Retz Posted October 14, 2015 Report Posted October 14, 2015 I'm about to install an 830 on a 252. We're is the accepted or best place to put the OAT sensor? Sent from my iPad using Tapatalk Quote
ArtVandelay Posted October 14, 2015 Report Posted October 14, 2015 I'm about to install an 830 on a 252. We're is the accepted or best place to put the OAT sensor? Sent from my iPad using Tapatalk Mine (J) is at the air inlet for the pilots footwell vent. 1 Quote
PTK Posted October 14, 2015 Report Posted October 14, 2015 I have the 800 and the Davtron M655. I have one sensor in each vent. Nice place for them. Quote
carusoam Posted October 14, 2015 Report Posted October 14, 2015 (edited) The 90's factory installed location is out on the wing on the underside. It is a small bump. So small it is a challenge to remember exactly where it is. If you fly in IMC it is helpful to have the high precision and accuracy afforded by the digital JPI display, with the sensor located in the factory position. Advantage: Away from engine heat and out of the sunshine. Disadvantage: Long wire runs. Please note: I am a PP, not a mechanic. Best regards, -a- Edited October 14, 2015 by carusoam Quote
Bob - S50 Posted October 14, 2015 Report Posted October 14, 2015 Ours is in the same place as teejayevans and daver328 Bob Quote
Houman Posted October 14, 2015 Report Posted October 14, 2015 Ours is in the same place as teejayevans and daver328 Bob I have it the same place as Carusoam, under the wing. I would have tought the position in the vent would get a good amound of prop air in it, wondering if that would influence the data ? Quote
Retz Posted October 14, 2015 Author Report Posted October 14, 2015 Where under the wing? Can you put up a picture please. Thanking you Sent from my iPhone using Tapatalk Quote
Houman Posted October 14, 2015 Report Posted October 14, 2015 I have mine under the 3rd access panel I belive, on the left side, I think pretty much aligned with the stall tab. Quote
ArtVandelay Posted October 14, 2015 Report Posted October 14, 2015 I have it the same place as Carusoam, under the wing. I would have tought the position in the vent would get a good amound of prop air in it, wondering if that would influence the data ? Most of the hot air passes underneath the plane, my original wing mount seems to match my 830 vent mount, or at least as close as I can tell from little analog temperature gauge. Quote
Bob_Belville Posted October 14, 2015 Report Posted October 14, 2015 Mine is on the left side of the fuselage, below the rear window, sticking out, causing drag. It must be costing me 3-4 kts. (EDM 930 but that wouldn't matter.) Quote
PTK Posted October 14, 2015 Report Posted October 14, 2015 (edited) I have it the same place as Carusoam, under the wing. I would have tought the position in the vent would get a good amound of prop air in it, wondering if that would influence the data ? I think the point is to have the probe be bathed by and sample the temperature of the outside air. As long as it's not sampling exhaust air, i.e. underneath the plane, it's fine. Edited October 14, 2015 by PTK Quote
Marauder Posted October 14, 2015 Report Posted October 14, 2015 I think the point is to have the probe be bathed by and sample the temperature of the outside air. As long as it's not sampling exhaust air, i.e. underneath the plane, it's fine. Being a redundant kind of guy I have multiple OAT indicators on my plane. The first being the factory unit, analog that now sits on the side window. The second is the JPI's sensor that is installed in the pilot side air intake and the third is the Aspen's which is resident in the RSM on the fuselage, just aft of the baggage door. Having watched all 3, I found the Aspen is always a few degrees warmer than the JPI reading and the factor unit usually agrees closely with the JPI. In this photo the Aspen is showing 57° F and the JPI at 54°. Sent from my iPad using Tapatalk Quote
PTK Posted October 14, 2015 Report Posted October 14, 2015 (edited) This made me think of something else. I have in the airplane a few instruments that provide voltage info: The JPI, the M655 and the stormscope has a battery monitor. All seem to be different! Is this normal?! Chris, how do you draw pretty red circles in pics?!! Edited October 14, 2015 by PTK Quote
