BRBENNETT Posted May 26, 2017 Report Posted May 26, 2017 Does anyone know what this is? No luck with this part number with any commercial mfgs. though it might be Alemite, but, no dice. See attached pdf with circled items in graphic and text. My aircraft is an M20F, late 1967. grease ftg ref.pdf Quote
N201MKTurbo Posted May 26, 2017 Report Posted May 26, 2017 (edited) I'm pretty sure this is the one you want: http://www.aircraftspruce.com/catalog/appages/greasefittings.php That is not the one, see below. Edited May 27, 2017 by N201MKTurbo Quote
N201MKTurbo Posted May 26, 2017 Report Posted May 26, 2017 http://www.partdeal.com/alemite-special-thread-straight-fitting-6-40-unf-2a-3018.html?zmam=74973193&zmas=1&zmac=4&zmap=77211866&gclid=CKLS8_OujtQCFQyHaQodHCUJuw I checked my manual. I think yours has a typo. it should be 3018 Quote
N201MKTurbo Posted May 26, 2017 Report Posted May 26, 2017 And just because I've never seen one in the wild before here is the one at the other end of the landing gear: http://www.partdeal.com/alemite-straight-fitting-5-32-in-shank-3019.html Quote
carusoam Posted May 26, 2017 Report Posted May 26, 2017 (edited) I wasn't able to connect the part number in the title, to the drawing, or the parts list... Got a photo you can post? Some Mooney grease fittings are threaded. Some are press-ins. If yours is missing, it probably used to be pressed in. Best regards, -a- Edited May 26, 2017 by carusoam Quote
Yetti Posted May 26, 2017 Report Posted May 26, 2017 https://www.saeproducts.com/grease-fitting-assortment-kits.html?gclid=CjwKEAjwpJ_JBRC3tYai4Ky09zQSJAC5r7ruc-R5GvgXQgnDLhMjWUP4gOwGEqkc_4mOj2nLGqL1CxoCRW7w_wcB Quote
N201MKTurbo Posted May 27, 2017 Report Posted May 27, 2017 1 hour ago, Yetti said: https://www.saeproducts.com/grease-fitting-assortment-kits.html?gclid=CjwKEAjwpJ_JBRC3tYai4Ky09zQSJAC5r7ruc-R5GvgXQgnDLhMjWUP4gOwGEqkc_4mOj2nLGqL1CxoCRW7w_wcB Unfortunately, none of those kits have the two grease fittings for the landing gear. Quote
cliffy Posted May 27, 2017 Report Posted May 27, 2017 One caution, these (especially the press in ones) zerks are sometimes yanked out by too tight a grease gun nozzle. Alemite sells a nozzle that is adjustable in tightness when attached to the zerk head. 1 Quote
BRBENNETT Posted May 31, 2017 Author Report Posted May 31, 2017 Thanks for all the responses. i ended up doing a precision measurement on the fitting that came out and it ended up being a 12-36 thread. http://www.kingfisherlubrication.co.uk/catalogue/greasenipples/564_HydraulicGreaseNipple1236Uns.html. Good ole Amazon sells a tap as well. Wierd! 1 Quote
RLCarter Posted May 31, 2017 Report Posted May 31, 2017 Good to know, I have 2 that the check ball is missing, I have rubber caps on those and check them frequently Quote
outermarker Posted March 15, 2021 Report Posted March 15, 2021 Photos of the location. Mooney P/N #3018 and yes, it is a typo in the manual. This is such a GREAT site! Quote
outermarker Posted March 17, 2021 Report Posted March 17, 2021 I found out that the 3081 number is in fact a typo as mentioned and should be 3081. This grease fitting doesn't have a ball. There is also what I believe several other typos...MS150001-1 (22-1), 46604 (23-6) and the location on 22-4 is pointing to the wrong spot. I sure would like to know what 46604 really is. MS15001-4 is a 90 degree angle fitting, it will be interesting to see if these still exist on my gear or if they have been changed out to MS15001-1. It is a 55+ year old airplane. 1 Quote
Mooney-Shiner Posted September 16, 2021 Report Posted September 16, 2021 To further highlight the difference between the standard Zerk MS15001-1 grease fitting (majority of the grease fittings on the Mooney) AND "3018" fitting on the FWD and AFT swinging points on the main gear see the attached photo. I just ordered mine from Lock and Lube (see ALEMITE 3018 GREASE FITTING - 6-40 UNF-2A THREADS): https://locknlube.com/products/alemite-3018-grease-fitting-6-40-unf-2a-threads?_pos=1&_sid=b15bed1d7&_ss=r Now I need to figure out how to extract the broken threaded neck of the old 3018 fitting from the FWD swinging point on my 20F. I ordered the micro extractor set on Amazon: https://www.amazon.com/gp/product/B08HRWGTN4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 Fingers crossed, I can back the old broken neck out and install the new shinny 3018 in place. Quote
