Spurious Moppet Posted November 7, 2018 Report Posted November 7, 2018 Anyone know the best place for a ball and socket type muffler for an M20E? Dawley quoted me a month to overhaul. Also, check your mufflers. I almost died today. Flying at 8000 with low cielings below my CO monitor started beeping. Ended up almost losing consciousness several times. Opened the door and window to try to get air. Was able to do an ILS and land but it was close. Quote
charlesual Posted November 7, 2018 Report Posted November 7, 2018 Wow!! Great job having an electronic CO2 warning device! Probably saved your life and a great reminder to anybody who doesn’t have one to get one. Do it now!!Sent from my iPad using Tapatalk 1 Quote
Nokomis449 Posted November 7, 2018 Report Posted November 7, 2018 I replaced mine a few years ago with one from Knisely Welding. Theirs was a complete replacement, risers and all, but it was shipped immediately whereas noone else in the country had a muffler on the shelf and I didn't have time for an overhaul. Quote
Bob_Belville Posted November 7, 2018 Report Posted November 7, 2018 A MS member had an annual on his M20E done at AGL last month. On day one Lynn always checks the muffler so that a repair/replacement if needed can be underway asap. The muffler was shot and repairs would involve at least 3 weeks. But PowerFlow had a system in stock and is was on the way next day air. The annual including several other repairs was finished the morning of day 4. 2 Quote
Spurious Moppet Posted November 7, 2018 Author Report Posted November 7, 2018 On 11/7/2018 at 6:55 PM, Bob_Belville said: A MS member had an annual on his M20E done at AGL last month. On day one Lynn always checks the muffler so that a repair/replacement if needed can be underway asap. The muffler was shot and repairs would involve at least 3 weeks. But PowerFlow had a system in stock and is was on the way next day air. The annual including several other repairs was finished the morning of day 4. Expand Planning to go to AGL next year for annual btw. 1 Quote
Spurious Moppet Posted November 7, 2018 Author Report Posted November 7, 2018 On 11/7/2018 at 6:45 PM, charlesual said: Wow!! Great job having an electronic CO2 warning device! Probably saved your life and a great reminder to anybody who doesn’t have one to get one. Do it now!! Sent from my iPad using Tapatalk Expand Seriously. I would likely be dead now if not for that CO monitor. My wife would have been pissed. 1 1 Quote
J0nathan225 Posted November 7, 2018 Report Posted November 7, 2018 Superior Aero was able to get me a replacement muffler next day, might call them and see who they went through? Quote
Jim Peace Posted November 7, 2018 Report Posted November 7, 2018 Please give details on the monitor you have. Time to go shopping. Quote
Oldguy Posted November 7, 2018 Report Posted November 7, 2018 @Jim Peace Here is the info on the CO detector Dan now uses. Everyone, The folks at Sensorcon are willing to pass along a 20% discount to pilots on all of their products. At checkout use the code below. http://sensorcon.com/collections/carbon-monoxide-meters Discount code: aircraft2017 Quote
kortopates Posted November 7, 2018 Report Posted November 7, 2018 If you have the budget for a panel mount unit which is always on and integrated into the audio panel so you can't miss it, this is what I use which replaced my original clock. 1 Quote
thinwing Posted November 7, 2018 Report Posted November 7, 2018 On 11/7/2018 at 6:38 PM, Frozen Flying said: Anyone know the best place for a ball and socket type muffler for an M20E? Dawley quoted me a month to overhaul. Also, check your mufflers. I almost died today. Flying at 8000 with low cielings below my CO monitor started beeping. Ended up almost losing consciousness several times. Opened the door and window to try to get air. Was able to do an ILS and land but it was close. Expand Would be interested in your max readings and for how long....1500 ppm? Quote
carusoam Posted November 7, 2018 Report Posted November 7, 2018 Great pirep, frozen! Including pic with the detail. Best regards, -a- Quote
Spurious Moppet Posted November 7, 2018 Author Report Posted November 7, 2018 On 11/7/2018 at 7:35 PM, Jim Peace said: Please give details on the monitor you have. Time to go shopping. Expand https://www.sportys.com/pilotshop/carbon-monoxide-cockpit-monitor-17131.html Quote
Spurious Moppet Posted November 7, 2018 Author Report Posted November 7, 2018 On 11/7/2018 at 8:28 PM, thinwing said: Would be interested in your max readings and for how long....1500 ppm? Expand Vague memory of 240 or some number after i opened the door. The sensor was in the door strap handle. Quote
