Robert c Posted September 10, 2018 Report Posted September 10, 2018 Hi i am new to your forum. I am looking at getting a 1957 m20 that is all disassembled into pices the wood wings where cut just outside of the landing gear. All the electronics are pry 1960 ish with ifr and need to be replased. What is the value of this plane. I am looking for a good project to restore in my hanger. Pleae comment on what you think. Thank you Robert chubb
Robert c Posted September 10, 2018 Author Report Posted September 10, 2018 I do have pics if that will help
orionflt Posted September 10, 2018 Report Posted September 10, 2018 please post the pics, but if the wings were cut this plane may need new wing making it worthless. Brian
kerry Posted September 10, 2018 Report Posted September 10, 2018 3K with engine and prop. $300 without. My understanding is CS props for a O-320 are quite rare.
MBDiagMan Posted September 10, 2018 Report Posted September 10, 2018 I think the question is “how much will you pay me to haul it off?” If it has a wood tail, you need to plan on converting the tail. 3
Robert c Posted September 10, 2018 Author Report Posted September 10, 2018 If will nees new wings thin that i found some aluminum wing for sale in good shape. Just dont know what to offer the owner thay think that $10,000.is what it is worth trying to tell tham that its not
TTaylor Posted September 10, 2018 Report Posted September 10, 2018 4 minutes ago, Robert c said: If will nees new wings thin that i found some aluminum wing for sale in good shape. Just dont know what to offer the owner thay think that $10,000.is what it is worth trying to tell tham that its not For me they would have to pay me to move it. The value is what would the engine be worth minus the cost of the dumpster to put the rest of the plane in. The basic assumption are that the engine and prop are core value and will need to be rebuilt. It all depends on how much you want to own a wood wing "A". The value of the engine and prop are a few thousand at most if they have log books (without almost nothing).
Robert c Posted September 10, 2018 Author Report Posted September 10, 2018 Can i put aluminum wing on it if thay are a shortbody wing?
Jerry 5TJ Posted September 10, 2018 Report Posted September 10, 2018 It might be better to assume you are buying only the aluminum data plate. Then plan to rebuild the whole plane from parts, a few of which may be included with the purchase. 2 1
Robert c Posted September 10, 2018 Author Report Posted September 10, 2018 Thank you for all your help
Shiny moose Posted September 10, 2018 Report Posted September 10, 2018 IMHO Jerry is correct, your buying the data plate and that’s not worth much for an old wood wing(I wouldn’t give any money for it) . If your wanting a project go for it. If you want something that you will fly in the next few years add another 15K and buy a solid corrosion free but ugly well flying metal mooney that needs paint, interior, with basic radios. You will save money and time!!!
kerry Posted September 11, 2018 Report Posted September 11, 2018 There are m20a projects out there where you can rebuild a wood wing. As far as a project it would be better to get a M20A with a 180hp.
MBDiagMan Posted September 11, 2018 Report Posted September 11, 2018 3 hours ago, Robert c said: Converted tail That sawed off wing is tough to look at. I realize that they probably did that in order to transport it. If so I hope it was an absolute last resort. Very sad.
steingar Posted September 11, 2018 Report Posted September 11, 2018 I wouldn’t take it for free. Plenty of derelict airplanes that need restoration. This one just needs a mess of termites. Or a good fire. 1
carusoam Posted September 11, 2018 Report Posted September 11, 2018 There are two wood wing Mooney projects around here... One recently had its wheels come through the wing... Do some searching you will probably find them. When it comes to value... it won’t be measured in dollars. As for price of an aluminum wing... 10Amu must be the standard price. Trying to buy one to fit an M20A probably goes way past economic sense... welcome aboard, Robert. The good news.... you already have an aluminum tail update! Are you a mechanic? Or a carpenter? Best regards, -a- 2
Guest Posted September 11, 2018 Report Posted September 11, 2018 A few positive things with this plane, it won’t have leaky fuel tanks or corroded spar caps. There have to be better projects to choose from. Clarence
MikeOH Posted September 11, 2018 Report Posted September 11, 2018 It is painful to look at what's left of that poor wing. This thing falls deeply into the "Run, Forrest, run!!" category. 2
0TreeLemur Posted September 11, 2018 Report Posted September 11, 2018 Wow- perhaps the most creative application of a sawzall that I've seen...
Hank Posted September 11, 2018 Report Posted September 11, 2018 Cutting that wing makes me sad . . . . It will need to be completely rebuilt, starting with a new spar. You may be able to salvage and reuse some ribs and some of the outer covering. The fuse and engine mount may be in good shape, along with the gear and tail. Flaps and ailerons will need close checking, certainly the control rods for them were also cut. I've heard of used metal wings selling in the $8-10K range, but I have no idea what paperwork would be required to put a metal wing on an A model. If you do buy this plane, send me a chunk of wing spar and I will make you a Mooney Remembrance item . . . . .
Mooney-Mark Posted September 11, 2018 Report Posted September 11, 2018 I would not touch it. You will have so much more into it than it is worth and never get a fraction of it out on sale. Remember that you also have old obsolete avionics and electronics that will have to be replaced. If you want a project, find a nice homebuilt. That will be much more practical and rewarding in the end. Unfortunately, the airplane you are looking at is a "parts" airplane at best.
M204ever Posted September 11, 2018 Report Posted September 11, 2018 Robert, thanks for the insight into the wood wing. I never thought to be able to see a cut view :). Mission impossible...
MyNameIsNobody Posted September 11, 2018 Report Posted September 11, 2018 9 hours ago, Fred_2O said: Wow- perhaps the most creative application of a sawzall that I've seen... Somewhere the Reaper scoffs quietly... 1
MB65E Posted September 11, 2018 Report Posted September 11, 2018 Are the outboard wings still available? It would be neat to see if some one like Steve Wolf or any other wood builder could rebuild the wings per drawings and old dimensions. If that were the case, it would probably cost at least 30-40k for some one to rebuild the wing from scratch. The rest of the project looks unmolested. That engine case is ancient. I’ve only seen one Like that and it was on the first E model that Alan cut up. It’s not like it’s a spitfire project or anything. However, to some it’s not about the money. Anything is possible, but it might cost more than a nice J by the time you are finished. I keep thinking of how neat it must have been to be at the Mooney factory between 1955 and 1965! I can’t imagine having a new wood wing Mooney in 1959, or my 65e brand new back in 1965! I bet the wood wing airplane fly nice. Wood wing Decathlon’s sure have more soul to them than the metal wing airframes. -Matt 2
