I just purchased 1996 M20M with recently overhauled Lycoming 540.  When advancing the throttle past idle, fuel sprays out of this uncapped port.
Do I need to cap it?
What do I need to do to correct this issue?
  • Confused 1
Expand
No fuel should be leaking/spraying out anywhere.  A cap should be installed before flight.  In some installations, that fitting is connected to a fuel flow gauge.
To amplify what @M20Doc said, some fuel flow gauges actually measure metered fuel pressure (which is proportional to fuel flow) and connect to that port. If you look closely at the flow divider case, that port is labelled GAGE. If not used, the hose fitting should be removed and replaced with a plug.
Skip
  On 12/26/2022 at 6:15 PM, Yetti said:
I think my fuel pressure line comes off the fuel servo,   Maybe comes off divider, can't remember.
Expand
The fuel PRESSURE line comes off the servo near the inlet. The GAGE line on the flow divider is for a pressure type fuel FLOW gauge. Most Mooneys use an actual fuel flow transducer in the fuel line between the pump and the servo for fuel flow.
I would not fly that plane with fuel spraying out in the engine compartment. Outcome cannot be great  and those things typically don’t fix themselves
Expand
Nope the 75 F only had a Fuel pressure gauge.   I think the Js started with the fuel flow gauges.
  On 12/26/2022 at 4:40 PM, Fly Boomer said:
As @PT20J pointed out:  "If not used, the hose fitting should be removed and replaced with a plug.".  Much better than capping the fitting that's already there.
Expand
A cap would be better than ruining the flow divider if the fitting is seized in place.
Expand
Mooney’s in my experience used fuel pressure measured at the carburetor finger screen or the fuel servo finger screen.  Flow was measured with a flow transducer, FT 101 was a common factory installation.
Bravo fuel pressure transducer installation, lower right side of the engine referenced to compressor air pressure.
To be clear, most aircraft that had fuel flow gauges that often were combo gauges MP / FF were actually pressure gauges, but marked in GPH, they inferred flow from pressure.
My Maule had such a gauge and when I installed an MVP-50 I put a cap on that fitting, the pressure there is very low, I forget what it is but it’s not enough to bother a cap.
I think even at full throttle it’s less than 20 PSI
I know the port marked gauge has a restricted orifice so all the fuel won’t dump out if the line breaks and to keep the leak small. That restricted orifice may be in the fitting
@Roger M
Yikes!
You have some really good feed back with pics supporting them….
One question…
How did you buy a plane with this ‘flaming disaster’ awaiting you?
When did you find the fuel spraying?
There are sooo many red hot parts on a turbo Mooney… having fuel leaking around inside the cowling, could be disastrous ….
A Good Pre-purchase inspection goes a long way…
A good post purchase inspection may be a good alternative…. Something to seriously consider….
Fuel leaks under the cowl of any airplane is not normal…
Somebody had to know something about this plane to have it get in that condition… check it’s logs to see what is recorded…
Expect there is a restrictor still in place, as mentioned above… or the fuel would have been streaming out that size hole….
Talk with the people who installed the engine… it seems they didn’t quite finish the installation…. :)
Good luck with the next steps…
Expand
What engine monitor do you have on this airplane?
Was it on there when you bought it (check the logs and see when it was installed) or has it been changed out recently?
My guess is that when they went from the factory gauges to the JPI, EI or Garmin that they are getting the fuel pressure reading from another area and didn't complete the job of capping this off.
Expand
That was my guess that someone went to the spinning fuel flow sensor over by the pilots feet and forgot to cap this.   Probably should have shown up in a fuel line AD inspection to a knowledgeable mechanic.
Expand
That fitting isn’t used for fuel pressure as it varies with throttle position, it’s used for the old type of fuel flow gauges, unless his aircraft had one of those which is doubtful then the cap wasn’t moved over or was left off during the overhaul, which I think more likely.
I don’t think any 6 cyl Mooney ever had the old style, think Bonanza fuel flow gauge did they?
In other words I don’t think that fitting is ever used on a Mooney with a 540.
That means it’s likely whoever did the engine installation is at fault, and I believe it’s a serious mistake, whatever that’s worth, they should at leads be told about it so they don’t do it again.
Expand
This is what the panel looked like when it was for sale in 2012 (https://www.aircraft.com/aircraft/1172923/n9154n-1997-mooney-m20m-bravo) and it shows a Shadin Mini-Flo on the panel just above the KAS297B Altitude Pre-Select. Not sure if they would have come off of this fitting or not.
Expand
The Shadin measures fuel flow, not pressure so it would not have come off this fitting.
The fuel flow gauges that use that fitting are pressure gauges, but the marking is in GPH instead of PSI.
I don’t think any Mooney with a 540 uses that fitting, but I am no Mooney expert, so the engine installer screwed up, and obviously didn’t even leak check his installation is my belief.
 That’s so unbelievable it has me thinking someone must have removed it later, but why would anyone remove that cap? Maybe the cap was left loose?
Expand
Or just maybe the cap has fallen off and is laying between the cylinders on the baffle?
Expand
maybe, but it would have to have been leaking for quite awhile, but if it fell off, it’s likely still there. I could have probably filled a small tool box with all the tools I’ve found laying in between the cylinders, seems things hide there well.
  On 12/28/2022 at 7:29 PM, Yetti said:
In other news, your MPG should increase slightly since you are not dumping fuel overboard.
Expand
Surely he wasn’t flying like that? If so then that fitting must have a restricted orifice or the engine would quit, fuel would come out of an open fitting like a fire hose.
Still The leak wouldn’t have been small, really lucky he didn’t become a flaming fireball.
