Freddb34 Posted September 17 Report Posted September 17 It's finally happening! I'm getting my first Mooney, a 1964 M20E. This will be the fourth, and hopefully, final aircraft I will ever purchase (a Piper Colt and 2 Cherokee 140's). Very excited to be a part of this community. It's fairly low time, 450SMOH on the I0-360, GPS WAAS equipped with an Avidyne 440 and King KX-155. It has an engine analyzer, recently replaced bladders in the wing tanks, and ADSB-Out. Even the Mooney PC control works! Really needed something to get from RI and SWFL to the Charleston SC area to see my new grandson and this fits the bill perfectly. The only issue I'm running into is that J-bar gear control. I can get it out of the "Down" position but getting it back up and in has proven to be a pain, literally (bad rotator cuff in the right shoulder.) I'm sure I'll get it sorted. Wanted to say hi to everyone at MooneySpace and looking forward to many discussions! Thanks! 4
Paul Thomas Posted September 17 Report Posted September 17 Welcome. I don't have a J bar but based on everything I've read, if you slow the airplane, it makes a huge difference in the amount of force needed. I believe that's even more so on retraction. The amount of gear preload makes a difference on how easy is it to move the gear; that should be checked if it's difficult to move. If it continues to be a pain, it may be easier to fly right seat.
Greg_D Posted September 17 Report Posted September 17 31 minutes ago, Paul Thomas said: Welcome. I don't have a J bar but based on everything I've read, if you slow the airplane, it makes a huge difference in the amount of force needed. I believe that's even more so on retraction. The amount of gear preload makes a difference on how easy is it to move the gear; that should be checked if it's difficult to move. If it continues to be a pain, it may be easier to fly right seat. Not very many of these older Mooneys that have brakes on the right side...
Freddb34 Posted September 17 Author Report Posted September 17 4 minutes ago, Greg_D said: Not very many of these older Mooneys that have brakes on the right side... I don't believe the one I'm getting does. I know it's more technique than strength...I just need to get that system down.
cliffy Posted September 17 Report Posted September 17 To get that last "push" into the gear down position make sure you are not trying to crush the leather boot at the bottom of the Johnson bar. It can get bunched up between the handle and the nose ger well. Also if you have thick carpet on the nose gear well between the bar the the well that can cause difficulty in getting the gear to lock down. As mentioned - gear rigging and over center torque may need to be checked also along with a real good lubrication of the gear. I have a metal shoulder and I can get it up and down with a little finesse. Gear going up -a slight push on the control wheel to help reduce the load really helps. Going down really seems no problem for me. Don't forget to pay attention to the Mooney specific AD for gear rigging check and lubrication every annual OR 100 HRS flight time. Both are limiting. Enjoy the Mooney You'll have fun with it.
AndreiC Posted September 17 Report Posted September 17 As a fellow Cherokee-to-short body Mooney, take your time with an instructor to perfect your landings. After 15+ years in the Cherokee, it took me several months to get used to the short throw of the controls on the M. It also really helps to say to yourself “pull on the yoke, pull on the yoke” as long as the nosewheel is up; don’t let it slam down.
Fly Boomer Posted September 17 Report Posted September 17 53 minutes ago, Freddb34 said: This will be the fourth, and hopefully, final aircraft I will ever purchase (a Piper Colt and 2 Cherokee 140's). I think your new ride will outrun your previous Pipers. 2
Fritz1 Posted September 17 Report Posted September 17 welcome aboard, probably best to jack it up, check the gear rigging, lube all the zerk fittings and practice retraction, gear doors may be rigged too tight, if that is the only issue the new bird has you are a lucky SOB 1
Freddb34 Posted September 17 Author Report Posted September 17 15 minutes ago, Fritz1 said: welcome aboard, probably best to jack it up, check the gear rigging, lube all the zerk fittings and practice retraction, gear doors may be rigged too tight, if that is the only issue the new bird has you are a lucky SOB I'm having the pre buy done here shortly. I really hope I can get into the plane while it's on the ground and work the gear a few times just to get the feel of it. Appreciate the warm welcome guys! This is going to be great.