Bob_Belville Posted October 14, 2015 Report Posted October 14, 2015 There's a parameter adjust for either the Aspen or JPI or both. I think I change the JPI after comparing all 3 in the hanger. Then I removed the one in the pilot window and plugged the hole with silicone caulk. Picked up 3-4 kts. Quote
carusoam Posted October 14, 2015 Report Posted October 14, 2015 I'm surprised the Aspen doesn't convert to °F when it knows where it is flying. Best regards, -a- Quote
ArtVandelay Posted October 14, 2015 Report Posted October 14, 2015 I'm surprised that JPI can't send my GTN650 the OAT, it sends it the fuel stats. How big is the Aspen probe temp probe anyway? The JPI probe is big: Quote
Marauder Posted October 14, 2015 Report Posted October 14, 2015 This made me think of something else.I have in the airplane a few instruments that provide voltage info: The JPI, the M655 and the stormscope has a battery monitor. All seem to be different! Is this normal?! Chris, how do you draw pretty red circles in pics?!! iPad app called photo editor by Axiem Systems. Sent from my iPad using Tapatalk Quote
Marauder Posted October 14, 2015 Report Posted October 14, 2015 I'm surprised the Aspen doesn't convert to °F when it knows where it is flying. Best regards, -a- Going from F to C is user selectable. I keep it at C to make it easier match for icing math. ️ Sent from my iPad using Tapatalk Quote
Marauder Posted October 14, 2015 Report Posted October 14, 2015 I'm surprised that JPI can't send my GTN650 the OAT, it sends it the fuel stats. How big is the Aspen probe temp probe anyway? The JPI probe is big: The probe for the Aspen is part of the antennae. Sent from my iPad using Tapatalk Quote
ArtVandelay Posted October 14, 2015 Report Posted October 14, 2015 The probe for the Aspen is part of the antennae. Antenna? For what? Aspen talks to you GTN-650, yes? Quote
PTK Posted October 14, 2015 Report Posted October 14, 2015 I'm surprised that JPI can't send my GTN650 the OAT, it sends it the fuel stats. How big is the Aspen probe temp probe anyway? The JPI probe is big: Exactly how mine is! Quote
KSMooniac Posted October 14, 2015 Report Posted October 14, 2015 The best spot is under the wing, just outboard of the gear in an inspection panel. That is where the factory put them in the J+ models and for good reason. Out of the sun, out of the exhaust, and out of the engine heat streams. It is also out of the way of getting bumped easily. Running the wire takes less than an hour if you already have an interior panel out. I put a Davtron probe on my left wing many years ago, and just added a JPI probe under my right wing at the original factory OAT location. It is worth doing it properly, especially if you fly in IMC where you'd really like to know if it is 31 degrees or 33 degrees! 1 Quote
Marauder Posted October 14, 2015 Report Posted October 14, 2015 Antenna? For what? Aspen talks to you GTN-650, yes? The Aspens have their own GPS antenna for emergency backup purposes. If you lose the GTN, the flight plan is stored in the Aspen and the Aspen reverts to an emergency GPS mode which is supplied by the Aspen. Sent from my iPad using Tapatalk Quote
ArtVandelay Posted October 14, 2015 Report Posted October 14, 2015 The Aspens have their own GPS antenna for emergency backup purposes. If you lose the GTN, the flight plan is stored in the Aspen and the Aspen reverts to an emergency GPS mode which is supplied by the Aspen. Sent from my iPad using Tapatalk I thought that was only for MFD version, does just PFD have this as well? I may not fully understand the Aspen offerings. Sorry for the thread shift.... Quote
Marauder Posted October 15, 2015 Report Posted October 15, 2015 I thought that was only for MFD version, does just PFD have this as well? I may not fully understand the Aspen offerings.Sorry for the thread shift.... The PFD comes standard with the backup GPS. The MFD shares the GPS with the PFD but you can also buy the updated backup for the MFD. I tried it a couple of times in flight by shutting off the GTN. An error popped and I got the emergency RSM GPS message. Features like these are why I picked the Aspen over the G500. Sent from my iPad using Tapatalk Quote
