Wonder if anyone uses built-in Foreflight performance profile for the Bravo. Seems like the use values that most of the folks on this forum recommend not to use.
For example i don't see performance for 29@2400rpm, and 30@2400 rpm at all.
Contacted them and they said they will only use values published by POH, wonder if custom profiles are working for the folks, since they produce gross errors for me.
Cheers!
Cheers!
I use the performance profile 32/2400 peak and then go and manually increase fuel burn by 12%.  I’m almost dead on with flight planning based on this adjustment.