Freddb34 Posted September 17 Author Report Posted September 17 32 minutes ago, Fly Boomer said: I think your new ride will outrun your previous Pipers. I'm really looking forward the extra speed. Getting to see my grandson more than just once or twice a year as I passed thru in my Cherokee is the main driver for getting it. 1
Flyler Posted September 18 Report Posted September 18 Do yourself a favor and have someone who is *knowledgeable and experienced* about Mooney gear check the rigging. 1
hammdo Posted September 18 Report Posted September 18 Working the gear in the air vs ground is not the same — the forces are different for sure… Just a heads up… -Don 1
Freddb34 Posted September 18 Author Report Posted September 18 On 9/17/2025 at 2:14 PM, AndreiC said: As a fellow Cherokee-to-short body Mooney, take your time with an instructor to perfect your landings. After 15+ years in the Cherokee, it took me several months to get used to the short throw of the controls on the M. It also really helps to say to yourself “pull on the yoke, pull on the yoke” as long as the nosewheel is up; don’t let it slam down. Thank you! The first time I flew it, my buddy (the seller) was in the right seat. As soon as I was on downwind with the gear down and flaps out, he said "It's just a Cherokee....a really fast Cherokee!" I actually got it down and stopped in the same distance he demonstrated for me. I even got an "eyebrow raise" getting stopped so well! I do know that it's going to take a few hours to get everything down (no pun intended) pat, but really looking forward to this next step in my airplane ownership journey!
Hank Posted September 18 Report Posted September 18 1 hour ago, Freddb34 said: Thank you! The first time I flew it, my buddy (the seller) was in the right seat. As soon as I was on downwind with the gear down and flaps out, he said "It's just a Cherokee....a really fast Cherokee!" I actually got it down and stopped in the same distance he demonstrated for me. I even got an "eyebrow raise" getting stopped so well! I do know that it's going to take a few hours to get everything down (no pun intended) pat, but really looking forward to this next step in my airplane ownership journey! The first time I took a Piper pilot to ride, we were on final over the trees about 1/4 mile from the displaced threshold and I pulled the throttle to idle. His head spun toward me, then looked back out front. As I taxied clear of the runway (3000' long minus abiut 10% for the displacement, only one exit 2000' from that end), he looked at me wide-eyed and said, if I'd pulled the throttle in my Cherokee when you did, I'd have gone down in the trees. But in your plane, nothing happened! You're gonna like your new Mooney! It's the same as mine, but you have 20 more hp.
kortopates Posted September 18 Report Posted September 18 4 minutes ago, Hank said: The first time I took a Piper pilot to ride, we were on final over the trees about 1/4 mile from the displaced threshold and I pulled the throttle to idle. His head spun toward me, then looked back out front. As I taxied clear of the runway (3000' long minus abiut 10% for the displacement, only one exit 2000' from that end), he looked at me wide-eyed and said, if I'd pulled the throttle in my Cherokee when you did, I'd have gone down in the trees. But in your plane, nothing happened! You're gonna like your new Mooney! It's the same as mine, but you have 20 more hp. True, the Arrow has a glide range with gear and flaps out about the same as a brick! 1
Hank Posted September 18 Report Posted September 18 4 minutes ago, kortopates said: True, the Arrow has a glide range with gear and flaps out about the same as a brick! I've always heard it described as "has the glide ratio of a sewer lid," but "like a brick" is gentler. 1
Ibra Posted September 18 Report Posted September 18 20 minutes ago, kortopates said: the Arrow has a glide range with gear and flaps out about the same as a brick! Follow the brick 6 10
C.J. Posted September 18 Report Posted September 18 On 9/17/2025 at 1:24 PM, Freddb34 said: It's finally happening! I'm getting my first Mooney, a 1964 M20E. This will be the fourth, and hopefully, final aircraft I will ever purchase. Congrarulations. When you can, post some photos.
