DVA Posted June 4, 2017 Report Posted June 4, 2017 We use the borescope extensively to look at things that would otherwise require expensive and time consuming disassembly. I also believe in Mike Busch's theory of MIF - the maintenace induced failure, using the borescope can reduce the chances of MIFs while saving owners a lot of time and money. I thought I'd share a video borescope look at the hot section of a turbo on a M20M. https://www.facebook.com/vanallenairmotive/videos/463022524065352/ Enjoy. DVA 3 Quote
RLCarter Posted June 4, 2017 Report Posted June 4, 2017 The bendable eye, a little hard to drive at first but well worth it Quote
carusoam Posted June 4, 2017 Report Posted June 4, 2017 (edited) Am i the last guy to sign up for FB? Dave made me do it. It was worth it, to see what's up that pipe... I get the feeling that some changes are coming to the industry. The installation of a couple of key inspection holes the size of a dental camera... Dave, why is there lubricant only on one end of the shaft and not the other? thanks for sharing the video. Best regards, -a- Edited June 4, 2017 by carusoam Quote
DVA Posted June 4, 2017 Author Report Posted June 4, 2017 Dave, why is there lubricant only on one end of the shaft and not the other? thanks for sharing the video. Best regards, -a- Lol. I'm not taking responsibility for your new FB addiction. :-)The picture of the wastegate is upside down due to the way the borescope entered the area. So you are seeing lubricant only on the top where the actuator connects to the valve. There is nothing to lubricate on the bottom side. 1 Quote
ArtVandelay Posted June 4, 2017 Report Posted June 4, 2017 Am i the last guy to sign up for FB? Nope, I'm still FB free. Quote
aviatoreb Posted June 4, 2017 Report Posted June 4, 2017 I'm on FB so I can cyber-watch my kids... Quote
Guest Posted June 4, 2017 Report Posted June 4, 2017 23 minutes ago, teejayevans said: Nope, I'm still FB free. There are a few hold outs left, I don't intend joining. Clarence Quote
Hank Posted June 5, 2017 Report Posted June 5, 2017 3 hours ago, M20Doc said: There are a few hold outs left, I don't intend joining. Clarence Me neither. Anything I need there, my wife lets me know. Me, I'm here. Quote
LANCECASPER Posted June 5, 2017 Report Posted June 5, 2017 22 hours ago, DVA said: We use the borescope extensively to look at things that would otherwise require expensive and time consuming disassembly. I also believe in Mike Busch's theory of MIF - the maintenace induced failure, using the borescope can reduce the chances of MIFs while saving owners a lot of time and money. I thought I'd share a video borescope look at the hot section of a turbo on a M20M. https://www.facebook.com/vanallenairmotive/videos/463022524065352/ Enjoy. DVA Wow N9153Z gets a colonoscopy! Quote
orionflt Posted June 5, 2017 Report Posted June 5, 2017 I also use the bore scope to inspect in my wings tail, and belly. Gives me a much better look then just using a mirror, Also lets me look in some of the nook and cranny areas Brian 1 Quote
