brndiar Posted October 11, 2020 Report Posted October 11, 2020 Hi, Would like to know your procedure when starting warm carburator motor. thanks in advance, m. Quote
David Lloyd Posted October 11, 2020 Report Posted October 11, 2020 Before shutting down, set the idle for 1000 RPM, don't move it until after it starts. To restart, brakes on, fuel pump on, engage starter. When it fires, advance the mixture. I think this is what the POH says, it works as well as anything. Edit: Looked in the POH and it doesn't say anything about a hot start. Maybe I read that here. It works. 1 1 Quote
Hank Posted October 11, 2020 Report Posted October 11, 2020 I always shutdown my C by pulling the mixture, and after the RPM rise I also pull the throttle. Restarting is simple-- Master On Mixture Rich Pump throttle one time Advance throttle 1/2" (~1 cm) Turn ignition key and push It will take about twice as long as a cold start, maybe 4-5 seconds to catch. Then set for 1000 RPM and lean the mixture about 2/3 towards Cut Off. If I've only shutdown a few minutes, like for refueling, I don't pump the throttle any. If it's sat while I ate, then I pump it one time. 3 Quote
Skates97 Posted October 11, 2020 Report Posted October 11, 2020 3 hours ago, David Lloyd said: Before shutting down, set the idle for 1000 RPM, don't move it until after it starts. To restart, brakes on, fuel pump on, engage starter. When it fires, advance the mixture. I think this is what the POH says, it works as well as anything. I do the same thing although I don't turn the fuel pump on. I leave the mixture at idle cut-off like you, I have found that if I pump the throttle or leave the mixture rich it takes longer to start. If I have the throttle all the way out I will push it in about 1/4 inch or so. Once the starter is engaged I start advancing the mixture and it will usually fire up by the 3rd or 4th blade. 1 Quote
Mooneymite Posted October 11, 2020 Report Posted October 11, 2020 (edited) 2 hours ago, Hank said: I always shutdown my C by pulling the mixture, and after the RPM rise I also pull the throttle. Restarting is simple-- Master On Mixture Rich Pump throttle one time Advance throttle 1/2" (~1 cm) Turn ignition key and push It will take about twice as long as a cold start, maybe 4-5 seconds to catch. Then set for 1000 RPM and lean the mixture about 2/3 towards Cut Off. If I've only shutdown a few minutes, like for refueling, I don't pump the throttle any. If it's sat while I ate, then I pump it one time. I used to also use this procedure, but became concerned about pumping raw fuel into a hot engine that was not running. Assuming the engine is still warm, I do not turn on the fuel pump, or pump the throttle at all until I engage the starter. MIxture rich, throttle position is nearly (but not quite) closed. As soon as the propeller begins to move indicating the fuel will be sucked into the engine, I pump the throttle once. The engine catches immediately and runs smoothly at a low idle. Lean immediately. There is nothing in the manual to substantiate this procedure. It is purely personal technique, but I will confirm that it seems to work well. Edited October 11, 2020 by Mooneymite Quote
DXB Posted October 11, 2020 Report Posted October 11, 2020 Start with mixture only 1/2 way in. Everything else the same. Never flood again. Easy peasy. Quote
Pasturepilot Posted October 13, 2020 Report Posted October 13, 2020 Almost any technique you want for try will work on an o-360. I pump the throttle once, push it in again, and start it lean. Push the mixture in when it fires, and pull the throttle to idle. Nothing has to happen in a hurry. Arguably this may be the most forgiving engine ever for hot starts. If you’re having problems with hot starts, get a CFI in the plane with you for a shot. If they have any problem at all, you’ve probably got an ignition problem. I've clown a number of injected engines, some of them hopped up way beyond Lycoming’s wildest dreams. Only time I sweated hot starts was on a four cylinder Lycoming pushing 280 HP. A well serviced ignition system and a decent carb should fire up easily. Hot, cold, any condition. Quote
59Moonster Posted October 14, 2020 Report Posted October 14, 2020 1 pump throttle - leave all the way out mixture in fuel pump on ignition key clear prop master on start advance throttle as soon as it kicks over (this helps ensure a nice smooth start and keeps the engine from jumping/racing and keeps passengers happy) So far has worked like a charm! Quote
Oscar Avalle Posted October 15, 2020 Report Posted October 15, 2020 On 10/11/2020 at 7:20 AM, Hank said: I always shutdown my C by pulling the mixture, and after the RPM rise I also pull the throttle. Restarting is simple-- Master On Mixture Rich Pump throttle one time Advance throttle 1/2" (~1 cm) Turn ignition key and push It will take about twice as long as a cold start, maybe 4-5 seconds to catch. Then set for 1000 RPM and lean the mixture about 2/3 towards Cut Off. If I've only shutdown a few minutes, like for refueling, I don't pump the throttle any. If it's sat while I ate, then I pump it one time. Same procedure on my side. If I don't pump the throttle once... she does not start. Oscar Quote
DJE22 Posted November 15, 2020 Report Posted November 15, 2020 On 10/11/2020 at 5:57 AM, brndiar said: Hi, Would like to know your procedure when starting warm carburator motor. thanks in advance, m. If starting within a few minutes (like a fuel stop, for example) mixture lean; throttle cracked from shutdown ~800 to 1000 rpm; engage starter and mixture rich after start. No fuel pump or throttle pump required. If more than 90 minutes I will pump throttle only (still no e- fuel pump) and start from lean starts every time! now...hot-starting a IO360 is a different story! 1 1 Quote
