kortopates Posted July 29, 2019 Report Posted July 29, 2019 New AD affecting Trig transponders, e.g. Avidyne AXP340 and Bendix KIng KT74. See attachedAD 2019-13-03.pdf 1 Quote
rbridges Posted July 29, 2019 Report Posted July 29, 2019 Yeah, I saw that the other day. I need to check the serial # to my KT74. Quote
ArtVandelay Posted July 29, 2019 Report Posted July 29, 2019 It doesn’t apply if in a conventional aft facing radio rack, which I assume is every Mooney.Tom 2 Quote
kortopates Posted July 29, 2019 Author Report Posted July 29, 2019 8 minutes ago, ArtVandelay said: It doesn’t apply if in a conventional aft facing radio rack, which I assume is every Mooney. Tom It "applies" to everyone with a Trig transponder, in that you'll need to show one time compliance entry in your AD list that you at least found the AD non-applicable due to installation (standard AFT facing) The following details of the SB may help others Hardware 01/10/2018 version 1.0 This Hardware Service Bulletin applies to TT31 transponders approved under ETSO authorisation EASA.21O.643 Rev B and EASA.21O.906 Rev A, part number 00220-00-(XX) and part number 00225-00-(XX) which are: Serial number from 05767 to 09715; Modification Level 6 or below; Installed in an orientation which is NOT a conventional aft-facing avionics stack mounting. Quote
jaylw314 Posted July 29, 2019 Report Posted July 29, 2019 55 minutes ago, kortopates said: New AD affecting Trig transponders, e.g. Avidyne AXP340 and Bendix KIng KT74. See attachedAD 2019-13-03.pdf I assume this can be done by any IA--it doesn't need to be "inspected" at a radio shop, right? Quote
thinwing Posted July 29, 2019 Report Posted July 29, 2019 I’m not sure how a non aft facing install would be possible.It would have to be mounted in the aft bulkhead to be visible .Maybe a strange mounting in flight engineers position. Quote
rbridges Posted July 29, 2019 Report Posted July 29, 2019 53 minutes ago, ArtVandelay said: It doesn’t apply if in a conventional aft facing radio rack, which I assume is every Mooney. Tom Thanks, I didn't catch that part. RIF. Quote
kortopates Posted July 29, 2019 Author Report Posted July 29, 2019 45 minutes ago, jaylw314 said: I assume this can be done by any IA--it doesn't need to be "inspected" at a radio shop, right? Yes, by any A&P. 1 1 Quote
N201MKTurbo Posted July 29, 2019 Report Posted July 29, 2019 I wonder who got smacked in the head by a flying transponder? 1 Quote
Oldguy Posted July 29, 2019 Report Posted July 29, 2019 I was unaware there was such a high threshold for the equipment. "While testing a new model of transponder, it was detected that the retaining cam was not meeting the approved design criteria for crash safety shock in the aft direction (20g sustained)." (emphasis added) I guess if the transponder is located in a downward-facing position, it might have such a force on vertical impact (26g seats in a Cirrus?), but in a non-vertical 20g impact, it would seem as there would be several other things which might not survive. Like maybe me? 1 Quote
EricJ Posted July 29, 2019 Report Posted July 29, 2019 Thanks for posting this. Mine is aft-facing and earlier than the affected S/N range, but good to know and will do the compliance statement. Quote
jaylw314 Posted July 29, 2019 Report Posted July 29, 2019 17 minutes ago, EricJ said: Thanks for posting this. Mine is aft-facing and earlier than the affected S/N range, but good to know and will do the compliance statement. Looks like those affected have 90 days from issuance, which is August 27th, 2019. My annual is due before then anyways, so it works out ok 1 Quote
OR75 Posted July 29, 2019 Report Posted July 29, 2019 it always bothered me that this transponder had a retaining cam made of nylon (it bends easily if you over torque it) I wonder how many installs are not Aft facing - maybe in an old plane with a navigator - Quote
rbridges Posted July 30, 2019 Report Posted July 30, 2019 15 hours ago, Oldguy said: it would seem as there would be several other things which might not survive. Like maybe me? Oh, I'm sure there would be AD's on many of us if there was such a thing. 1 Quote
neilpilot Posted July 30, 2019 Report Posted July 30, 2019 17 hours ago, kortopates said: Yes, by any A&P. Since compliance due to mounting configuration is so simple, it’s unfortunate that the FAA didn’t allow for owner certification as they do with the 100 hr ignition switch AD. Quote
