (like @Danb above). See if it is cracked.  If not - this doesn't seem to make sense.
Edited by 1980Mooney
Referenced wrong part #
  • 10 months later...
On 8/30/2023 at 1:05 PM, PT20J said:
I'm firmly in the camp of if it ain't broke, don't mess with it.
I've looked into this a lot. Eaton never had a recommendation about maintenance on these as far as I can tell until they had a failure of a no-back spring that was probably due to a bad manufacturing lot of springs. That was many years ago. The 1000 hours seems to have come from Mooney and was due to the failure of two springs in Plessey actuators (different design) at a little under 1000 hours each.
The 1000 hours is really meaningless. It's cycles that are important. Don Maxwell told me that the Eaton actuator is rated for 20,000 cycles. If you cycled the gear once per hour of flight time, that would be 20,000 hours.
So, figuring that any bad springs have worked their way out of the installed base by now, I see no value in messing with it. I think about it this way: The only reason to mess with it is fear of failure. After I had it serviced, I would have to worry about a maintenance induced failure. Same difference -- I'd still have something to worry about and there is no objective means to tell which is better. By the way, when I asked Don about it he said not to mess with it unless it was making an unusual noise.
Skip
I'm having to deal with the NBS for my annual right now.  Since it's a SB from Mooney it's not mandatory to comply with the replacement every 1,000 hrs.  But, I was wondering what implications that has with insurance.  If the spring does break and you have a gear up can insurance deny the claim because you did not comply with a Service Bulletin?
Doubt it but we should let @Parker_Woodruff answer.
Not at all.
What if you had a perfectly good no-back-spring and it was replaced with a new one that suffers from infant mortality and snaps in 20 hours?
Not always, but Service Bulletins are sometimes over-reactions - a solution looking for a problem.
2 hours ago, LANCECASPER said:
Not at all.
Actually, there was an accident like that where a noback spring with only a few hundred hours since replacement failed in a Plessey actuator and caused a gear up landing. It was classified as an accident because some structural piece was worn through by contact with the pavement that classified it as substantial damage.
Edited by PT20J
Updated to include that it was a Plessey actuator
I replaced my no back spring about 4 years ago at 1500 because I had the part, knowing what I know now I woul leave it alone. The risk of the spring failing is minuscule and outweighed by the risk of something being damaged in the installation and/or the new spring failing, if you call Brian Kendrick or Don Maxwell they will probably say the same thing, ain't broke ain't fix it
Nothing to worry about as this isn't presently a legal requirement to accomplish.
  • 1 year later...
So the consensus is still not to replace the no back spring if it looks ok? Are the kits even available currently? If one were to choose not to replace them, how often would you inspect it?
Yes, they are available with significant lead time, from website:
LASAR INC is pleased to return to market the crucial Eaton "no-back" clutch spring kit, as specified in Mooney SB M20-282. P/N SB 20-282-001 kit. Initial quantities are limited with a manufacturing lead time of 32 weeks. To celebrate, we're offering this part at a reduced rate through the end of the year! Full part price as of March 1, 2025 is $2995.00, but our sale price is $2575.00 each. Take advantage of the savings and secure your order by submitting your $1250.00 deposit today, the remaining balance of $1325.00 will be due when the part is ready to ship to you!
  • Sad 2
I don't understand what the discount there is? Is it on the prepayment but the full price is $2995.00 regardless?
But more importantly, do people replace them after 1000h or no?
I haven’t yet seen a MSer who replaced a NBS for $3000. This is a “go away” price for a part that may have negative overall value for the aircraft.
 I know SB is not mandatory for part 91, but this shows up in at least some of the Maintenance Manuals…  The Ovation manual shows it as mandatory. It’s not an AD, so I guess it may depend on the vintage of the aircraft if this manual applies to a specific airframe or not.
Got this in the email the other day from Lasar:
Why is the No-Back Spring so important?
Per the Mooney Service Bulletin, the failure of the No-Back Spring in the Landing Gear actuator renders both the normal (electrical) landing gear inoperative as well as the emergency (manual) mode.  The potential for physical harm and expense of a belly landing far outweighs the cost of safety.
Take advantage of our No-Back Spring Kit installation – in accordance with Mooney Service Bulletin - M20-282.
Purchase your kit (SB 20-282-001 - $2575.00)
Standard install price: $895.00
Labor Day Special
Installation for $750
that's a savings of $145!
Labor Day Special
You only need to fly to Oregon to save that $145.....
:D
  • Haha 2
I was advised that I am nearing the sb to replace the spring.
I am not going to do so.
I believe there was a bad batch at some point in the past and that the SB was an over reaction.
no guarantee that the “new” spring will not have issues.
the life cycles of these springs is pretty light in our airplanes and I see no reason to spend $3k for a $10 part that is unlikely to fail.
At least that is my opinion.