Mooney in Oz Posted September 18 Report Posted September 18 4 hours ago, Freddb34 said: I actually got it down and stopped in the same distance he demonstrated for me. I even got an "eyebrow raise" getting stopped so well! It looks as though you are doing well with your landings, which is a good thing as many new Mooney pilots tend to land too fast that can result in more than a bad hair day. You may already may be aware, but be mindful of harsh brake application as older Mooney brakes tend to be sensitive if applied too hard that can result in flat spotted tyres. Congrats and enjoy the ride.
Hank Posted September 19 Report Posted September 19 46 minutes ago, Mooney in Oz said: You may already may be aware, but be mindful of harsh brake application as older Mooney brakes tend to be sensitive if applied too hard that can result in flat spotted tyres. @Freddb34, this is very correct. The best way to stop is to cross the numbers at the right speed. I don't use my brakes until slowing to 50 mph. 1
kortopates Posted September 19 Report Posted September 19 2 hours ago, Mooney in Oz said: You may already may be aware, but be mindful of harsh brake application as older Mooney brakes tend to be sensitive if applied too hard that can result in flat spotted tyres. Excellent point but its actually really nothing to do with with older Mooney's but weight. The longbody's especially are the easiest to lock up the wheels with their heavier weight/faster landing speed and beefier double puck brakes which can flat a tire immediately. With all Mooney's it's important to not touch the brakes immediately after touchdown since speed is till high and their isn't much weight on the wheels yet making them easy to flat spot if not flat them. Its important to initially slow down with aerodynamic braking where the savvy pilot holds the nose wheel off as long as possible and only applies brakes after the aircraft has slowed down adequately that the brakes won't lock up soon as you touch them. That speed varies by aircraft weight. 2 1
PeterRus Posted September 19 Report Posted September 19 21 hours ago, Hank said: ... about 1/4 mile from the displaced threshold and I pulled the throttle to idle. His head spun toward me, then looked back out front.... he looked at me wide-eyed and said, if I'd pulled the throttle in my Cherokee when you did, I'd have gone down in the trees. But in your plane, nothing happened! In a Diamond DA20 during PPL training power idle was on downwind at the numbers with first flaps...
Skates97 Posted September 19 Report Posted September 19 23 hours ago, Hank said: The first time I took a Piper pilot to ride, we were on final over the trees about 1/4 mile from the displaced threshold and I pulled the throttle to idle. His head spun toward me, then looked back out front. As I taxied clear of the runway (3000' long minus abiut 10% for the displacement, only one exit 2000' from that end), he looked at me wide-eyed and said, if I'd pulled the throttle in my Cherokee when you did, I'd have gone down in the trees. But in your plane, nothing happened! You're gonna like your new Mooney! It's the same as mine, but you have 20 more hp. My first flight in a Cessna was after I think about 400 hours in our Mooney. We rented on in Maui and took a CFI along. I told him I'd never sat in a Cessna but to just give me speeds and power settings. Two hours later I was coming in to land and when I was where I pull power on the Mooney I pulled the power. He immediately reached over and shoved it back in as I said "sorry, I'm used to my Mooney." 1
EricJ Posted September 19 Report Posted September 19 31 minutes ago, Skates97 said: My first flight in a Cessna was after I think about 400 hours in our Mooney. We rented on in Maui and took a CFI along. I told him I'd never sat in a Cessna but to just give me speeds and power settings. Two hours later I was coming in to land and when I was where I pull power on the Mooney I pulled the power. He immediately reached over and shoved it back in as I said "sorry, I'm used to my Mooney." Cherokees are much worse, especially a straight-wing Arrow, that has a ton of drag when the gear is down. I flew a friend's experimental that is kind of Mooney-like but has stubbier wings and a higher wing loading. It's fairly fast but when I reduced power for descent it came down way faster than I expected, and slowed down a lot, too. The Mooney really does spoil you in some ways. 2
hubcap Posted September 19 Report Posted September 19 On 9/18/2025 at 3:02 PM, Hank said: I've always heard it described as "has the glide ratio of a sewer lid," but "like a brick" is gentler. I was told it was a “streamlined” brick.
