nickmatic Posted June 1, 2017 Report Posted June 1, 2017 I posted about a fuel smell in my cockpit a while back when I bought my M20K and just have been keeping the right tank below full up until now in order to not have to deal with it. It has worked but all of a sudden recently I can only fill the tank to about 18 gallons before getting wet carpet on the right side of the plane. Time to get this fixed. I did a lot of searching online and in this forum and I see Weep No More in Willmar, MN, WetWingOlogists East in Fort Lauderdale, FL, and Propellorhead Aviation in Winter Haven, FL. Wondering if anyone knows a reputable shop a little further north on the east coast? The plane is in South Carolina at the moment and I'd like to stop somewhere on the way back to New York (where I live) to get the tank seal dealt with. I'm open to having it patched vs completely resealed if that's possible. Quote
DVA Posted June 1, 2017 Report Posted June 1, 2017 We're in Allentown PA at KXLL which is right along your route. I'd be happy to chat if you'd like. Best regards,Dave484-224-0105 Quote
DonMuncy Posted June 1, 2017 Report Posted June 1, 2017 Before you start worrying about patching, have someone check the gasket on the sender unit just behind the upholstery on the right side. It may be as easy as tightening 6 screws. 2 Quote
nickmatic Posted June 1, 2017 Author Report Posted June 1, 2017 On 6/1/2017 at 1:03 AM, DonMuncy said: Before you start worrying about patching, have someone check the gasket on the sender unit just behind the upholstery on the right side. It may be as easy as tightening 6 screws. Expand Good call, thanks for the tip. Though if the problem only shows when I'm above 18 gallons in the tank, doesn't this indicate a tank seal issue? Quote
Hank Posted June 1, 2017 Report Posted June 1, 2017 I flew down to FXE from Furthest West Virginny to have Edison strip and seal my tanks. Great service and good pricing, with MAPA discount, too. Quote
DonMuncy Posted June 1, 2017 Report Posted June 1, 2017 On 6/1/2017 at 1:13 AM, nickmatic said: Good call, thanks for the tip. Though if the problem only shows when I'm above 18 gallons in the tank, doesn't this indicate a tank seal issue? Expand I don't remember for certain, but I think you have 37 gallon tanks, and the sender units may be mounted just above the center of the tank. It may come out about right. Quote
nickmatic Posted June 1, 2017 Author Report Posted June 1, 2017 On 6/1/2017 at 1:20 AM, DonMuncy said: I don't remember for certain, but I think you have 37 gallon tanks, and the sender units may be mounted just above the center of the tank. It may come out about right. Expand OK fair point. Definitely worth checking out thanks Quote
orionflt Posted June 1, 2017 Report Posted June 1, 2017 On 6/1/2017 at 12:35 AM, DVA said: We're in Allentown PA at KXLL which is right along your route. I'd be happy to chat if you'd like. Best regards, Dave 484-224-0105 Expand I'll have to stop over one of these days and check out your operation, Last time i was over you were just starting to move in. Brian Quote
carusoam Posted June 1, 2017 Report Posted June 1, 2017 (edited) Wet carpet is a sign that comes with the aged cork or rubber seals for the Fuel Level indicator. take the interior panel off and look what's behind it... This is something you can do or get done. No need to wait. Fuel in the cabin is my least favorite type of leak... make it stop. Best regards, -a- Edited June 1, 2017 by carusoam Quote
helitim Posted June 1, 2017 Report Posted June 1, 2017 Not that I'm suggesting you use a non approved part but, if you need seals, NAPA sells an exact replica of the seal for about $2. Takes just a few minutes to install once the fuel is drained from the tank to below the sender level. Quote
buddy Posted June 1, 2017 Report Posted June 1, 2017 Check the inboard and outboard sending unit gaskets there are 2 in each wing. I tried patching my leaking tanks a couple of times when I owned my 201 and it never worked out so I ended up bring it to Edison, wet wing in FXE and he did a great job resealing both tanks. Quote
nickmatic Posted June 1, 2017 Author Report Posted June 1, 2017 Thanks for all the comments regarding the fuel senders. Sounds like this is a serious possibility. I've asked them to take a look and I'll report back. Would be great if it's that easy! 1 Quote
Drumstick Posted June 2, 2017 Report Posted June 2, 2017 Rusty at ICS services in Hummel County Field VA does tanks. Not sure what he will charge total for the job but his shop rate is $60/hr. Quote
nickmatic Posted June 3, 2017 Author Report Posted June 3, 2017 On 6/2/2017 at 10:51 PM, Drumstick said: Rusty at ICS services in Hummel County Field VA does tanks. Not sure what he will charge total for the job but his shop rate is $60/hr. Expand Good option thanks! Quote
