xavierde Posted January 5, 2020 Report Posted January 5, 2020 My aircraft type (252) doesn't seem to be on Garmin Pilot's performance data list. Closest one is the 231 but the performances are not the same. What do fellow 252 pilots use? Many thanks, Quote
carusoam Posted January 5, 2020 Report Posted January 5, 2020 Let’s ask a few people... @gsxrpilot and @aviatoreb and @FloridaMan About performance numbers.... They also are avid K pilots that have performance beyond the ordinary(?) 231... Best regards, -a- Quote
gsxrpilot Posted January 6, 2020 Report Posted January 6, 2020 As a fellow 252 pilot, all you need to know about performance is... shove all three levers forward and you'll get good performance But in all seriousness, what performance data are you looking for? I have a basic performance profile in ForeFlight but it's pretty basic. And the numbers are very rough. Climb is dependent on weight. Cruise is completely dependent on altitude. But here's what I have. Climb: 120 TAS, 26 gph, 800 FPM Cruise: 175 TAS, 9.5 gph Descent: 200 TAS, 9.5 gph, 500 FPM 1 Quote
xavierde Posted January 6, 2020 Author Report Posted January 6, 2020 This is what I get with Garmin (table supposedly from a 231): This one I can easily update with my numbers but then there is the full one: Quote
gsxrpilot Posted January 6, 2020 Report Posted January 6, 2020 Interesting. I don't have any data like that for my 252. I'm pretty confident though, I know what it will do in all phases of flight and in most conditions. I've got a folder full of pictures that document the performance in different situations. Quote
PJClark Posted January 6, 2020 Report Posted January 6, 2020 I have a Rocket. I use the M20K 231 aircraft type in Garmin Pilot, and then I open up the full table as above (you can't do this from the app, you have to do it from a web browser at FlyGarmin.com). I put in enough Rocket climb and cruise data points (but not all of them in that table...sheesh) to give me a sampling of what I think I would ordinarily do...and go with it. Like the Rocket, the 252 is going to be "better than the 231", so you know it's conservative, and should keep you safe. Quote
Greg252AY Posted January 8, 2020 Report Posted January 8, 2020 I used the 231 numbers then adjusted them for the 252. I have found that my 252 is around 5 to 7 knots faster than the posted 231 numbers and the fuel burn is very close. You can add 5 knots to all the 231 numbers and be pretty close Quote
One Whiskey Hotel Posted January 8, 2020 Report Posted January 8, 2020 19.4 gph on climbout is awfully low Quote
xavierde Posted January 8, 2020 Author Report Posted January 8, 2020 Exactly, that's why I don't want to use these tables. Quote
larryb Posted January 8, 2020 Report Posted January 8, 2020 Every plane is slightly different, every pilot flies it slightly differently. For example, in your climb do you climb at 500 fpm or 700 fpm or 900 fpm? And of course cruise speed varies quite a bit based on how you operate your engine. So this is one area you need to determine your own numbers using your own flying preferences. For me, I have an Encore with TKS, so it's not as fast as others. You don't have to fill out every box. For climb and descent I have just one line filled out with the numbers below. For cruise, I start at 10,000 feet and go up, it uses the 10,000 foot entry for altitudes below. Climb 600 fpm, 25 GPH, 120 KIAS Cruise 10,000 ft, 150 kt, 10.5 GPH. For every 1000 feet higher I add 2 kt. Descent -500 fpm, 180 Kt, 10.5 GPH Quote
