MBDiagMan Posted August 31, 2018 Report Posted August 31, 2018 I just moved from a ‘63 C to a 66 F. I had gotten familiar and comfortable with the C. Many things are alike on the F and a few things are seemingly to me much different. A friend of mine has an F with a three axis auto pilot, assumedly a Britain. I flew it before buying mine and the controls, at least the elevator seemed really stiff as opposed to my C that had no autopilot at all. Now that I have MY F, it has a non functional PC. It has heck for stiff elevator control. It is giving me difficulty getting used to it. It seems that it is as if you run the elevator with the trim wheel rather than the yoke. The controls on my C with no autopilot are almost as floppy as those on my little Cessna 140. Would removing the Britain components have anything to do with this? Would fixing the autopilot, if I could find parts, have anything to do with this? Has anyone ever experienced this or should I just throw in the towel and send in my pilot certificate. Thanks in advance for your comments and sha4ing your experience.
lamont337 Posted August 31, 2018 Report Posted August 31, 2018 Does it feel the same on the ground as it does in flight?
takair Posted August 31, 2018 Report Posted August 31, 2018 Would start with lube. It does make a difference. In particular, I find the the yoke shaft feed through the panel makes a difference. 1
N201MKTurbo Posted September 1, 2018 Report Posted September 1, 2018 2 hours ago, takair said: Would start with lube. It does make a difference. In particular, I find the the yoke shaft feed through the panel makes a difference. Plus 2 Most Mooneys are not properly lubed. It makes a huge difference. Remember a greasy Mooney is a happy Mooney! 3
kmyfm20s Posted September 1, 2018 Report Posted September 1, 2018 Clean off the old 40 year old grease brefore applying the new grease the best you can. I know every time my plane comes out of annual the crntrol feel noticeable more lubed then it slowly reverts back but never have been unusually stiff.
cliffy Posted September 1, 2018 Report Posted September 1, 2018 Lube lube lube then check under your panel to see if anything is holding the yoke from moving- wire bundles, radio rack slipping, etc. My guess is that proper lube and checking under the panel will solve the issue
MIm20c Posted September 2, 2018 Report Posted September 2, 2018 I assume it’s well lubed as you just picked it up from DM. The control forces feel a lot different from my C to a long body. Never been in a mid body so I can’t comment on that.
Yetti Posted September 2, 2018 Report Posted September 2, 2018 Lube... And in flight with the Brittian on it is pretty stiff, but you only need small movements to make things happen. There should be a way to turn the Brittian off. Switch or Plunger.
N201MKTurbo Posted September 2, 2018 Report Posted September 2, 2018 The elevator control system changed at least three times through the different models. There were bungees with springs, bungees without springs and bob weights. They all feel different.
RobertGary1 Posted September 3, 2018 Report Posted September 3, 2018 I find the elevator on the C to require less force than my F, especially pulling back while taxiing. -Robert
Danb Posted September 3, 2018 Report Posted September 3, 2018 A chance the yoke block, eyeball unit needs lubing or the eyeball is stuck,, mine was, DMax and Weber never saw one seized if so replacement is necessary. A real pia.
Prior owner Posted September 16, 2018 Report Posted September 16, 2018 What should be used to lubricate the yoke bushing in the panel? My manual shows a symbol (circle with cross inside) but doesn’t specify what that particular symbol represents...
Andy95W Posted September 16, 2018 Report Posted September 16, 2018 3 hours ago, PilotCoyote said: What should be used to lubricate the yoke bushing in the panel? My manual shows a symbol (circle with cross inside) but doesn’t specify what that particular symbol represents... Powdered graphite- but you're right, it takes some puzzling through it to get the answer. The legend shows 2 circles, neither have a cross inside. The other circle is labeled 5606 hydraulic fluid and is used for the hydraulic reservoir. Additionally, Revision D of the Service Manual from 1981/83 shows the symbol correctly and says either powdered graphite or Tri-Flow teflon spray.
