Yourpilotincommand Posted July 29, 2020 Report Posted July 29, 2020 lol, I don’t have hub caps, but want them. Please share pics of yours. Original, after market, show em off, thanks! ..and where did you buy them.
Prior owner Posted July 29, 2020 Report Posted July 29, 2020 9 minutes ago, Yourpilotincommand said: lol, I don’t have hub caps, but want them. Please share pics of yours. Original, after market, show em off, thanks! ..and where did you buy them. No hub caps, but tell me- do you have to remove them every time you check the tire pressure? Seems like a lot of trouble...
Yourpilotincommand Posted July 29, 2020 Author Report Posted July 29, 2020 Just now, PilotCoyote said: No hub caps, but tell me- do you have to remove them every time you check the tire pressure? Seems like a lot of trouble... I don’t mind at all. I look for reasons to fly or work on my Mooney.
carusoam Posted July 29, 2020 Report Posted July 29, 2020 Choices... 1) plain white discs... original... 2) polished and shiny... Lasar... 3) Hubba Hubba hubcaps.... has the access panel to reach the air valve... @Speed Merchant ? 4) Many get a hole drilled for access... PP thoughts only... Best regards, -a- 1
xcrmckenna Posted July 29, 2020 Report Posted July 29, 2020 I bought the LASAR aluminum hubcaps then scratched them up and painted them with black texture paint two years ago. Still holding up. Sent from my iPhone using Tapatalk 2 1
Greg Ellis Posted July 29, 2020 Report Posted July 29, 2020 I am not sure where to buy them but LoPresti made the Hubba Hubba Hub caps. They have a hinged opening to allow access to the airstem to put air in the tire without removing the hub cap. If you search Hubba Hubba Hub caps on Mooneyspace there is a thread about it with the Mooney Bravo. I searched online for them and could not find them and Aircraft Spruce used to sell them but I could not find them on their website either. Well....I guess this was not much help. 1
Yourpilotincommand Posted July 29, 2020 Author Report Posted July 29, 2020 I wasn’t able to find them on Spruce or Lasar. I’ll call them.
ArtVandelay Posted July 29, 2020 Report Posted July 29, 2020 I bought the LASAR aluminum hubcaps then scratched them up and painted them with black texture paint two years ago. Still holding up. If I was going to have hub caps, I would only put them on the mains side facing out, for aerodynamics. Can you buy them individually? 1
steingar Posted July 29, 2020 Report Posted July 29, 2020 I assume these are just for looks. Decorate the aircraft as it sits in the hangar. Can't imagine taking money from the fuel kitty to do that. I look for excuses to fly. I work on the aircraft when it needs it.
hypertech Posted July 29, 2020 Report Posted July 29, 2020 They are for looks and keeping crud out of the wheel. I had the flat aluminum ones that I assume are from the factory. I landed one day and had it bent in half after a screw fell out. I'm glad it happened on landing not take off. Who knows what it could have hung up on if retracted like that. I would choose one with a bevel that are less likely to bend if they catch wind. I went with the hubba hubba caps as a replacement. The little door to check pressure works ok. They are probably the dumbest STC I have on my plane. How a hub cap is a major alteration is beyond me. Other than that and being expensive for what they are, they are working out for me.
skykrawler Posted July 29, 2020 Report Posted July 29, 2020 Caps definitely help keep the wheel bearing grease cleaner. The main wheels are exposed when retracted and I would bet the cap reduces the turbulence generated as the air passes over the tucked wheel.
xcrmckenna Posted July 29, 2020 Report Posted July 29, 2020 If I was going to have hub caps, I would only put them on the mains side facing out, for aerodynamics. Can you buy them individually? As far as I know they don’t make ones for the outside of the mains that would be facing down with the gear retracted. But that’s only the little bit of info I know:) The LASAR hub caps are sold as a set. Two for the nose gear one side has a hole for the axle to go through and one on each of the main. Sent from my iPhone using Tapatalk 3
xcrmckenna Posted July 29, 2020 Report Posted July 29, 2020 I assume these are just for looks. Decorate the aircraft as it sits in the hangar. Can't imagine taking money from the fuel kitty to do that. I look for excuses to fly. I work on the aircraft when it needs it. Oh I’m sure you spend money elsewhere, but I’m sure it sounds cool for you to say it....Sent from my iPhone using Tapatalk
redcatcher27 Posted July 30, 2020 Report Posted July 30, 2020 I don't have a picture handy with them on, but I have the chrome ones from LASAR on my 1968 M20F. I love them! The line guys really love them too - I've lost count of the number of compliments I have gotten on them. I'm sure they love my tips too. 1
Yourpilotincommand Posted July 30, 2020 Author Report Posted July 30, 2020 Well darn... I looked at all three wheel hubs and noticed no screw holes to mount a hub cap. Are my wheels not original? Maybe the hub caps pop on/off. ...wishful thinking I guess.
SantosDumont Posted July 30, 2020 Report Posted July 30, 2020 Been thinking about trying to 3D print some hubcaps with a hole to access the valve stem. They're a pain to take off every time I want to check the tire pressure. 1
DonMuncy Posted July 30, 2020 Report Posted July 30, 2020 Take a look at mine in my album. My hangar elf built them. As you can see, they have a pop-out plug, easily removable to check and add pressure. I will be glad to provide details of the construction, and presuming I am not overrun, could possibly be induced to turn out another set. 2
MBDiagMan Posted July 30, 2020 Report Posted July 30, 2020 Don, Great to see you post. Hope all is well! I will take a picture of my moon discs next time I’m at the airport. They are nice shiny ones. I wrote the tire pressure inside. I can remove two screws and loosen one and pivot allowing tire pressure Checking/adjusting. Easy easy.
M20F-1968 Posted July 30, 2020 Report Posted July 30, 2020 I have several that I would be willing to sell. You can e-mail me here. I'll get pictures. John Breda 1
Yourpilotincommand Posted July 31, 2020 Author Report Posted July 31, 2020 13 hours ago, M20F-1968 said: I have several that I would be willing to sell. You can e-mail me here. I'll get pictures. John Breda Please post pictures. Do these “pop in” or screw in type (3 screws)? Thanks
