MARZ Posted May 24, 2018 Report Posted May 24, 2018 Looking for a source to get Tefzel 18 awg 4 conductor shielded wire - all I can seem to find is 3 conductor from the usual sources....
jetdriven Posted May 24, 2018 Report Posted May 24, 2018 (edited) http://www.prowireusa.com/p-343-m22759-16-18-4-yellow-wire-tefzel-18-awg.aspx https://m.skygeek.com/m22759-16-18-4.html ah wait, shielded. For strobes. Very tough. Edited May 24, 2018 by jetdriven
MARZ Posted May 24, 2018 Author Report Posted May 24, 2018 Yea... so I may not be deep enough into the documentation yet - I just have the position lights on the wingtips - looking at doing the Orion's (LED) from what I saw on Aircraft spruce it calls for 18awg - I'm guessing shielded.......
N201MKTurbo Posted May 24, 2018 Report Posted May 24, 2018 Look up the mil spec. Some of the wire manufacturers have it posted. Find the mil spec number of the wire you are looking for and search on that. You can find just about everything. The hard part is finding someone who will sell you less than 1000 ft. 1
N201MKTurbo Posted May 24, 2018 Report Posted May 24, 2018 Here is a page that links to a lot of specs: http://www.militarywire.org/ 1
carusoam Posted May 24, 2018 Report Posted May 24, 2018 Is this it? http://www.aircraftspruce.com/catalog/elpages/whelencablekits.php?gclid=CjwKCAjwopTYBRAzEiwAnU4kbxk_66sWx6j4hf85cXqgQIX_gkd4DJcEKvetMWxu8FmbKb74Fp0nzhoCta8QAvD_BwE It is a Whelen supplied part, thru AS... If it is... the idea came to mind while reading through this thread. By the time I finished reading, the idea was floating nearly completed... the power of MS at work... If it isn’t... the power of MS isn’t finished yet... stand by... Best regards, -a-
carusoam Posted May 24, 2018 Report Posted May 24, 2018 How many feet are required for this project? Panel to each wing tip and tail? Best regards, -a-
MARZ Posted May 24, 2018 Author Report Posted May 24, 2018 9 hours ago, carusoam said: How many feet are required for this project? Panel to each wing tip and tail? Best regards, -a- Yes - My AP and I haven't looked at the current routing or potential junction points - I'd rather run the new wire than run additional wires - alternatively I may run two new doubles - thinking it's going to be easier to source. That's my idea and will have to bounce it against the AP 1
MARZ Posted May 25, 2018 Author Report Posted May 25, 2018 All the searching - and where do I find it ????? E-bay sheez 2
RLCarter Posted May 25, 2018 Report Posted May 25, 2018 49 minutes ago, Mike Ropers said: All the searching - and where do I find it ????? E-bay sheez Go figure
bradp Posted May 27, 2018 Report Posted May 27, 2018 Ebay can be a great source for wire you just need to be able to weed out the $hit.
1964-M20E Posted May 28, 2018 Report Posted May 28, 2018 Shielded might be a nice touch but unless it is called out in the docs I don't think it would be necessary. You don't have the high voltage pulse on the LEDs lights like you do with traditional strobes. JMHO and a silly electrical engineer that deals with real voltage and power.
MARZ Posted May 28, 2018 Author Report Posted May 28, 2018 19 minutes ago, 1964-M20E said: Shielded might be a nice touch but unless it is called out in the docs I don't think it would be necessary. You don't have the high voltage pulse on the LEDs lights like you do with traditional strobes. JMHO and a silly electrical engineer that deals with real voltage and power. Good point - looks like I overkilled it - shhhh don't tell my wife.