skydvrboy Posted November 7, 2018 Report Posted November 7, 2018 First and foremost... glad to hear you are safely on the ground. I needed everything from the exhaust mainfold back and got it from Knisley Exhaust. I wasn't in a hurry, but I do recall it taking a while. If I knew then what I know now, I might have sprung for the power flow exhaust and picked up a few HP's. I have the Sensorcon Industrial Pro CO detector and can't say enough good things about it. I now have it "panel mounted" with 3M sticky velcro. Quote
jaylw314 Posted November 7, 2018 Report Posted November 7, 2018 On 11/7/2018 at 6:38 PM, Frozen Flying said: Anyone know the best place for a ball and socket type muffler for an M20E? Dawley quoted me a month to overhaul. Also, check your mufflers. I almost died today. Flying at 8000 with low cielings below my CO monitor started beeping. Ended up almost losing consciousness several times. Opened the door and window to try to get air. Was able to do an ILS and land but it was close. Expand Holy crap! Glad you are safe! If you have portable O2, you might want to keep it handy tonight Quote
carusoam Posted November 7, 2018 Report Posted November 7, 2018 @DanM20C For those shopping... Sensorcon has a strong ‘installed base’ on MS... Gaurdian has the nice panel mount options... i went with Aeromedix before Dan did his research. CO sensors have some age limitations... getting it calibrated is a great idea! Best regards, -a- Quote
DanM20C Posted November 7, 2018 Report Posted November 7, 2018 @Frozen Flying, I'm so glad you made it down safely! Another save from a CO detector. This is a good time to plug the detectors that are offering discounts. Guardian has offered a 20% discount on all their CO products. It's very generous and may not last much longer. Code: coaware Sensorcon makes an excellent portable and they still have the 20% discount code active. Code: aircraft2017 I like redundancy so I have a Guardian, and 2 Sensorcons Cheers, Dan 3 Quote
thinwing Posted November 7, 2018 Report Posted November 7, 2018 On 11/7/2018 at 8:37 PM, Frozen Flying said: Vague memory of 240 or some number after i opened the door. The sensor was in the door strap handle. Expand Ok ,at that percentage (though not good)symptoms would be slight headache after 2 or 3 hours of exposure and death would be unlikely for typical E fuel duration flight.Glad you are ok 1 Quote
Spurious Moppet Posted November 7, 2018 Author Report Posted November 7, 2018 On 11/7/2018 at 9:05 PM, thinwing said: Ok ,at that percentage (though not good)symptoms would be slight headache after 2 or 3 hours of exposure and death would be unlikely for typical E fuel duration flight.Glad you are ok Expand Yeah it was probably higher since I was about lights out. I’ve done the hypoxia simulator trainer in the Navy several times and this was felt about like that but with a headache added in. Quote
Spurious Moppet Posted November 7, 2018 Author Report Posted November 7, 2018 Anyway the only reason I had a monitor was from hearing the story about the guy that woke up in his Mooney in a field in North Dakota or somewhere a couple years ago. Thanks to that him for sharing his story. 2 1 Quote
carusoam Posted November 7, 2018 Report Posted November 7, 2018 That guy... ...Is DanM20C. Spreading the word, a few pilots at a time... That crack appears tiny... but the HAZ heat affected zone... tells a bit more about how the metal was behaving... So if anyone hasn’t seen the crack... look closer to the weld line near the big reddish area... Something to look for at annual. Best regards, -a- 1 Quote
jaylw314 Posted November 7, 2018 Report Posted November 7, 2018 On 11/7/2018 at 9:52 PM, carusoam said: That guy... ...Is DanM20C. Spreading the word, a few pilots at a time... That crack appears tiny... but the HAZ heat affected zone... tells a bit more about how the metal was behaving... So if anyone hasn’t seen the crack... look closer to the weld line near the big reddish area... Something to look for at annual. Best regards, -a- Expand You wouldn't see that at annual, though, unless you cut open the muffler can. It would be nice if there was a way to detect impending heater failure @Frozen Flying, out of curiousity, do you use LOP or ROP for cruise? Quote
takair Posted November 7, 2018 Report Posted November 7, 2018 Just found a near identical crack in my muffler at annual. Got the same one month quote from Dawley. Called AWI and had an overhauled exhaust less than two weeks later. Best sending in risers too for jigging. Mine ended up needing overhaul as well. Quality seems really good and the fit was perfect. Quote
takair Posted November 7, 2018 Report Posted November 7, 2018 On 11/7/2018 at 9:43 PM, Frozen Flying said: Yeah it was probably higher since I was about lights out. I’ve done the hypoxia simulator trainer in the Navy several times and this was felt about like that but with a headache added in. Expand I’m curious, did you shut heat off and continue to get CO? You may want to check the heater box seals as well. Many leak as they age and then you have no way of isolating. When they leak, you feel heat year round....so added benefits in summer. 1 Quote
