My little firebreather is in the shop for an avionics update. Apparently the speedbrakes are connected to the avionics bus, and they ask whether I want to keep it on the avionics bus or connect it to the battery bus.  Any opinions on this ? Avionics bus+engine failure = no speedbrakes. Then again, how much amps do the speedbrakes drain from the battery ? My speedbrakes are pneumatically operated...
I think anything with a motor on it (high momentary current draw) is best kept away from the power that supplies the more sensitive electronics...
it is more in the category of flaps, gear, and anything else that adds drag.... if concerned with emergency things to remember when things go pear shaped...
For back-up to your logic... find a CB panel from any long body... they all got speed brakes from the factory...
PP thoughts only not a mechanic...
Electric speed brakes on the LBs...
What is the electrical use for the vac powered brakes?   A relay and a valve? Which could get electrically noisy with age...
1 hour ago, PT20J said:
What does the installation manual say?
I can only find the manual for the electrically operated speedbrakes.  Since the SB were installed at the Mooney factory I hoped I’d find something in the maintenance manual but alas...
On my M20J, the speed brakes are wired to the main bus, but they are electric and should have a much higher current draw. If you have the schematics from the Mooney Service and Maintenance Manual for your airplane you could check to see if the factory originally wired them to the avionics bus. You might also email Stacey Ellis at technicalsupport@mooney.com -- I usually get an answer back pretty quickly.
Skip
They should be wired to the main battery bus.
Just now, ArtVandelay said:
What more do you need?
Tom
I’d like to learn the reasoning behind it. Or find a reference document.  I have zero technical background but I like knowing what happens to my plane.
3 hours ago, Airways said:
Clear & concise, @StevenL757 :). I like that ! Could you elaborate ?
Simply put, speed brakes are not avionics.  Conversely, TKS is on the avionics bus; however, it is part of essential equipment - in that when you shed load by switching from the primary ALT FIELD to the EMERG BUS / STBY ALT (in airplanes so-equipped), TKS remains part of the essential/emergency bus...for obvious reasons.
On the G1000-equipped Ovations and Acclaims, everything is on the primary bus, so when you power up the cockpit from "cold and dark", everything comes up...displays, avionics, TKS, standby instruments, etc.
It’s possible that it was wired to the avionics buss because there were open optional circuit breakers at the time of the installation.
Here is a typical circuit breaker panel layout from the maintenance manual.  Personally I’d power it from the main buss not the avionics buss
OK, first point: An electrical busbar (often shortened to 'bus') only has one 's'. Buss means a kiss (https://www.dictionary.com/browse/buss). Some of the confusion probably originates from the common usage of Buss brand fuses. But 'Buss' is a shortening of the name of the German immigrant inventor Bussmann (https://dynamic.stlouis-mo.gov/history/peopledetail.cfm?Master_ID=2015).
Now to the second point. Mooney has long installed speed brakes at the factory during production using the Preciseflight STC (I once asked why and was told that the paperwork to get the speed brakes added to the type certificate was not worth the trouble), Since the OP's speed brakes were installed at the factory, there was presumably a reason for connecting them to the avionics bus. I would try to determine the factory configuration before changing anything (but that's just me -- Being an engineer myself, I assume that the factory engineers had a reason for whatever they did).
I agree, however, that it makes more sense to connect speed brakes to the main bus as the factory-installed electric speed brakes are in my 1994 M20J. The activation button on mine is on the left yoke horn and easily bumped when reaching for the heading knob on the Aspen PFD. After accidentally extending them once while changing course to extricate myself from icing -- and having them not fully retract -- I put a red ring on the circuit breaker and pull it now if there is any chance of encountering ice.
Skip
Skip
I looked through all of the factory K model schematics and could not find one that had a speed brake circuit breaker.  Your assumption on Mooney having powered them through the “avionics bus” may not be correct, it may have been moved in the decades since leaving the factory.
All of the Mooney 252 speed brakes were vacuum operated.
In 1997-98 when Mooney revived the K model and called it an Encore they used electric speed brakes.
You could well be right and probably are.
While true, they still had an electric control circuit, hence one would think a circuit breaker?
Mine has one.
Great test for the find the right CB Test....
I went through them all hoping it would stand out....
I had to go through a second time fully reading each label... before I found it... :)
Definitely good to have the colored switch caps on the important stuff.
Thanks for posting the pic!
