From what I've heard, there is little gain over the J cowl as far as speed.  Correct me if I'm wrong.  It looks pretty modern and cool though.
There would also be little to no gain over the J cowl as far as MP.
When it was put on my airplane, it increased top speed by about 7-8 kts.  Some was due to drag reduction and some due to the much more efficient ram air.  Whereas the original ram air system gave me at most 0.25" of MP, I get between 1.25" and 1.5" increase in MP.  I also really enjoy the dramatically easier preflight and maintenance given the large inspection panels (one on each side) that span the baffling (you can see both in front and behind the baffling) and the lower parting line that makes many more maintenance operations possible with only removing the top cowling (for instance, I can replace all spark plugs, top and bottom, with just removing the top cowling).
I hadn't heard this before.  That's awesome.
So what was the install like.  Time and cost, if you don’t mind me asking. :)
Sorry but my plane was used to develop the cowling so my experience isn't really meaningful to your question.
Hi guys I am slowly getting parts together to do the conversion please see image below does anyone now what the part number or were I can get this part oil cooler baffles .
thanks
Jesse
21 minutes ago, Jesse20 said:
I went on the website listed above and did have any luck finding the part, any other suggestions.
Jesse
You might want to call them.
