Jim Peace Posted June 21, 2018 Report Posted June 21, 2018 Now that all my avionics work is done and new engine cables and I have flown the plane about 30 hours etc. My tunnel vision is calming down and I am back to normal. I noticed the last couple of flights that my engine is making what I can only assume is backfire noises from about 400 feet to touchdown. Have not noticed this in the last 4 years of ownership. I have a JPI 900 and will go over the data at some point this week..... threads on this are kind of dated. 1964 M20c 180 hp carb I am due for an oil change soon and will look over everything....but what should be concentrated on?
Hank Posted June 21, 2018 Report Posted June 21, 2018 (edited) Mine sometimes burbles at idle power on short final, kind of like a 3/4 ton Ford truck I used to drive for work did when coasting downhill in town. It's never bothered me, but I've heard it may indicate a too-rich mixture for the weather at that time. Edited June 21, 2018 by Hank
mike_elliott Posted June 21, 2018 Report Posted June 21, 2018 3 minutes ago, Hank said: Mine sometimes burbles at idle power on short final, kind of like a 3/4 ton Ford truck I used to drive for work did when coasting downhill in town. It's never bothered me, but I've heard it may indicate a too-rich mixture for the weather at that time. Check for intake gasget leaks also 2
Patto Posted June 21, 2018 Report Posted June 21, 2018 My C will make popping sounds if I run it rich during descent. Aggressive leaning eliminated it for me. 3
gsxrpilot Posted June 21, 2018 Report Posted June 21, 2018 Yep, same in my C. I learned to leave Mixture off the GUMPS check. Just left it lean all the way to the ground. If I needed to go around, I could get both black and red knobs at the same time. 3
Guest Posted June 21, 2018 Report Posted June 21, 2018 Possibly an intake leak from the recent engine work? Clarence
MarkC Posted June 21, 2018 Report Posted June 21, 2018 +1 to check for an intake leak. This was the cause for me once. Mark 1
takair Posted June 21, 2018 Report Posted June 21, 2018 Check your idle mixture. On shut down, see what the RPM rise is. Something less than 50RPM rise would be optimal. If much more, it might be contributing to rich mixture and popping... 1
jaylw314 Posted June 21, 2018 Report Posted June 21, 2018 If it's a new thing, the warm summer temperatures might be contributing?
skydvrboy Posted June 21, 2018 Report Posted June 21, 2018 8 hours ago, gsxrpilot said: Yep, same in my C. I learned to leave Mixture off the GUMPS check. Just left it lean all the way to the ground. If I needed to go around, I could get both black and red knobs at the same time. If I remember right, don't you do a GEEAR check instead of a GUMPS check? Gear... Everything Else As Required. 2 1
Jim Peace Posted June 21, 2018 Author Report Posted June 21, 2018 Took my plane to Air Mods in NJ. Adjustments were made to the flux capacitor and got an oil change on a short 1 hour notice phone call......did not backfire on the landing back home.... 1
BDPetersen Posted June 22, 2018 Report Posted June 22, 2018 My Christen Eagle sounds like a corn popper when you pull the power on downwind and begin plummeting to earth. Never gets old.
carusoam Posted June 22, 2018 Report Posted June 22, 2018 Hmmm.... 1) I think technically a backfire comes out the carburetor... 2) Making this a frontfire? because it’s coming out the exhaust... (?) 3) O360s are known for running rich at low MP settings... 4) The JPI data will be interesting to see what is going on during that portion of the flight? Increased EGT until the flame goes out? 5) popping in the exhaust can be hazardous to its construction. The interior of the muffler is at risk of getting broken... 6) An experiment to the procedure should show immediate results... Leave the mixture leaned some to see if the popping becomes less... 7) Be sure the mixture is full in, for the go around... 8) My M20C would pop a few times when I pulled the throttle back. I experimented with pulling the throttle a bit slower to see if it would make a difference... 9) This is a good question for carb set-up... asking a mechanic familiar with the carb may be a good idea... PP thoughts only... not a mechanic... Best regards, -a-
Hector Posted June 22, 2018 Report Posted June 22, 2018 My C was doing the same and it was an intake leak. Fixed the leak and popping went away. Sent from my iPad using Tapatalk
Boilermonkey Posted June 22, 2018 Report Posted June 22, 2018 Mine does that if carb heat is onaking the mixture too rich.Sent from my Pixel using Tapatalk
Hank Posted June 22, 2018 Report Posted June 22, 2018 1 hour ago, Boilermonkey said: Mine does that if carb heat is onaking the mixture too rich. A hot summer afternoon will do the same thing.
