I'm looking for mooney part #600364-003 and -001.  These are the washers used to shim the engine mounts.  I guess I can call the MSC in Rome, but I didn't know if anyone knew where they are readily available.  Google is coming up empty, and searching on this forum isn't really helping a lot, either.
Thanks.
there is a trick to putting shims in..they have thin spacers and thick 32nd and 64th inch.....on 2 of the shims thick and two thin,,,,make a cutout all the way through the shim approx 1 inch,,,,this way you can slide the shim in just loosen engine mount,,,add thick or thin shim..put on the cowling bolt it up and see which corner mount will move the spinner in the exact position..to line up with cowling.... really very easy job you will need an engine hoist to move engine in certain positions