GeeBee Posted September 16, 2021 Report Posted September 16, 2021 Better than the adjustable grease nozzle is the "Lock-N-Lube" nozzle. https://locknlube.com With respect to the press in 3019 zerk, I stopped replacing them and use a needle tip pressed firmly, gets the job done. Get a Lock N Lube coupler with a Milwaukee cordless grease gun and a long hose. Greasing made easy. 1 Quote
67 m20F chump Posted September 16, 2021 Report Posted September 16, 2021 (edited) Locknlube also has that zerk under grease fittings. I think on page 2 for .99 each. I picked up some along with the grease gun. Edited September 16, 2021 by 67 m20F chump Quote
47U Posted September 16, 2021 Report Posted September 16, 2021 10 hours ago, ukrsindicat@yahoo.com said: Now I need to figure out how to extract the broken threaded neck of the old 3018 fitting from the FWD swinging point on my 20F. I ordered the micro extractor set on Amazon: The micro extractor set should work well for you. I felt pretty lucky when both gear trunnion forward zerks came out using a simple valve core repair tool. 4 1 Quote
PT20J Posted September 16, 2021 Report Posted September 16, 2021 10 hours ago, GeeBee said: With respect to the press in 3019 zerk, I stopped replacing them and use a needle tip pressed firmly, gets the job done. Do you do this through the zerk, or in the hole left when the zerk was removed? I believe that these zerks do not have the check ball. Skip 1 Quote
Shadrach Posted September 16, 2021 Report Posted September 16, 2021 31 minutes ago, PT20J said: Do you do this through the zerk, or in the hole left when the zerk was removed? I believe that these zerks do not have the check ball. Skip I have one that I use a needle on. The zerk head is gone but part of he shaft remains. You’re correct about the absence of a ball valve. 2 Quote
GeeBee Posted September 16, 2021 Report Posted September 16, 2021 I do it through the hole that is left. The entire zerk is missing. 4 Quote
carusoam Posted September 17, 2021 Report Posted September 17, 2021 Now all the technical detail has been covered… Perfect time to consider getting the colored rubber covers for all the Zerks…. GeeBee was having a sale on these things… GO MS! -a- Quote
vik Posted April 11, 2022 Report Posted April 11, 2022 On 5/31/2017 at 7:52 AM, BRBENNETT said: Thanks for all the responses. i ended up doing a precision measurement on the fitting that came out and it ended up being a 12-36 thread. http://www.kingfisherlubrication.co.uk/catalogue/greasenipples/564_HydraulicGreaseNipple1236Uns.html. Good ole Amazon sells a tap as well. Wierd! So, what is the conclusion? Is it 3018 zerk or 12-36 UNS taper and where I can buy one. I have the same problem as many other owners, the grease fitting in the aft bearing of the main landing gear is missing. Quote
N201MKTurbo Posted April 11, 2022 Report Posted April 11, 2022 The problem is the standard grease gun. The fitting won't release. When you try to get the grease gun fitting off the zerk you tear the zerk fitting off. The zerks on the landing gear pivots are very fragile and can't take the forces needed to get the fitting off. The Lock and Lube is the secret to success with those zerks. 1 Quote
N201MKTurbo Posted April 11, 2022 Report Posted April 11, 2022 http://www.partdeal.com/alemite-straight-fitting-5-32-in-shank-3019.html https://www.finditparts.com/products/2240084/alemite-3018?srcid=CHL01SCL010-Npla-Dmdt-Gusa-Svbr-Mmuu-K2240084-L136&gclid=EAIaIQobChMI0Mz988WM9wIVjBmtBh2UdQwAEAQYASABEgKi4fD_BwE https://www.finditparts.com/products/2240105/alemite-3019?s_s=3019&sctx=eyJzIjoiMzAxOSIsInNvdXJjZSI6InNlYXJjaHBhZ2UiLCJwcm9kdWN0X2lkIjoiMjI0MDEwNSIsInJlc3VsdF9jb3VudCI6MjEzOSwicmVzdWx0X2lkeCI6Mn0=&ga_list=Search Results V3 https://www.amazon.com/Alemite-Special-Thread-Fitting-Straight/dp/B00KNXO4R4 https://www.amazon.com/Chaps-Alemite-3019-Grease-fitting/dp/B004HMAPDO Not that hard to find. Just search for Alemite 3018 and 3019 Quote
A64Pilot Posted April 11, 2022 Report Posted April 11, 2022 (edited) There is a regular length Loc-N-Lube and a long nose one, my regular length one won’t fit on a couple of fittings, perhaps the long nose one will? There are two fittings on the nose gear that require a 90 degree adapter, I replaced them with 90 fittings so I don’t need the adapter Edited April 11, 2022 by A64Pilot 1 Quote
47U Posted April 12, 2022 Report Posted April 12, 2022 7 hours ago, N201MKTurbo said: The Lock and Lube is the secret to success with those zerks. I’ll try my Lock and Lube next summer. To release the zerk, unscrew the end of the grease fitting from its body and the pawls will get loose. Yeah, it’s a pain to do it that way, but it keeps from breaking the zerks. Quote
