Glen Davis Posted September 7, 2020 Report Posted September 7, 2020 I have a 1984 M20J in for a prebuy right now. Do the back seats on this year and model fold down flat? If so, was that standard or an option? Thanks, Glen Quote
Hank Posted September 7, 2020 Report Posted September 7, 2020 Look for the release levers on the rear sidewall. Quote
PTK Posted September 7, 2020 Report Posted September 7, 2020 9 minutes ago, Glen Davis said: I have a 1984 M20J in for a prebuy right now. Do the back seats on this year and model fold down flat? If so, was that standard or an option? Thanks, Glen The back cushions slide up and out, and the frame should fold down flat. The back adjustment/release is behind the rear pax knees. 1 Quote
kmyfm20s Posted September 7, 2020 Report Posted September 7, 2020 I believe the individually adjustable seat that can be removed easily started in 1982. 1 Quote
gsxrpilot Posted September 10, 2020 Report Posted September 10, 2020 An easy way to check... The rear seats are buckets, not a single bench seat. The seat cushion (not the back cushion) is just velcro'd in. You can pull them out easily with one hand. If so... you have the removable rear seats. Quote
rbridges Posted September 10, 2020 Report Posted September 10, 2020 Everything is foldable if you push hard enough. 2 1 Quote
carusoam Posted September 10, 2020 Report Posted September 10, 2020 Glen, look for the release levers... That will help with your confidence level... What else do you have questions with? Best regards, -a- Quote
AIREMATT Posted September 13, 2020 Report Posted September 13, 2020 Similar topic but I didn’t see it anywhere for a 1967 C model. My 1967 Mark 21 Ranger Owner Manual says rear seat can be removed, but it seems to be a fixed back and no releases. A&P doesn’t think my plane has removable rear seats. Anyone know if it was an option only and not standard or if there is a way to tell? Thanks for any help! Quote
Hector Posted September 13, 2020 Report Posted September 13, 2020 Similar topic but I didn’t see it anywhere for a 1967 C model. My 1967 Mark 21 Ranger Owner Manual says rear seat can be removed, but it seems to be a fixed back and no releases. A&P doesn’t think my plane has removable rear seats. Anyone know if it was an option only and not standard or if there is a way to tell? Thanks for any help!My 67 C backseat is not easily removed. The back rest bolts to the frame on the sides and you have to get in there with a socket and open end wrench to remove one bolt each side so you can pull out the backrest. The bottom cushion clips to a rod at the back and just need to undo the clips to get it out. Sent from my iPad using Tapatalk Quote
AIREMATT Posted September 13, 2020 Report Posted September 13, 2020 Thanks Hector! Much appreciated!! Quote
atrosa Posted September 14, 2020 Report Posted September 14, 2020 Hey Glen you take amazing pictures. I love looking at airplanes through your lense. Quote
