I just recently found out that the Insurance starts going up on retractable gear airplanes when you hit 70 years of age. So I was thinking I would convert my E to a D to keep the plane and get the lower insurance rate. I would rather keep my Mooney than have to sell it and buy a fixed gear. I just read a 2018 post that D models were C’s however when you look at the parts manual it appears the parts would fit an E model. I have 5 years to think about it. What do you guys think?
I’m sure there would be somebody out there with a Fixed gear D who would love trade you his 180 hp engine, fixed pitch prop, cowling  and stuck gear - for your engine, prop, cowling, and complete  retract system....
It is an interesting thought!  You might check with your insurance company if insurance for such a one off aircraft would be reasonable.  You may find it harder to insure than what you have already.  Perhaps @Parker_Woodruff is around to chime in.  He discussed some strategies in another thread, where a friend lost hull coverage due to age 80.
You’d never make the saved premium back that you’d have to spend for a field approved conversion like that.
And there is no fixed gear M20E in the underwriting tables...so you might not even get a better rate.
Just be with the right insurance company at age 68 and re-evaluate with your broker at age 74.
17 hours ago, kerry said:
Skip the hull coverage and get a quote for liability.
maybe skip the in motion hull coverage.  That way your hull is covered when sitting at the hangar
I would wait 5 years and see what the insurance company says at that point.