Hector Posted November 15, 2020 Report Posted November 15, 2020 I always shutdown my C by pulling the mixture, and after the RPM rise I also pull the throttle. Restarting is simple-- Master On Mixture Rich Pump throttle one time Advance throttle 1/2" (~1 cm) Turn ignition key and push It will take about twice as long as a cold start, maybe 4-5 seconds to catch. Then set for 1000 RPM and lean the mixture about 2/3 towards Cut Off. If I've only shutdown a few minutes, like for refueling, I don't pump the throttle any. If it's sat while I ate, then I pump it one time.This is exactly what I do and it works every time. Sent from my iPad using Tapatalk Quote
bonal Posted November 15, 2020 Report Posted November 15, 2020 As others have said easy Peasy but kind of depends on what you consider warm. Set rpm around 1100 pull mixture to cut off. When ready turn key push mixture in till it fires usually only a couple blades. If it's been more than a few hours give it one pump on the throttle and do the same procedure as before. Always works for our C Quote
MooneyMitch Posted November 16, 2020 Report Posted November 16, 2020 4 hours ago, bonal said: As others have said easy Peasy but kind of depends on what you consider warm. Set rpm around 1100 pull mixture to cut off. When ready turn key push mixture in till it fires usually only a couple blades. If it's been more than a few hours give it one pump on the throttle and do the same procedure as before. Always works for our C Similar procedure....... except I enrich mixture prior to initiating start. Quote
bonal Posted November 16, 2020 Report Posted November 16, 2020 14 hours ago, MooneyMitch said: Similar procedure....... except I enrich mixture prior to initiating start. But how do you know just how far to push it in. If it's cranking as you enrich then it fires as soon as ideal mixture is reached. Guess it's about what works best for the individual. It's all good Quote
Hank Posted November 16, 2020 Report Posted November 16, 2020 Just now, bonal said: But how do you know just how far to push it in. If it's cranking as you enrich then it fires as soon as ideal mixture is reached. Guess it's about what works best for the individual. It's all good Simple, I push it to Full Rich before turning the key. 1 Quote
bonal Posted November 16, 2020 Report Posted November 16, 2020 I try to avoid full rich for any idle speeds because of plug fouling would rather find sweet spot from the lean side of the spectrum but that's just me. Snoopy is very sensitive that way. Quote
Hank Posted November 16, 2020 Report Posted November 16, 2020 (edited) 6 minutes ago, bonal said: I try to avoid full rich for any idle speeds because of plug fouling would rather find sweet spot from the lean side of the spectrum but that's just me. Snoopy is very sensitive that way. Full rich, start engine, set RPM, pull mixture 2/3 or more towards ICO. Full rich is for starting, Takeoff and Landing only. Pretty much no lead whenever I pull the plugs. Edited November 16, 2020 by Hank 2 Quote
brndiar Posted November 16, 2020 Author Report Posted November 16, 2020 23 minutes ago, Hank said: Full rich, start engine, set RPM, pull mixture 2/3 or more towards ICO. Full rich is for starting, Takeoff and Landing only. Pretty much no lead whenever I pull the plugs. Thanks a lot. Hopefully not off topic: More here lg, M Quote
MooneyMitch Posted November 16, 2020 Report Posted November 16, 2020 1 hour ago, bonal said: But how do you know just how far to push it in. If it's cranking as you enrich then it fires as soon as ideal mixture is reached. Guess it's about what works best for the individual. It's all good I push mixture all the way in, don’t move throttle, start. It’s the same as a normal start, except no electric pump activation. Quote
Mooneymite Posted November 16, 2020 Report Posted November 16, 2020 I'm really enjoying this thread. Finally! A thread about starting the O-360 with lots of different techniques; all of them work! I was feeling so left out of all those threads about starting IO-360s where apparently, the only successful technique involves voodoo and secret incantations. 1 2 Quote
brndiar Posted November 16, 2020 Author Report Posted November 16, 2020 After a short break (works for me): -I do not touch Throttle (remains where it was, when I turned out the engine, cca 1000 RPM) -Mixture ICO -Short Activate electric Pump (just to make fuel Pressure), -Crank Engine and simultaneously move Mixture forward, till engine fire -lean the mixture Lg, M 1 Quote
brndiar Posted November 16, 2020 Author Report Posted November 16, 2020 Just to consider :-) MA3-SPA carb accelerator pump action. 1 Quote
Hank Posted November 17, 2020 Report Posted November 17, 2020 4 hours ago, Mooneymite said: I'm really enjoying this thread. Finally! A thread about starting the O-360 with lots of different techniques; all of them work! I was feeling so left out of all those threads about starting IO-360s where apparently, the only successful technique involves voodoo and secret incantations. Ours are as easy to start as theirs are difficult! Seems like no matter how you do it, an O-360 will crank (hot or cold!). Quote
carusoam Posted November 17, 2020 Report Posted November 17, 2020 When I blend Brndiar’s accelerator pump video with Hank’s advice... My O360 would have started more predictably with an accelerator pump that worked properly... A carb OH would have been a great idea... I needed MS to start about 10 years sooner... Best regards, -a- Quote
