Stupid question for Acclaim pilots, my Acclaim on climb out until 2-3000 feet and in cruise under 3,000 feet my plane has a strange hum or weird sound, I’ve had four Mooneys over 35 years this is the only one with an strange sound. I’ve had the plane for a couple years, any others have similar sound. It’s difficult to describe a noise.
Dan
I asked because you could have some space in the plane that is acting like a Helmholtz resonator. My truck will do that if I open a rear window while driving down the freeway. It makes a very low frequency, actually subaudible, sound.
If you are getting a high pitched sound, it could be a piece of sheetmetal or an antenna vibrating in the wind, or a small cavity whistling.
A recording would be nice.
I was thinking something like that, I’m going to make sure the gear doors are fit good and go from there..it is somewhat high pitch but disappears around 2000+ feet.
I’m betting it’s your door seal. My climb rate is usually declining by 3000’.
tear a bunch of strips of paper and when you start hearing the noise, move the paper methodically along the door seam. The scrap will stick where there is a leak. I’m betting you will find your noise eliminated…
Ray I wasn’t thinking door which makes sense I think I’ll get painters blue tape and tape it from the inside and go for avride
TY
Dan
That also makes sense since you had an inflatable seal on your last airplane, so not having one on this airplane would make the sound seem different.
